Projects 1950 Ford Business Coupe build
Discussion in 'Traditional Customs' started by SinisterSleds, Apr 29, 2025.
  1. Rand Man
    Rand Man
    I think it’s gonna turn out great.
  2. SinisterSleds
    SinisterSleds
    from MA
    Yes. Been around it but not really done it. I missed on one of the pleats so 2 are off (one narrow and one wide that taper) but was able to hide the mistake around the front. My top s***ch is a little off. I wish I had shrunk the pattern (existing seat cover cut apart) by 1/2" rather than adding 1/2". I will adjust the patterns for the seat backs when I make those.
  3. SinisterSleds
    SinisterSleds
    from MA
    Thanks
    ffr1222k and Rand Man like this.
  4. warhorseracing
    warhorseracing
    from cameron wv
    Where?:confused: As long as you can see it. Looks great from my porch.
    ffr1222k likes this.
  5. SinisterSleds
    SinisterSleds
    from MA
    Left of center 1st and second pleats. It's a curse, I'm very critical of my own work, never happy and only see the imperfections.
  6. warhorseracing
    warhorseracing
    from cameron wv
    As you should be.;) As long as you know. It is hard to see until you point it out.:( Nevertheless, once installed in the car and some one sitting on it while cruising.:cool: Who will ever know besides you? :rolleyes:
    SinisterSleds and Deutscher like this.
  7. SinisterSleds
    SinisterSleds
    from MA
    That and im limited on $ and the amount of materials I have on hand. Using the remainder of a bolt of vinyl. Hopefully will be able to get the seat + out of it. I will probably have to order more.
    warhorseracing and Kelly Burns like this.
  8. SinisterSleds
    SinisterSleds
    from MA
    Shrinkage...
  9. Rand Man
    Rand Man
    Yeah, that’s odd. I am using that same material for my door panels and I did not have that problem.
  10. Rand Man
    Rand Man
    Actually, let’s see a picture of that panel on the bottom. Rather than shrinkage, that one might be stretched. Those seams are supposed to be heat-sealed and it looks like those pleats are much wider than they’re supposed to be.
    SinisterSleds likes this.
  11. SinisterSleds
    SinisterSleds
    from MA
    Those are the before and after pleading. Each pleats eats up a bunch of material. I have some of that heat pressed stuff, far from the look I'm after. 20250903_140938.jpg
    I really want the depth and the visual appearance of the dark line formed by the folded pleats. I believe this to be key to pulling off the white interior w/o being overpowering or adding a contrasting color.
  12. SinisterSleds
    SinisterSleds
    from MA
    Piece below is layout prior to s***ching.
    Grey lines will be my top s***ch followed by the fold and 2nd s***ch. 175692363727355803424601371920.jpg
  13. Rand Man
    Rand Man
    My mistake. I thought I saw part of that as the heat sealed. You are doing it the right way. I only used that stuff for cost.
  14. brading
    brading
    Just read right through this thread and can see when finished this is going to be a very nice car. ;)
  15. SinisterSleds
    SinisterSleds
    from MA
    Thanks
  16. SinisterSleds
    SinisterSleds
    from MA
    Thanks. I hope so.
    210superair likes this.
  17. SinisterSleds
    SinisterSleds
    from MA
    An hr or 2 a day can make a big difference. In this case I spent about 3 hrs (2 this AM before work and took a 1hr lunch)
    Pushed along the driver's side seat back.
    I have to put a flap on the bottom tomorrow AM and I should be able to install it. Im pretty happy. Narrowed all the patterns by 1/2" all the way around to make up for the additional stretch of this vinyl vs original cloth. 20250904_191341.jpg Happy with the pleat alignment back to bottom. Wrinkles should come out with a little steam or when the cover is stretched tight.
    Oh! And it's really comfortable.
  18. SinisterSleds
    SinisterSleds
    from MA
    Left side installed. Im a little disappointed with the slight inboard taper of the back pleats. I will lay out the next seat back a little differently and hope to correct that issue.
  19. warhorseracing
    warhorseracing
    from cameron wv
    It does appear that way, but it may be an optical illusion. Mockup the other side and see if it looks worse or better.
    guthriesmith likes this.
  20. SinisterSleds
    SinisterSleds
    from MA
    I wish it were. I'll survive. LOL
    I adjusted on the other side. Hopefully it will come out better. It's a learning process. As long as i can identify the problem and adjust the process it will be fine. It may just be the way the cover stretches over the old frame and stuffing.
  21. leon bee
    leon bee
    Damn, looks good from here.
  22. SinisterSleds
    SinisterSleds
    from MA
    Thanks. To quote my neighbor "I've seen people pay for worse!" LOL
  23. SinisterSleds
    SinisterSleds
    from MA
  24. pprather
    pprather
    Awesome seat recover.
    I'd cruise in that!
    210superair and SinisterSleds like this.
  25. Nobody is going to notice the little pleat difference at 60 Miles Per Hour, and your **** won't feel it either.
  26. SinisterSleds
    SinisterSleds
    from MA
    Thanks. Hopefully next year it will make it on the road.
    Agreed. Most of the problems are small and only noticeable because im looking for flaws and the seat is all you are looking at. Once installed most flaws could never be seen.
    One of my 2 upholstery guys looked at it yesterday and gave me some tips.
    Have another guy who will Hopefully come by this week.
  27. warhorseracing
    warhorseracing
    from cameron wv
    If someone wants to pick on it. They need to go pound $alt you know where. It looks great.
  28. When out at events and I see someone pointing and picking at something even if it's not mine I sorta act like it is and say, "so let's go look at yours now". That usually generates a different conversation.
  29. TrailerTrashToo
    TrailerTrashToo
    About 45 years ago, our local car club had a parking lot car show. Just an informal Saturday gathering. Two guys in their late 20's were loudly picking apart almost everything.
    They then climbed into a sun faded Mercury Comet - the headliner was torn and partially obscuring the rear window - and drove off trailing oil smoke.
  30. laidbackluis
    laidbackluis
    from Sachse Tx
