Hilborn 301 Update - 2nd Go at old project
Discussion in 'Off Topic Hot Rods & Customs' started by GlassThamesDoug, Aug 27, 2025.
  1. GlassThamesDoug
    GlassThamesDoug
    Finally after alot of years, going to finish the 302 sbc Hilborn.
    Had pieces going together in 2006, changed direction on G***er, sold this Hilborn to brother. He had it on his Nova, running on his 301, started as good as any carburetor, and idled great. He got some bad advice from a box bracket racer, removed it, and sold it to his friend. Fellow Hamber bought it, and I recently bought it back. I had sent nozzles and pump to Hilborn back in 2004 time frame, had flowed the nozzles, and inspected and flowed 150A pump. Purchased brand new barrel valve.
    The 302 iron is running, and the cam Dialed into this system from jets, to stack length is in the engine. Ironically I bought 3x cam kits in around 2010 for this Hilborn: 0.500, 0.525, 0.555 solid FT dialed into this system via article from "ram tuning equations" ...
    Basically it's pull tunnel ram system, and begin the install.
    20250818_171538.jpg 20250818_173425.jpg 20250818_163937.jpg 9e6a5c74-ce0a-4d72-844e-241666a609a1.jpg
  2. GlassThamesDoug
    GlassThamesDoug
    Picture when it was running on Nova 2015.
    rod1, Deutscher, Deuces and 5 others like this.
  3. Mike Lawless
    Mike Lawless
    Mechanical systems are as simple as it gets. All the nozzle and by p*** jets (pills) are dependent on pump output. Once dialed in, the only thing that messes 'em up is crud and fuel contamination.
    They will not be fuel efficient on the street, but they can be made tame enough to do so.
    The biggest set-up mistakes are stuff like too small, or too long a suction line to the pump. They DO NOT like restrictions, and while it may run OK at low load, it can ruin a motor at high RPM due to pump cavitation resulting in severe lean out. Another mistake is setting up high speed byp***es/lean out valves etc before getting it tuned in a basic configuration first. I've seen that dozens of times. MFI rookies will want all the bells and whistles before getting it dialed.
    I would advise doing a basic set up first before trying the whiz-bang stuff. Also, err on the side of smaller nozzles. A smaller nozzle with higher fuel pressure will have a better spray pattern than a big nozzle and low fuel pressure.
    vtx1800, RodStRace, Deutscher and 3 others like this.
  4. GlassThamesDoug
    GlassThamesDoug
    Sounds good, Yes, agree no high speed byp***es, just the basic Hilborn Set Up.
    I have -8AN and -10AN inlet lines.
    Collecting spare nozzles, looking for some extra 6As.
    porkshop, Deutscher and elgringo71 like this.
  5. GlassThamesDoug
    GlassThamesDoug
    Next, clean and install unit. Set on heads temporarily.
    Old Tunnel gets a break.
    rod1, Tickety Boo, Deuces and 3 others like this.
  6. Dave G in Gansevoort
    from Upstate NY
    Oh man, that takes me back! First time on the modified back in 75, I had no experience with injection and no one to help. One call to Hilborn, and they had me ready to go. 3/4 lines from the tank to the pump, 3/8 lines from the pump to the barrel valve, the byp*** and the blowoff, back to the tank. That engine would idle around 800-900 rpm, and the cam ran out of pull around 7700 rpm. What a toy for a 19 year old…
  7. GlassThamesDoug
    GlassThamesDoug
    Found markings on 150 pump. Yeah it's mine from 2004, pump cover, body and all fittings have identifiers I put on them.
    rod1, Deutscher, Tickety Boo and 5 others like this.
  8. GlassThamesDoug
    GlassThamesDoug
    20250901_102653.jpg Verified pump rotation, flipped cover, by relocating dowel, this repositions center gear to the correct belt drive orientation for Hilborn PD bracket which mounts to water pump.
  9. GlassThamesDoug
    GlassThamesDoug
    Intake is on 301.
    Mike Lawless, rod1, Deutscher and 4 others like this.
  10. GlassThamesDoug
    GlassThamesDoug
    Stant Twist on breather looks correct.
  11. Dave G in Gansevoort
    from Upstate NY
    Other than the type of fuel, essentially the same deal! Heads were the latter 492 castings ported by Mondello.
    Make a video of it running, please! Got to get a Hilborn fix!
    GlassThamesDoug and Deuces like this.
  12. GlassThamesDoug
    GlassThamesDoug
    For sure...
    porkshop likes this.
  13. GlassThamesDoug
    GlassThamesDoug
    Have some Moon breathers for these Corvette valve covers, been wanting to use.
    Tickety Boo and porkshop like this.
  14. GlassThamesDoug
    GlassThamesDoug
    Found my belt drive bracket.
    Had the gilmer belt hanging for years.
    Mike Lawless, rod1, Deuces and 5 others like this.
  15. Harv
    Harv
    from Sydney
    That looks like the pump has been shown some love over the years. Some of the ones I have opened up look like they were rode hard and put away wet :(
    cheers,
    Harv
    porkshop and GlassThamesDoug like this.
  16. GlassThamesDoug
    GlassThamesDoug
    Had it inspected and rebuilt at Hilborn around 2006? Was flowed as well. Only used for a few hrs in 2015. Found spare parts from rebuild still in plastic bag.
  17. Dave G in Gansevoort
    from Upstate NY
    Just a question. Who can make the nozzle hoses these days? I had everything R&Rd before mothballing them in the late 70s. However I didn’t expect them to stay that way until now. The hoses are 50 years old. They look fine, but I don’t think I want to use them…
  18. Flatrod17
    Flatrod17
    Dave, you can make your own. I reused the fitting or you can buy new. I bought the br*** parts at a rubber hose store and used a electrical crimper to attach them. I also made a crimper out of a old dead tubing cutter. Just took the cutting blade out, made a rounded one for it. it works great.
    Or you can go to just about any in the fuel injection people and buy all new stuff.
  19. Dave G in Gansevoort
    from Upstate NY
    When the time comes, I’ll be in touch. I have a 327 that is just screaming for the Hilborns. Gotta keep up with You west coast guys…
  20. GlassThamesDoug
    GlassThamesDoug
    Few -8 hoses for coolant, and a new hose for inlet to low restriction screen filter.
    Ignition Decision.....
    For those interested, The 4 outlet Radiator was made specifically for run stands by the "Radiator Lady" in California. Best money I spent over 10 years ago.
    Tickety Boo, SS327, loudbang and 2 others like this.
  21. Dave G in Gansevoort
    from Upstate NY
    If you hadn’t mentioned that, I would have never known. Looked at the picture and never saw the outlets until just now. Nice
  22. GlassThamesDoug
    GlassThamesDoug
    Be nice to have a set of metal fuel lines like Blower Hats have.
    loudbang and Tickety Boo like this.
  23. Chucky
    Chucky
    I almost never go to the off topic section. This might be my 4th? visit ever. I have to ask…why the heck is this awesome thread in here? Are you hooking up a computer to that injector?
    GlassThamesDoug and slowmotion like this.
  24. slowmotion
    slowmotion
    Just a guess, but maybe because the sbc 302 wasn't "officially" in production until '67, post '65 cut-off for the main board? Even though they were a thing waaay before that in hotrodum...
    Tickety Boo and GlassThamesDoug like this.
  25. Dave G in Gansevoort
    from Upstate NY
    Just call it a 301, like before Chevy renamed them
  26. Mike Lawless
    Mike Lawless
    Fuel injection enterprises (if they are still in biz ) is where I got a lot of mine from.
    Kinsler FI is a source too
    GlassThamesDoug likes this.
  27. GlassThamesDoug
    GlassThamesDoug
    Been working on 65 F100.... lately.
    352 FE Running now.
    Tickety Boo, SS327 and Mike Lawless like this.
