ANGRY BIRD, THE TRI 5 T-BIRD HOT ROD...
Discussion in 'Off Topic Hot Rods & Customs' started by ALLDONE, Apr 23, 2025.
  1. ALLDONE
    ALLDONE
    my next move will be a closed cooling system...they do better when they can expand the coolant and **** it back in as it cools..
  2. deathrowdave
    deathrowdave
    from NKy
    I think switching the fan was a major help . You’re headed to ice land now !
  3. ALLDONE
    ALLDONE
    the fan was switched be fore I ever drove it... it was when I put the 4 core bigger radiator... and before the new motor...
  4. deathrowdave
    deathrowdave
    from NKy
    Have you checked vacuum advance operation ?
    ALLDONE and chryslerfan55 like this.
  5. deathrowdave
    deathrowdave
    from NKy
    I have same engine in my 32 , no overheating issues . You have way more radiator than in the 32 .
    pprather and chryslerfan55 like this.
  6. ALLDONE
    ALLDONE
    yes... back to zero light... all in 30 degrees.. new new pointless dist...
    the other thing...old style radiator you can 't fill to the top or they spit coolant... have to leave room for expansion..
  7. ALLDONE
    ALLDONE
    core is only 18 x 15
  8. ALLDONE
    ALLDONE
    but it is working very well for 120 degrees out..
  9. mustangsix
    mustangsix
    Any more progress on this?
  10. ALLDONE
    ALLDONE
    new motor and runs cool now... alot was the no ground on the gauges...the shroud helped a ton...
  11. ALLDONE
    ALLDONE
    as far as the car.... it's getting stripped right now to paint it black...
  12. mustangsix
    mustangsix
    Looking forward to seeing it!
  13. ALLDONE
    ALLDONE
    she's to bare metal naked right now..getting the metal work done, and should be in primer next week.... car had 7 paint jobs on it.so thick it cracked like bondo in spots.. no real body damage... a few pressure dents here and there..
  14. ALLDONE
    ALLDONE
  15. mustangsix
    mustangsix
    Good work! I hate doing paint and body.
    ALLDONE likes this.
  16. ALLDONE
    ALLDONE
    It's setting in first primer now...gotta get the 58 finish while it shrinks
    also wanna see if I can get salt flat wheels to fit....wheels are staying if I have swap rear ends..
  17. miker98038
    miker98038
    15x7 front, 3 1/2” backspace 225/60 15. 15x7 rear, 4 1/2” backspace. 235/60 15’zs. Really tight. Measure yours first, carefully. I had to move the rear over 1/4” in back to center it. Tight on upper front ball joint in front. No skirts. American Salt Flats
    ALLDONE likes this.
  18. ALLDONE
    ALLDONE
    thanks for the post.... I'm gonna have to take a tire off and see what would fit...I need to move the rear 1/4 also
