Technical Best tire dye for Coker Firestones
Discussion in 'Traditional Hot Rods' started by Choppedcoupe, Aug 16, 2025.
Tags:
  1. Choppedcoupe
    Choppedcoupe
    I’ve got some Coker bias ply Firestones on my coupe. I love them. But, they are turning a nice uniform brown color. I ***ume that it is surface oxidation(?). Not sure how old they are. No cracks, no problems, they drive great. The fronts are newer than the rears, but they have the brown discoloration too. What’s the best way to turn my brown tires black again? I’m hoping that they can be dyed. I’d rather not have greasy lotion all over them…. If it is a product that I need, please recommend a brand and a source.
  2. '29 Gizmo
    '29 Gizmo
    from UK
    Not oxidation. It's the sulphur and protective chemicals that precipitate out. It's how rubber protects itself from the environment. It's why there are no cracks!
    gimpyshotrods and JD Miller like this.
  3. Dan Hay
    Dan Hay
    They tell you not to use it on their white walls, but Wesley’s Bleach white and a good scrub brush will get the brown off.
    D-Russ, 270ci, Outback and 4 others like this.
  4. Jack E/NJ
    Jack E/NJ
    from NJ
  5. AccurateMike
    AccurateMike
    Westley's Bleche-Wite and a scrub brush has been getting the brown stuff off of my tires for decades. I apply it to a dry tire, scrub it up some, mist on some water, scrub it more and rinse. The rinse water comes off brown as ****. Mike
    D-Russ and weps like this.
  6. ‘28 RPU
    ‘28 RPU
    Here’s what I do and the old guys at the tire shop are really impressed. (1) Give them a good scrubbing with Blue Dawn in hot water. (2) Apply “Hot Shine” (which is a vastly superior compe***or to Armour All). (3) Give the tires a good scrubbing with the Hot Shine and the stiff brush. (4) Wiped the gunk off the tire. (5) Apply another round of hot shine and rub it in good with your hands (I were gloves). (6) Let dry. (7) Now you can apply as many coats of the Hot Shine as you feel is needed to get the look you want (usually 2 for me).
    If you spray the tires again every once in awhile you will keep that look forever.
    I just “restored” a set of 35 year old bias ply’s for a friend that sat out in the weather for years. They came out fantastic and my friend is thrilled and is going to use them, he was going to trash them (I don’t need advice about using 35 year old tires. I don’t own them and I’m not using them, my friend is. It’s just a “Cars and Coffee” kind of car and will never see speeds over 35 mph for a couple miles at a time.)
    I think that if you do this tire treatment you will be thrilled and even though it sounds like a lot of work you can do all 4 in less than an hour total. I have done several dozen tires this way and I use “Hot Shine” on all my vehicles (even the RV) it keeps them looking like new. The stuff is around 10 bucks and one bottle will last quite awhile. Forget about the dye, it’s a LOT of nasty work and it won’t last.
    Let me know how it goes.
    BigJoeArt, jet996 and Tow Truck Tom like this.
  7. ‘28 RPU
    ‘28 RPU
    PS, you may consider it “Greasy Lotion” at first but give it a couple days and it will dry really nice. If in the end you don’t like it you can remove it with Blue Dawn and the scrub brush (but you’ll love it)
    Tow Truck Tom likes this.
  8. Bandit Billy
    Bandit Billy
    Dupli-Color Tire black. Lasts for years
  9. JD Miller
    JD Miller
    Yep, that brown color is the L'Oreal Paris Triple Power Moisturizer that keeps the rubber from cracking.
    I use a water base wipe/spray tire dressing, hides the brown color... I leave the brown color alone. I dont try and scrub it off
  10. Choppedcoupe
    Choppedcoupe
    Photos added to original post. So just for clarification, Westly’s Bleach-White works on a non-white wall tire?
    Dan Hay likes this.
  11. alchemy
    alchemy
    I’d scrub them with a bristle brush and Comet first. Probably have some of that sitting under the kitchen sink.
    winduptoy likes this.
  12. ***Area-51***
    ***Area-51***
    from Ohio
  13. AccurateMike
    AccurateMike
    Yes. I don't own any whitewalls and I mount white letters in (until I get a check for advertising). Westley's is a good tire cleaner, works on the white parts too, (if you have them). Mike
    Outback and Tow Truck Tom like this.
  14. Choppedcoupe
    Choppedcoupe
    When I was little, my dad had something that was like a rubber STAIN, that the tire rubber seemed to absorb….it left no slimy film and was dry…must have had a solvent in it. He’s long gone and the knowledge with him.
  15. HOTRODPRIMER
    HOTRODPRIMER
    The browning is called blooming and is caused by antiozonants, chemicals that rise to the surface of the tire rubber to protect it from degradation due to ozone and UV exposure, get some Naptha at your local Ace Hardware or Home improvement center, put it on a rag and wipe the tires down the brown will disappear. HRP
    jet996, ***Area-51*** and hotrodA like this.
  16. Choppedcoupe
    Choppedcoupe
    That sounds right!-they are more brown with every minute they are in the sun! I’ll give that a try.
  17. hotrodA
    hotrodA
    When I was in the tire biz we had to put a plastic barrier underneath the bottom tire if they were barrel stacked, rather than racked. The new tires would leave a permanent brown ring even on epoxied floors!
    TrailerTrashToo likes this.
  18. 57Fury440
    57Fury440
    I have a set of BF Goodrich Radial TAs on an OT muscle car. It has the white letters showing. The larger tires in the back turned brown. The slightly smaller fronts did not. I spoke to a representative and the said the same thing that the brown is from the chemicals that keep them from cracking. They said I could send them back and they would send a new set. I did not want to go through the h***le. He said if I took some 360 sandpaper and wet sanded them that they would clean up. He was right and it worked.
  19. HOTRODNORSKIE
    HOTRODNORSKIE
    My Firestones did the same thing I could not scrub it out so I sprayed some flat black paint onto a rag and rubbed it into the tire worked good you could also use black shoe polish don't know if it will last though.
    GuyW likes this.
  20. Kiwi 4d
    Kiwi 4d
    I have Coker bias look radials on my avatar, they pee me off going brown. It’s covered in a shed. Simple green works well you can see the ugly brown just running off . If they say it’s oxidation, I don’t buy that , as to why all the tires on our daily don’t go brown .?
  21. 1971BB427
    1971BB427
    from Oregon
    Best thing I've found for cleaning that funky brown off tires is the same thing I use on my wheels! Maguires Wheel & Tire Cleaner. I spray it on my tires and wheels at every washing to keep my as cast wheels looking new, and my sidewalls looking new without using that gross tire shine ****. The tires after spraying get scrubbed with stiff bristle brush and I can see the solution turn brown as it cleans. It takes seconds to work, and a quick scrubbing and rinse has the tires and wheels both looking new.
    427 sleeper likes this.
  22. Choppedcoupe
    Choppedcoupe
    Bleche -white did pretty well, but I had to use a Scotch bright pad and probably went over each tire 4-5 times. The pie-crust edges were very tedious. I’ll look into that MacGuires cleaner next. But, Ive got black tires again. Thank you HAMB.
  23. A Boner
    A Boner
    IMG_6295.jpeg Get some “Totally Awesome” cleaner at the dollar store!
    It’s really totally awesome…ZERO shine.
    okiedokie and down-the-road like this.
  24. rockable
    rockable
    Diamondbacks......"Round not Brown". I gave up on Cokers after having 3 sets that bumped like hell at freeway speeds. An added bonus is the DB's don't turn brown and the whitewalls stay white.
    The 39 guy likes this.
  25. K13
    K13
    They certainly turn brown here and you can find endless information from tire retailers who have nothing to do with cl***ic car tires on why tires turn brown online so it is not unique to Coker.
  26. ct1932ford
    ct1932ford
    Once your tires are clean and dry use this regularly. This makes tires and anything else look great without the fake shine. upload_2025-8-28_13-53-44.png
    down-the-road and Blade58 like this.
  27. kabinenroller
    kabinenroller
  28. 1971BB427
    1971BB427
    from Oregon
    I use the Maguiar's tire protectant, but I don't spray it on my tires. I spray it on a rag and then rub it into the sidewalls. I just looks better and uses less protectant.
  29. Mark T
    Mark T
    I use this stuff on everything, it really is Awesome.
    It will give you a chemical peel if you get it on your hands, I now wear gloves when using it.
  30. chlsnk
    chlsnk
    I always clean my tires with a stiff nylon brush and some comet kitchen cleaning powder.
    alchemy likes this.
