Event Coverage LLOYDFEST III.... SEPTEMBER 5TH-7TH 2025
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jan 6, 2025.
  1. High test 63
    High test 63
    Man! The time and money we put into these things, just to get bit in the *** AGAIN! Damn junk!
  2. I don't remember what it was. Jamie the machinist told me, but it's been a couple of years. It didn't have any affect on the erson cam, it was a much smaller profile. I ordered a 236@ .050, 472 lift. Roll the dice again. It'll work out, sooner or later lmao! I foresee me switching to LS engines soon
  3. I did everything perfect this time! Lol... but it'll be alright. **** will be in on Wednesday, gonna have the car hauled out to the shop tmrw or Wednesday morning. Can't really break a cam in here in my yard... neighbors :rolleyes::D
  4. chevy57dude
    chevy57dude
  5. That's my initials though, it must be trying to tell me something :D
  6. Oh The Humanity!!! Oh, wait, LS as in LS-5, LS-6, LS-7, that would be ok.
  7. chevy57dude
    chevy57dude
    Andy is right, and LS-6 would do!
  8. Cosmo49
    Cosmo49
    I have an Advance Design Front Bumper to sell for reasonable offer (whatever that is). Good condition, in primer. If I don't hear from anyone I won't bring it as I'm travelling and camping in a small ot wagon.
  9. Moriarity
    Moriarity
    SUPER MODERATOR
    man… so let me ask, is this the milder cam you put in just before Bowling Green? I don’t have a ton of recent camshaft experience but when I put one in my chevelle a few years back I used an isky cam. I figured that a company that was something like 75 years old wouldn’t dare jeopardize their reputation by selling junk….
  10. No, that was an erson. The first cam was a Howard's, it ate a lifter, put the erson in it and all was good, but i wanted the Howard's profile back in it. Bad idea I guess lol.
  11. Moriarity
    Moriarity
    SUPER MODERATOR
    wasn’t it faster or seemed more powerful with the milder erson cam?
    chryslerfan55, enloe and Sharpone like this.
  12. Sharpone
    Sharpone
    That ****s man. 0.472 lift isn’t crazy shouldn’t be eating lifters. How much lift can you go before you reach coil bind?
    I agree with Mark about Isky cam and lifters, Crower sells a cam saver lifter made by Johnson. A little more$$$s but I think you get good ****. Didn’t Comp buy Luaniti ? Comp cams used to be great, don’t know what happened but a lot of people cuss them now a days.
    Dan
  13. The Edelbrock Group owns Lunati now. I believe they have Comp as well.
    chryslerfan55, enloe, SS327 and 2 others like this.
  14. No. Just moved the power range down. Sounded like ****.
  15. 472 lift is the cam that's coming Wednesday. This cam was 507 lift. Coil bind is over 550.
  16. tomcat11
    tomcat11
    Sorry this happened to you again Big Daddy. These days we have to be checking the lifter faces for the proper crown and the cams for proper lobe taper. This is easy to do. Even the top brand name lifters have proven to be ****. Including the cam saver ****. The geometry has to be right and is critical. Break in your cams with just the outer springs. Too much spring pressure on break in is a killer. Check for coil bind and retainer interference too. Pretty damn sure Howards cams are not the problem here. Probably just the re-boxed lifters. We need to stop pretending everything should be good because it's not!:D
  17. can you explain what keeps spring pressure from destroying the lifter and lobe after you go through the process of pulling springs, break in, and reinstalling springs?
  18. my mother said to ask what to bring for food, charcoal/propane for fuel, etc... because it skipped my mind on what exactly to bring.
    since we are closing in on the last week!
  19. Everything is provided while you’re at the park. Hamburgers, hotdogs, chips, drinks, etc.
  20. John B
    John B
    As you left the Drive-In Theater last night one of the guys who was standing near us said it sounded like you had a flat lobe. Guess he wasn't too far off.
  21. 427 sleeper
    427 sleeper
    Plenty of good oil on the lobes. Personally, I won't use a standard flat tappet lifter anymore. Everything gets lifters with the oiling holes on the bottom.
  22. 3 of em.
  23. But do you get what I'm saying? If the lifters can't handle a certain seat pressure, nothing is gonna change that. Thought about switching to beehive springs.
  24. Same with the springs on the Blue Print heads I bought.
    I have that same cam & lifters (already in the car when I got it). When I pulled the tunnel ram to change the heads, one of the lifters was missing a piddle valve retaining clip, probably not an issue as long as the pushrod was holding the valve in place, but you gotta wonder did the forget to put it in or did it come out.
    Have to thank Dad for being a packrat/hoarder. There is at least one coffee can with a couple dozen GM factory lifters from the 70's upstairs that mostly have a couple hundred miles or less on them. Back then if a pickup was still in warrantee & the engine had a problem they just threw a Targetmaster in it & Dad would bring home the whole engine or at least a lot of the parts.
    So many folks are having these issues with lifters in the last decade+ that I am not sure if I wouldn't just put a roller in anything I build going forward.
    God Bless
    Bill
    https://www.jalopyjournal.com/forum...ar-transport-hauling-open-or-enclosed.614419/
  25. I was pissed off and going through summits selection of retro roller cams lol. $1300 average, then I needed a compatible timing cover with a wear plate, a cam ****on, a fuel pump pushrod, a compatible gear for my distributor...... I decided I'd go with a smaller profile. Hot rodding is fun..... and cheap!
  26. tomcat11
    tomcat11
    Well, the way I understand it, before break in the lifter faces and cam lobes are not perfectly matched. The extreme pressure loading can be distributed over a reduced and/or uneven surface area. The oil and its anti wear additives along with their ability to withstand a given amount of extreme pressure loading are your only protection against failure during the break in process. After break in (wear in) the surfaces are more perfectly matched and the extreme pressure loading is distributed more evenly and across the maximum (i.e. greater) available area. The increased area is then able to withstand more load from the additional spring pressure as long as it is not excessive. The geometry greatly affects the available load carrying area. Even the size of the chamfer on a lifter face can affect the load carrying capability.
    That was a mouth full. Now where's my beer:eek:
  27. What's your opinion on initial lubrication on the lobes & lifter faces? Do you agree that there has to be a certain amount of friction between the 2 surfaces to accomplish the rotation of the lifter? You'd think that with all of the zinc and phosphorus and oil on the mating surfaces, along with fire up and 2500rpm, that you'd promote slippage, and premature wear on those surfaces. Seems that you would want a certain amount of drag to ensure surface mating. My head hurts from thinking about it lol...
  28. I'll say this, I ordered a tube of moroso moly lube. I'm going back old school, the way i did it for years. And I'll admit that I didn't check these lifters on gl***. That's my fault.
  29. good! was just making sure for logistics sake.
