Projects Chevrolet 1954 210 mild kustom
Discussion in 'Traditional Customs' started by Acres, Jan 6, 2022.
  1. engine138
    engine138
    from Commack NY
    I made something similar with exhaust pipe cut in half and welded 2 ends on works perfectly
  2. 325w
    325w
    54 I had we tied a rope to the hood ornament. Ran it over the roof to the rear bumper over rider. Pulled hard and tied it off. Held the hood back so I could change engine an trans without removing the hood.
    Acres likes this.
  3. Mike_B
    Mike_B
    Just wanted to add that the Performer EPS manifold should not cause you any throttle response problems, unless there's a vacuum leak somewhere. It's simply an updated version of their popular Performer low-rise manifold.
    Acres likes this.
  4. Acres
    Acres
    from Sweden
    New mufflers for the Chevy, its so quiet right now, I like to atleast hear the V8
    Okie Pete, Squablow and 54delray like this.
  5. Acres
    Acres
    from Sweden
    Long time no update, been busy driving.
    The Smithys mufflers turned out to be a disapointment, the Chevy sounded almost as quiet as my old mufflers, after 2 weeks i removed them and went for a cl***ic noisy muffler, 18 inch Cherry bombs, im quite pleased how they sounds, still quiet when going down the road, I could probably go straight pipes on this engine but som people out there doesnt like that....
    The isolation i did on the floor did make a real difference on the exhaust/road sound, to really hear the V8 i have to roll down the windows.
    Listen to that V8 really puts a smile on my face
  6. Kaptain Kustom
    Kaptain Kustom
    from Finland
    Nice car!
    I made this kind of hood spring removal/***emling tool:
    https://chevy.oldcarmanualproject.com/miscellaneous/hoodspring.htm
    There's also a video about using it in the link. IIRC it was better to make it a little of the long side for my 1950. Tool worked well, but it's still a freightening job, and the geometry of my jack was not the best working with the springs. I worked with the fenders off, so can't say how it would work with them on.
    Acres likes this.
  7. Acres
    Acres
    from Sweden
    After the whole front suspension were rebuilt (last pieces this spring) the Chevy started eating tires really bad, I guess the really sloppy frontend compensated pretty good.
    After some checkup it turned out someting also were bent, couldn't aligne right side into spec, changed lower control arm and after a real alignment it turned out pretty good, before the car dragged pretty hard too the right, now you can let go of the steeringwheel and the car just run straight, im so pleased, also after driving around for a while i cant see any abnormal tire wear.
    It were time for a tire change, been lookin forward too this since i bought the car, really need some whitewalls.
    First choice would have been cl***ic Firestone www but with all alignment problems and the cost of these tires i realised its wiser with radials, I know boring but they look ok i think, but you cant compare them too Firestones
  8. You know if you were to put the heads off the 267 on the 283 the 283 would probably be a lot happier
  9. Also good to see another 53/54 Chevy on here. Somehow missed this till today
    Acres and 54delray like this.
  10. Acres
    Acres
    from Sweden
    That engine had some serious issues, after re***emble it i discovered, really bad scoring on crank wich had destroyed the bearings, piston clearence were like 3 times as it should have been, rings were badly worn, timing chain were slack, the cam had gone flat on one of the lobes.
    So it needs a full rebuild to be uasable again
    The heads were the only uasable, but they were on wrong engine.
    Okie Pete and Squablow like this.
  11. kustomkat1950
    kustomkat1950
    from Coastal GA
    Damn clean car. digging it man..
    54delray and Acres like this.
  12. Squablow
    Squablow
    Great car, the new tires look great.
  13. Moriarity
    Moriarity
    SUPER MODERATOR
    Yup, the wide whites really woke it up, good call, great lookin car man
    54delray, lurker mick and Acres like this.
  14. Acres
    Acres
    from Sweden
    Long time since any update, have had issues with a leaking heater core, went to my local radiator shop and had it rebuilt, they also change the angle on one of the pipes, now I dont need a hose with a 90' angle
    Before and after photo
    Squablow, 54delray and guthriesmith like this.
  15. Acres
    Acres
    from Sweden
    Also painted the heater box
  16. Acres
    Acres
    from Sweden
    Finally got a replacement lens for the cracked speedometer 20240807_231705 (1).jpg 20250831_152752.jpg
