Back on the T'bird!
Discussion in 'Off Topic Hot Rods & Customs' started by flynbrian48, Jun 17, 2025.
  1. 6sally6
    6sally6
  2. flynbrian48
    flynbrian48
    It’s got 2 double wet coats of 2K over epoxy primer, so the short answer is no. It’s going in, I’ll mask it and work around it. It’s been out for so long I need to see the car with gl*** if only to keep me inspired.
    SS327, 57 Fargo and RodStRace like this.
  3. flynbrian48
    flynbrian48
    Here's the last of the stock steering junk headed for the s**** pile. I'm happy to be rid of this, have a non-power steering link for the center link coming from Ekler's. E84CDE5C-431F-4B3A-B8D5-97568BB080BC.jpeg
  4. RodStRace
    RodStRace
    Check for a rebuilder. That may be gold to them. I'm no fan, but they aren't making them any more!
    porkshop and warhorseracing like this.
  5. rockable
    rockable
    flynbrian48 and porkshop like this.
  6. Pontmerc
    Pontmerc
    from Finland
    It was basically same system that corvette use till 1981.
    Somehow when you buy expensive borgeson kit, you can never admit that its not any better than old properly working setup.
    CSPIDY and porkshop like this.
  7. flynbrian48
    flynbrian48
    Is, “Yeah, well they **** too”, an acceptable reply? Having had a couple of them, that is my evaluation. And, illl add that anything would be better, even a rope tied to each steering arm. ;)
    Jrs50, SS327, rockable and 1 other person like this.
  8. flynbrian48
    flynbrian48
    The valve is a rebuilder I installed years ago, with very little use as I quit driving the car shortly after. I could offer it to someone, but I’d rather not deal with people.
    Jrs50, ffr1222k, miker98038 and 3 others like this.
  9. Pontmerc
    Pontmerc
    from Finland
    Sorry if i hurt your feelings.
    Do what ever makes you happy.
  10. flynbrian48
    flynbrian48
    Didn't hurt my feelings at all, if one likes sloppy, vague steering, then that system is great.
    rockable and porkshop like this.
  11. Pontmerc
    Pontmerc
    from Finland
    I dont like sloppy steering either but i know how to repair it to work as it should.
    Ford ram cylinder steering is a perfectly good system, when in good condition.
    warhorseracing likes this.
  12. flynbrian48
    flynbrian48
    I would disagree, based on the fact that this is a rebuilt valve, rebuilt ram, new tie rod ends, idler and ball joints. It was not good.
    If this power steering set up were that good it'd still be used. It isn't. I'd have done a R&P but the Borgeson is a bolt in proposition, I'd have had to fabricate mounts and fanagle a steering shaft around the headers and crossmember.
    You can have all that stuff if you want to pay the freight.
    rockable, Okie Pete and porkshop like this.
  13. Pontmerc
    Pontmerc
    from Finland
    You have spent lots of money for "experts" who dont know how to rebuilt things.
    That does not make ford steering set up bad.
  14. flynbrian48
    flynbrian48
    Didn’t make it good either. I also know when to stop throwing money at outdated stuff. You seem to be very concerned that I did this. Again, if you want that junk, you can have it..:p
    rockable and loudbang like this.
  15. rockable
    rockable
    You can't make chicken salad out of chicken poop. That system is poorly designed and wears out long before it should. You seem to be the only fan.
    flynbrian48 and loudbang like this.
  16. flynbrian48
    flynbrian48
    Yesterdays project was to (try to) fire it up. I dumped what gas I had (about 3 gallons) in it, swiped the battery out of the Impala, cycled the (new Walbro) fuel pump in several times and hit the key. Turned over about half a revolution, fired, coughed, fired again. Repeated this several times with the same result. I don't have a fuel pressure gauge (yet, one will be here this afternoon), but it sure seems to be lack of fuel. I used a fuel pressure regulator/return filter similar to a Corvette system from Tanks Inc. (where I got all the rest of the fuel system stuff), and on their advice simply plugged the 5.0's factory fuel return port at the fuel rail. I'm going to see if, until the gauge set arrives, see if the Schrader valve at the fuel rail has any pressure, and if not I think the issue may be that the regulator/return set up isn't compatible with the Ford 5.0.
    Frustrating, mostly because I don't understand all I know about this stuff, but I'll get it. It ran when parked, until I replaced the tank and pump...
  17. I'm glad to see you back on this. I do love me a flynbrian build!!!
  18. flynbrian48
    flynbrian48
    Addendum: The fuel pressure gauge set arrive from my pal Jeff Bezos, so I fitted it to the Schrader valve at the fuel rail, put a battery charger on it and cycled the pump. Took 4 cycles but it came up to 40 PSI (I guess Fords need 35+ PSI), so now to pull the battery back out of the Impala and see if this 'Bird has wings...
  19. flynbrian48
    flynbrian48
    EXTRA! EXTRA! EXTRA! The 'bird fired up as if it'd been shut off yesterday! However much gas I had dumped in it evidently wasn't enough to get into the fuel pump windage tray, as I dumped whatever was left in my gas can and that did the trick. So, that made my day. I'd have taken a little video but didn't have my phone this morning, so y'all hafta take my word for it, but it runs perfectly. I'm excited now.
  20. riv63
    riv63
    from Texas
  21. flynbrian48
    flynbrian48
    When I fired the car up the other day after I shut it down there was gas on floor at both ends. Not a lot, but definitely lines leaking. I got under it this morning and found the problem, rotten 30 year old rubber lines from at the front to the fuel rail, and a not tightened fitting under the tank from the filter to the line. I made a plug for the front as the original return line could be abandoned with the new regulater/return filter, and tightened the flare fitting at the back. It fires right up with no leaks, no issues now, so I can go back out and install the pitman arm on the new steering box and install the center link fitting that replaces the original power steering valve. Sorry Pontmerc, all that old stuff is in the recycle bin now. ;) Note: I tried uploading the video of starting it up, but my internet connection is super slow for some reason and wonky, won't load, so, we'll save it for another day...
  22. Dick Stevens
    Dick Stevens
  23. flynbrian48
    flynbrian48
    I worked on the left front fender where it had a knot from welding the new section in to fit the ‘63 Caddy headlight bezels, and then finished up the (roughed in) work on the driver’s wheel opening. I won’t be able to drive it the full skirts with the Salt Flats wheels, and I’d never had just the upper section of the skirts on, so I tried thiss one on .
    51pontiac, Okie Pete, fordor and 6 others like this.
  24. flynbrian48
    flynbrian48
    Brakes bled, windshield ready to go in. I’m going to need hand with that… IMG_4116.jpeg IMG_4117.jpeg
    porkshop, SS327, Okie Pete and 5 others like this.
  25. flynbrian48
    flynbrian48
    Well, ****. I was going to set windshield today, my wife helped me set the gl*** in the body with the rubber on. The fly in the ointment is that with the w/s frame sunk into the body like I did it, I have a trough that is too narrow at the bottom to accommodate the very bulky gasket. I tried t******* some of the (cosmetic) lip off the bottom and tried setting it again. I thought it was going to slide in, but with putting a tiny bit of pressure on the gl*** at the top it cracked in the corner.
    So, plan B is getting a new w/s which I’m going to glue in. Not the way I want to do it, but it’ll work.
  26. rockable
    rockable
    Aaarrrgggh! :mad::(
    SS327 likes this.
  27. RodStRace
    RodStRace
    @flynbrian48 I usually try to 'like' updates, but I can't bring myself to hit the ****on for that!
    fordor and j hansen like this.
  28. flynbrian48
    flynbrian48
    Right? It’s not the end of the world, but it still ****s.
    RodStRace and SS327 like this.
