Hot Rods Door panel clip info needed
Discussion in 'The Hokey Ass Message Board' started by seabeecmc, Aug 31, 2025.
  1. seabeecmc
    seabeecmc
    I have this style door panel clips from the upholstery removed from my 1932 Ford.
    I made new panels and had them done in R&P. Now the original clips don't fit over the thicker panel. There are many wire clip options available by application, but panel thickness is not provided. Anyone got any help?
  2. Bandit Billy
    Bandit Billy
    I am not exactly sure what you have going on here, but I will have a go. These clips hold the door card to the door metal. The upholstery is glued to the door card. The clips, thus are unseen. The door card is made from thin, weatherproof material like fiber board, wood or plastics. Is that what you have going on?
    Just Gary likes this.
  3. seabeecmc
    seabeecmc
    Exactly. It's the "C" shaped part of the clip that won't accommodate the panel thickness. Ron
  4. dana barlow
    dana barlow
    from Miami Fla.
    I did a few panel replacement ,over the years.
    Most were custom,none used factory standard clip. Except when trying to fix windows or latch/lock things in my every day driver.
    The fail of stock clips,was most often do to factory panel {some type of card stock,had got wet an was falling-a-part}
    I like using stainless decorative washers and phillp screws with a little dome {the small bit of dome make then shine extra}.
    Placing these in planel so they also match the placement of panel next to it. { Make things look planed vs just anyplace }.
    Other tips that maybe helpful,I posted in one of my "How I did it".
    https://www.jalopyjournal.com/forum/threads/tech-sew-at-home-upholsrety-hot-rod.604077/
  5. jaracer
    jaracer
    There is supposed to be an elongated "D"shaped hole in the panel. The clip slips in the hole behind the upholstery and is unseen on the outside.
  6. ronzmtrwrx
    ronzmtrwrx
    Unless I’m missing something in your description, it shouldn’t matter what material is covering the board or card as some call it. There should be an oblong hole in the board and the clip should slide into that hole and rest at the end of the hole. Unless your panel board is just too thick and not allowing the clip to slide onto it, the thickness of your new material shouldn’t come into play. A picture of the back side of your panel would help.
    Fortunateson likes this.
  7. abe lugo
    abe lugo
    On the inside of the door card trim around the fabric if it's layered and too close to the hole. Hope fully you just traced of the old holes on your old door card.
    seabeecmc likes this.
  8. seabeecmc
    seabeecmc
    The original panel (card) is approximately .1060 the new panel is approximately .1180. I'm looking for a clip to fit the thicker panel size. Ron
  9. tomcat11
    tomcat11
    51 mercules likes this.
  10. oldolds
    oldolds
    If you can wait a couple weeks and go to Carlisle or Hershey, Restoration Specialties is usually there. They should be able to help you out. Or you could call. 814-467-9842. They are usually good on the phone, but it is coming up on show season.
  11. K13
    K13
    Go to any autobody supply store. They all usually carry them and have cards with examples of all that is available.
  12. 325w
    325w
    Stainless trim washer screws. Two should be plenty on sides since the window trim holds the top.The rubber weather strip on the bottom may require use four. Thicker panel may need the padding removed along the window trim.
  13. woodiewagon46
    woodiewagon46
    from New York
    Jeff Norwell likes this.
  14. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Yes.Restoration Specialties is my go too..Matt is very helpful and good.
  15. seabeecmc
    seabeecmc
    Found them. Thanks for all the help. Ron
    Trim Clip Fasteners Auveco 2310 For the .125 Chrysler Dodge Plymouth Thicker Panel
    RICH B and TagMan like this.
  16. HOTRODPRIMER
    HOTRODPRIMER
    Check with a local paint & body supply house, in my area they carry they a huge supply of clips and accessories for different body types, the original '32 door clips I had kept were not big enough for the new door cards, the replacements look the same but were larger, if you go this way take one of yours for comparison. HRP
    ClayMart and seabeecmc like this.
  17. jimmy six
    jimmy six
    Same as the ones on our 56 Ford. 99% of all upholstery shops and suppliers can get them.
  18. i.rant
    i.rant
    Those and others are available from Autozone also.
  19. tim troutman
    tim troutman
    ford used that style door panel clips for years in the 50s 60s 70s ebay has them for less than $1 each maybe you could slightly bend them to fit a thicker panel
  20. seabeecmc
    seabeecmc
    Got it. Ron doose4.jpg doose5.jpg Trim Clip Fasteners Auveco 2310 For the .125 Chrysler Dodge Plymouth Thicker Panel
  21. mr.chevrolet
    mr.chevrolet
    maybe some of these might help? TCHHH.jpg TCIII.jpg TCJJJ.jpg TCLLL.jpg TCMMM.jpg TCNNN.jpg TCOOO.jpg TCPPP.jpg TCQQQ.jpg TCRRR.jpg TCSSS.jpg TCTTT.jpg TCUUU.jpg TCVVV.jpg TCZZZ.jpg
  22. redroaddog
    redroaddog
    If the new panel is abs cut your holes then thin it with a grinder or sander
    seabeecmc and Algoma56 like this.
  23. seabeecmc
    seabeecmc
    Being tipped to the absolutely correct Auveco 2310 panel clips was the perfect answer to my issue. Thanks All, Ron
  24. woodiewagon46
    woodiewagon46
    from New York
    I just picked up the new Restoration Specialties and Supply catalog at HERSHEY last week and it is even bigger than the last one. There isn't a clip that you can need that they don't have.
