1940 Ford Sedan Delivery Project
Discussion in 'Off Topic Hot Rods & Customs' started by rockable, Jun 13, 2025.
  1. lothiandon1940
    lothiandon1940
    WOW! Beautiful truck, beautiful work.
    lothianwilly71 and chevy57dude like this.
  2. rockable
    rockable
    I WAS going to use the ashtray vents that Oldair sells but they were UGLY. After researching, I found some Bob Drake vents that look much better, so I formed some patch panels to go into the square holes I had shaped for the Oldair vents and welded them in. A little hammer and dolly work later, I finally have the dash acceptable. This is a much better look. PXL_20250831_135345772.jpg PXL_20250831_135340624.jpg PXL_20250831_135334421.jpg
  3. rockable
    rockable
    PXL_20250903_201701168.jpg PXL_20250903_201647300.jpg We have power door locks, power windows, no vent window and bear jaw latches. A lot of work in these two doors. This is my first time using SPW power window kit and I like it. It would have been better to do it before painting but I managed to get it done without harming anything. I will paint the bare metal when I get back from Triple Crown.
    CruznArt, porkshop, Deutscher and 2 others like this.
  4. riv63
    riv63
    from Texas
    Very nice work.
    rockable likes this.
  5. rockable
    rockable
    PXL_20250910_203543637.jpg PXL_20250910_203324713.jpg This little 400 HP 350 small block Chevy should motivate the Sedan Delivery pretty well. Installed the Vintageair Front Runner system yesterday. I like the compactness and the clean design. Not gaudy like some that are on the market. It will be connected to a T5 5speed transmission with overdrive.
  6. rockable
    rockable
    Wow. I never dreamed installing the engine would be this hard. After taking 3 attempts today, my friend Richard and I decided on this approach for tomorrow.
    First, we will remove the radiator (which includes the Cooling Components fan and the Vintageair condenser) and then remove the front grill ***embly. Then, we will install the engine/transmission ***embly. After that, we will install the radiator ***embly and then the grill ***embly. Hopefully, there is room for all that. Wish me luck! Since I didn't mock up this car, I have no idea how all this stuff is going to fit but I know it's going to be tight.
  7. rockable
    rockable
    Well, we got the SBC and T5 nestled into place today. It is the tightest fit I have ever dealt with but removing the front grill was the hot lick. Despite that, it was still TIGHT. There is a lot of work yet to be done but this was the big hurdle I was dreading. I now know that my nice copper/br*** radiator and fan will clear my front runner system. There is 1/4" clearance between the firewall and the distributor. So, I will sleep easier tonight.
  8. rockable
    rockable
    I just love dressing engines. Polished the intake up a little and reinstalled it and the carb. Then, I stabbed the distributor in and decided to finish my spark plug wires. I saw the recent thread on spark plug wire routing for SBC's and decided to take a different tack this time. I routed the wires underneath and back to the distributor and I think it gives a really clean look. At some point, I need to repolish the valve covers but that can wait. The intake was a lot easier to do with it out of the car. Next step is routing all the battery cabling.
  9. okiedokie
    okiedokie
    from Ok
    Great workmanship, going to be a really cool 40. Glad I found your thread.
  10. rockable
    rockable
    I've been working on wiring and AC plumbing. I'm not pro when it comes to wiring but I'm pretty satisfied with the way this is turning out. It sure is tedious work. I can't imagine paying shop rate for a pro to do this. Expensive!!!
    PXL_20251018_155618029.jpg PXL_20251018_155611932.jpg PXL_20251017_175745017.jpg
  11. rockable
    rockable
    PXL_20251213_140947802.jpg PXL_20251213_140929439.jpg PXL_20251213_140805825.jpg PXL_20251213_140716903.jpg New shoes for the 40 Ford. It's coming along. Next up is some paint work and upholstery.
  12. wetskier2000
    wetskier2000
    from NH
    Wow!! What a beautiful piece. And you brought it home only 6 months ago and already have it this far along. Awesome...
    porkshop and rockable like this.
  13. rockable
    rockable
    It was already painted but no prep had been done for accessories like AC, taillights, dash, etc. This week I stripped the hood and dash for body work and repaint. Weather looks good next week, so fingers are crossed .
    Okie Pete and loudbang like this.
  14. BJR
    BJR
    "Well the floor is in and I am worn out from screwing for hours!"
    I haven't said that since I was in my 20's! :D
    Great looking car, and as usual you are doing a great job on it.
    SS327 and rockable like this.
  15. rockable
    rockable
    Made a cover to cover up the hole I had to cut to accommodate the shifter housing. This will make it easy on the upholsterer when making me a boot. BTW, he has the pattern done on the Glide seats and should start sewing cowhide this week. Also, my painter has all of my parts prepped and primed. Hoping for a warm day soon so he can paint.
    PXL_20251226_171322167.jpg PXL_20251226_171331112.jpg PXL_20251226_171313646.jpg
  16. rockable
    rockable
    Taillights turned out good, I think. What's your opinion?
    PXL_20260115_210229694.jpg PXL_20260115_205446275.jpg PXL_20260115_205428356.jpg PXL_20260115_205438893.jpg
    akoutlaw, loudbang and foolthrottle like this.
  17. rockable
    rockable
    ***embled the dash today with the backup camera monitor behind the speaker grill. I will put some self adhesive neoprene on the back side of the grill to black out the shiny stuff behind it.
