1935 Dodge Floating Power Speedometer 160 MPH REBUILT AND CALIBRATED Up for sale is a 1935 Dodge Floating Power speedometer that has been converted with a 160 MPH dial. The speedometer has been totally rebuilt and recalibrated, the dial has a 160 MPH vinyl overlay decal as the original dial paint was too far gone and did not do the rebuilt speedometer justice. The speedometer also has a new convex glass lens. This speedometer would be a fantastic addition to your hot rod build. The original dial had the MPH numbers and increments embossed (raised) into the metal so when the light is right, they can still be seen underneath the vinyl overlay if you look closely (full disclosure). Wanna see how cool it looks installed, here are two pic's of Speed~On's dash with the same speedometer, large and in charge. The hole size for the bezel will need to be roughly 6-1/2 inches and the speedometer is rear mounted and will need to be lighted externally. The speedometer fitting size id 3/4-20 inverted nut, I can make up a custom speedometer cable to your spec's, just need OAL and what transmission you are using. Free shipping to the lower 48 states PayPal friends and family
