Technical 32 axle under model A ?’s
Discussion in 'The Hokey Ass Message Board' started by olskool34, Aug 29, 2025.
  1. olskool34
    olskool34
    I know a lot of you have done this and I have always wanted to and recently I acquired a complete 32 axle, perch pins, and spindles to go under my ‘29 roadster. My stock A kingpins were perfect in the 32 spindles, no movement, no nothing. Can I run the stock Model A brake actuators or do I need the 32-34 style? IMG_1755.jpeg IMG_1756.jpeg IMG_1757.jpeg
  2. Pete Eastwood
    Pete Eastwood
    from california
    Get yourself a set of 32/34 front brakes to run with the 32 axle & spindles.
    They are a bigger & better brake than the model A's and it's a bolt on!
  3. 62pan
    62pan
    Use the A actuators if your keeping the mechanical brakes. You will also need a spacer for the wishbone as the 32 axle is 1/4 inch thinner. If you go with 32 brakes you still use the A actuators.
  4. olskool34
    olskool34
    Thanks. I did put a 1/4 spacer on the bottom. The reason I am asking is the area on the 32 perch pins where the actuator bolts on is almost twice as thick as the A perch pins.
  5. Deutscher
    Deutscher
    from Germany
    The brake actuator of the Model A allows the brake rods to run parallel to the frame and thus fit better, the 32-34 run under the frame to the middle.
    I just built the same.
    Greetings Harald
    51 mercules and jet996 like this.
  6. You will find that the '32 axle is thinner than the A. You will need a spacer to fit the wishbone.
  7. Hitchhiker
    Hitchhiker
    I got 32 front brakes if yoy want to upgrade
  8. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    If you do 32 front brakes make sure you have the actuator rod that goes through the kingpin for a 32 as well, the Model A is too short.
    While you are in there, add the floaters to the front wedges, this makes a Nice difference!
    Deutscher and 62pan like this.
  9. olskool34
    olskool34
    This is the one area that I am a little confused by. The boss on the 32 perch pin where the actuator bolts is nearly twice as thick as the A perch pin. The actuator when mounted is on a slight angle. Do you guys shave the boss down to match the A? IMG_1786.jpeg IMG_1787.jpeg
  10. olskool34
    olskool34
    Anybody have any idea as the thickness of the perch pin bosses that hold the actuator? Did you guys just run them as is?
  11. 62pan
    62pan
    When I did this, all the threads I read or followed I never saw any mention of thinning the actuator or perch pin mount. If you loosen the perch pin and then mount the actuator it should turn enough fit flush without a slight gap.
