Projects 62 409 20 Day to Great Bend KS
Discussion in 'The Hokey Ass Message Board' started by saltflats, Sep 6, 2014.
  1. saltflats
    saltflats
    from Missouri
    Got it down on rubber after some time setting on the lift. Should be some good inspiration to keep pushing for completion on my deadline. Had to change out the rear studs to the 5x5 bolt pattern to get the M/T wheels on.
  2. saltflats
    saltflats
    from Missouri
    Well I'll be dang, it still runs.
  3. Chucky
    Chucky
  4. 427 sleeper
    427 sleeper
  5. saltflats
    saltflats
    from Missouri
    Hope the leather on the accelerator pumps swell up some new fuel and get to working.
    Tickety Boo likes this.
  6. Healthy sounds!
    saltflats likes this.
  7. saltflats
    saltflats
    from Missouri
    Sometimes it's all about the bling. :cool:
  8. saltflats
    saltflats
    from Missouri
    Seat belts showed up, now to pick out a new helmet.
  9. saltflats
    saltflats
    from Missouri
    Well the accelerator pumps never cam back to life on the 625s Carters. I do have a pair of 750s ready to go but I am a firm believer in only changing one thig at a time. I'm calling the ch***is and roll bar upgrades as the one change. I will take the 750s to the track with me and change them out there after I get a baseline of how the car runs coming out of retirement. So got two kits coming for the 625s.
    swade41, Tickety Boo, SS327 and 5 others like this.
  10. I hear you. I'll also be back to carb rebuilding soon as the Holley I rebuilt this spring also isn't pumping (squirters aren't squirting). It's a replacement for an Autolite 4100 and has no adjustable floats or sight gl***/peep hole (I know, weird!) so I'm going to check out a few 1850s that a guy in Belton has available and if they aren't too roached, I'll pick one up plus get a rebuild kit and wash/rinse/repeat. If I get a working carb, then it's onto replacing that damned Duraspark II with a 1970 points distributor and coil. Good luck with your carb swap and rebuild(s).
    UPDATE: pulled the carb, watched an online tutorial and noticed there was too big a gap between the accelerator pump arm and the throttle ***embly. Removed the pump to find I'd put the diaphragm in upside down. At least that now works. Won't know about the rest of the carb until it gets tested once the ignition's replaced.
    laidbackluis and saltflats like this.
  11. patsurf
    patsurf
    we need an 'upside-down ' emoji for all the posts like this!
    osage orange, SS327 and saltflats like this.
  12. saltflats
    saltflats
    from Missouri
    Carburetor kits showed up so got the accelerator pumps working. When I had the rear carburetor off the accelerator pump linkage fell off and had me on a wild goose chase retracing my steps. Guess I should sweep my shop floor.
    New brain bucket showed up.
    Did some prep work on the floor pan braces so I can get started on the pan install.
  13. saltflats
    saltflats
    from Missouri
    Made another big swing at it today. Got the door bar welded in and the swing out brackets installed.
    61Cruiser, Moriarity, swade41 and 8 others like this.
  14. saltflats
    saltflats
    from Missouri
    Got the drivers side floor pan welded in.
    Little warm in the blue sky garage today. Trying to stay well hydrated drinking lemon ice water.
    61Cruiser, Moriarity, swade41 and 7 others like this.
  15. saltflats
    saltflats
    from Missouri
  16. saltflats and Tickety Boo like this.
  17. Tickety Boo
    Tickety Boo
    from Wisconsin
    Got the driver's side floor pan in
    After all the strengthening done to the X frame along with the 6-point roll bar you've installed the Saltshaker should 60-foot hook like a Bear :cool:
    You might **** the pan ;):D:D:D
  18. saltflats
    saltflats
    from Missouri
    Not much of a converter in the car to help with 60 foot times. My main reason for all this work was to make the car safe. Good chance I have put on a few pounds with the added steel. All the events are bracket races so it doesn't have to be the quickest just consistent and the driver needs to be on point.
  19. saltflats
    saltflats
    from Missouri
    Another big swing of the axe today. All seat belt mounts in except the crotch belt. P***enger floor brace and floor pan welded in. Was a little warm in the blue sky garage today. Time to watch NASCAR and have a few beers to cool down. 20250913_134046.jpg
    61Cruiser, Moriarity, swade41 and 9 others like this.
  20. saltflats
    saltflats
    from Missouri
    The last seat belt mount is welded in.
    Using the shrinker to finish off the factory pans to the new rear crossmember.
  21. DDDenny
    osage orange and Tickety Boo like this.
  22. saltflats
    saltflats
    from Missouri
    Thanks Figured a seat belt mount was important.
  23. saltflats
    saltflats
    from Missouri
    Upholster I am not. :eek: This is the head rest.
  24. saltflats
    saltflats
    from Missouri
    Blue sky garage is closed until further notice.
    Had a major downpour come through here this afternoon.
    osage orange, swade41 and Stock Racer like this.
  25. 427 sleeper
    427 sleeper
    Well... ****!!!
  26. saltflats
    saltflats
    from Missouri
    I heard some thunder so went it to check the radar and it wasn't looking good. So rounded up the tools and moved the welder inside. Then scrambled and got the quarter gl*** back in to protect the cars inside. When I get this done I need to make a big push to get my carport up.
    osage orange, Chucky, swade41 and 5 others like this.
  27. saltflats
    saltflats
    from Missouri
    Couple more holes to patch then I can put the carpet back in and mount the shifter and seat.
  28. swade41
    swade41
    from Buffalo,NY
    It's all looking good, I opted for a white open face helmet too and switched from red belts to black. Funny how you get tied up thinking about all that kind of stuff, you'd think that would be the simple stuff after building a car. Lol
  29. saltflats
    saltflats
    from Missouri
    Office going back together.
  30. saltflats
    saltflats
    from Missouri
