Technical Buying Fiberglass Bodies and Chassis from Different Companies
Discussion in 'The Hokey Ass Message Board' started by Kansas Gary, Nov 11, 2024.
  1. 325w
    325w
    RJs builds a nice frame package.
    bchctybob likes this.
  2. flynbrian48
    flynbrian48
    I'm not sure that argument holds up. I've built three 'gl*** bodied roadsters, my current one is a '29 on '32 rails, built a beautiful '34 fender-less car and a full fender '27. The buy in is SO much less to build a 'gl*** car, I can't afford $25-to $50K for a bare steel body, then spend hundreds or thousands of hours to restore it (or pay someone else) and then have to double or triple that to build a complete car. I'm not going to be specific, but I've done VERY well when the time came so part them. This is supposed to be a fun hobby, it's expensive either way, but... I simply can't afford to spend over $100K on a car that might be worth half that when completed, I'd rather spend my money on a car that I can recoup the investment on, have fun while doing it and not put us in financial jeopardy doing so.
    GuyW, bchctybob, 57Fury440 and 9 others like this.
  3. 05snopro440
    05snopro440
    That Vicky looks like a deal, but he already said it's not what he wants. He said he wants a 3W coupe as his retirement project, so building a Vicky because it's a deal makes zero sense because it's a compromise on what he wanted.
    lake_harley, X-cpe, mad mikey and 2 others like this.
  4. 05snopro440
    05snopro440
    What you'll find with new parts for hot rods is that they almost all require some amount of modification to work as intended. You'll be amazed and pleased when you find some that just fit together without issue.
    There are a lot of us here that have cars that aren't fully traditional or traditional at all. You can still learn things and go your own way with your build. Try it and see what you think. Glad to have you!
    bchctybob and Kansas Gary like this.
  5. RodStRace
    RodStRace
    I would also suggest that you hang around. There are builds here that can be a guide, and this place has a knowledge base second to none. You can look at other places too. Knowledge is power, so arm yourself!
    I'll also mention that while buying brand new is great and supporting the places like P&J helps the whole hobby, getting a stalled project or completed car close to your desired result can save enough to make it affordable. The first step is to define what your final vision is, and then select and price out all the parts. Make sure they will all work with each other and be a cohesive whole. Make a napkin drawing or an excel spreadsheet, but have a fairly complete and researched plan.
    Body, ch***is, drivetrain, electrical, cooling, interior, exterior, accessories, wheels, tires, exhaust, controls.
    This one can be a very strong guide to the build process and choices made to fit HAMB era, but also show what is required to put one together.
    https://www.jalopyjournal.com/forum/threads/gl***-32-5-window.1049484/
    Here's a 34, but all the pics are gone.:(
    https://www.jalopyjournal.com/forum/threads/my-gl***-34-tudor-build.647514/
    bchctybob and BJR like this.
  6. Bandit Billy
    Bandit Billy
    @Kansas Gary, HAMB members can forgive anything (other than being a Chiefs fan) you just have to build your car in the right forum. Heck, I have a Toyota 4x4 thread and one for my 442 on the off topic site.
    You can also just learn to edit your photos and not talk about the off topic stuff like IFS, EFI, LS, MII, AC, PW, GPS, ***, (that last one wasn't an acronym). Who knows, the power of the HAMB may have you second guessing your build preference before long. Peer pressure is a wonderful thing at times.
    Go with your gl*** body, if it is fenderless (funny, my computer changed that to "genderless", sign of the times) don't run IFS (IMO). If you are running a full hood, who cares what power train it is. Coil overs are fine as long as they aren't hanging out the *** end. Above all, try to be original and not just knock off someone else's ride. As the saying goes, "it's been done".
    There is a coolness to what we build. No, they are not all "traditionally compliant," I skirt the edges but I build what I want and I like what I build. But I don't insult the HAMB by parading a street rod or rat rod on these hallowed pages of hotroddum. You'll catch on...if you stay.
    I had the frame for my 34 Ford built locally (Troutdale, OR) by Daryl Schroeder. So Cal front end, Winters QC, quarter ellipticals. He does excellent work.
  7. DDDenny
    If you have the skills to screw a car together, getting the body to ch***is mounting locations to match up is not a big deal no matter what combination you choose, fibergl*** is pretty forgiving.
    My Wescott body is as good as they come for being dimensionally (and visually) correct, my ch***is was also built by a pro ch***is builder but a few holes in the fibergl*** floor needed a little love with a rotary burr in a die grinder.
    Whether you choose a steel or a gl*** body you will need to "make it your own".
  8. DDDenny
    Go Chiefs!
    blue 49, Tim, okiedokie and 4 others like this.
  9. 19Eddy30
    19Eddy30
    from VA
    I even had a Toyota engine in a steel 32 ,Plain to put back in ,
    Native
  10. twenty8
    twenty8
    Oh man..... NICE!!! Nothing better than some good ch***is ****....:D
    Bandit Billy likes this.
  11. A Boner
    A Boner
    Stick around…build it as traditional as you can…skip the fad/modern stuff, and the resale will definitely be better…timeless, doesn't go out of style!
    bchctybob and Bandit Billy like this.
  12. Bandit Billy
    Bandit Billy
    What the ? I think those SBC's has tainted your mind Dougl***!
  13. blazedogs
    blazedogs
    Check with your state what all will be involved on ***led & registering it... Ask me how I know here in Minnesota Was a nightmare Gene in Mn
  14. DDDenny
    Yup 24/7!
  15. Johnny99
    Johnny99
    https://www.jalopyjournal.com/forum...e-32-34-ford-fibergl***-cars-any-pics.988012/
    Take a look at this thread. Wescott out of Oregon are about the nicest gl*** bodies I've seen; don't think they do a 33/34? But they do a 32 three window. Bad Bob does not hang out here much anymore, a friend of his built a really nice traditional style gl*** 33/34 coupe, there was a thread on the car several years ago, I cannot recall the name of the thread maybe someone else can? Splitbudaba has a build thread going he's building a great looking gl*** 32 five window. My 2 cents on gl*** bodies, avoid hidden hinges and glued in windshield. Good luck and have fun!
    BJR likes this.
  16. Kansas Gary
    Kansas Gary
    I've researched the laws here in Kansas and am told they are a builder friendly state. They say the key here is photos, do***entation and receipts for as many components as possible. Might not be that easy in real life, but appears to be doable.
    ~Gary
  17. Kansas Gary
    Kansas Gary
    Hello all, just a quick update on my '34 Coupe project. After considering the many comments here and lots of further soul searching, I decided to build much more traditional looking car. It will still be gl*** and have a narrowed 9" and steamroller tires, but now with a dropped drilled I-beam axle, door handles, working cowl vent and crank down rear window.
    I went to Pete & Jakes last week to see my ch***is build underway in the jig and dropped off a core 390/C6 for them to mock up the mounts. When the rolling ch***is is finished in a couple of weeks, it will go to Show Me Rod and Custom for the body to be built on the ch***is. The 390 will stay installed during that in case any mods need to happen to the firewall/trans tunnel. Very happy to know that when I get it home my 428 should slide right in.
    Thanks for all the encouragement!
  18. RodStRace
    RodStRace
    Since you are a paying customer, pick the builder's brains for suggestions and warnings about all the details you will be adding. I'd imagine they will ask a few questions and give you info based on your vision and their experience.
    An old story is to pay an attorney for a half hour of their time and ask for help. Most of them once they get going can't stop, so you get your money's worth!:D
  19. Kansas Gary
    Kansas Gary
    You are absolutely right! I've had many phone calls with both builders over the last nine months and even the seemingly simple questions have turned into ~45 minute discussions. Both of them (Jason Slover and Tony Curry) have been extremely helpful. They both have 30+ years in the hot rod world and provide great guidance without pressuring me to do it "their" way.
    bchctybob and RodStRace like this.
  20. brigrat
    brigrat
    from Wa.St.
    Chiefs are woke!
  21. 31Apickup
    31Apickup
    You went the best route, having the body built on your ch***is. Should be quite a handful with a 428!
  22. flamedabone
    flamedabone
    Glad you ae on a better path. I have never dealt with the Show Me guys, but I know the Pete and Jakes crew are fantastic. Good choice on the FE, they are a bit on the heavy side, but can make plenty of power and look *****n with some extra carbs and cool valve covers. It's not too late to throw a third pedal in there....
    -Abone.
  23. pprather
    pprather
    You've learned well in a short time.
    Splitbudaba likes this.
  24. SPEC
    SPEC
    Buy everything from Pete & Jakes and everything will be quality parts!!!!
    MMM1693 and Splitbudaba like this.
  25. ronzmtrwrx
    ronzmtrwrx
    Pete n Jakes = Good people
  26. Splitbudaba
    Splitbudaba
    I am finishing the build stage on my coupe. I bought a 32 5 w kit from a company R&R Fibergl***. I went with these guys mainly because they hand laminated every piece including the body. What that meant is a uniform thickness even in the corners. That way I could bond in all the UPAC interior structure steel and wood. Worked great. Check out my build here. Gl*** '32 5 Window. I think I bought a bare perimeter frame from Blackboard. SoCal, Speedway, and Summit loved me for about 5 years!!
    PXL_20230916_211057257.jpg PXL_20231019_205458640.jpg PXL_20250713_031735858.jpg PXL_20240409_012345591.jpg
    verno30, Bandit Billy, X-cpe and 2 others like this.
  27. Kansas Gary
    Kansas Gary
    Abone,
    I was originally going to go with a factory 3x2 setup and 4 speed that I've have had for many decades, but to be more streetable, I've decided to go with an 8 Stack EFI and a C6. I was also going to run my chrome "powered by ford valve" covers but they are a bit pitted, and I think these polished 428 American Eagle valve covers would be a better look with the aluminum heads and the polished 8 Stack intake.
    I cracked up about your "third pedal" comment. I had such a hard time deciding that I'm having P&Js install the clutch master cylinder bracket and a bushing to replace the clutch pedal. Just in case I decide to swap the top loader in someday! Nothing like the sound of a 4 speed going through the gears!
  28. RAK
    RAK
    I recommend you give the fat rear tires a second thought. I have a close friend that pro-streeted his 40 Pontiac coupe and ran into a whopper T-storm returning from an event in Florida, hydro-planed and did a 360 totally out of control, luckily without hitting anything. After changing his drawers, he slowly and carefully drove home but didn't drive the car again until he had removed the pro-street rear suspension and put in a normal one.
  29. 19Eddy30
    19Eddy30
    from VA
    X2 With big tires , when unexpectedly
    Rain , run into water like 1/2 , will hydro fast
  30. Bandit Billy
    Bandit Billy
    Never seen the patches on your seat covers before, nice! You gained a few more points.
    Not just fatties but treadless tires as well. If you might get 'em wet, chose your rubber carefully. I got caught twice in the rain this last weekend at the beach far from home in my roadster. Might as well have been black ice. I didn't wreck the car (or my shorts) but it weren't fun.
    RAK and Splitbudaba like this.
