Technical Oddball Fuel line fitting source?
Discussion in 'The Hokey Ass Message Board' started by justpassinthru, Sep 4, 2025.
  1. justpassinthru
    justpassinthru
    Any recommendations for a source.
    Trying to find a straight internal female flare fuel line fitting for 5/16" steel hard line.
    (1/2-20 tube nut size) to 3/8 NPT. To plumb in a Holley type fuel pressure regulator.
    For a 57 J2 Olds factory Tripower that has too much fuel pressure.
    Only thing I can find so far, is a fitting for 1/4 NPT. Don't want to have to use a bushing reducer if at all possible.
    Getting too bulky for the space to fit the regulator.
    Have looked at all the normal sources of catalogs from Dorman, Edelman/Plews, Gardner/Wescott etc. and no luck so far. Sources like Auto parts, Summit, Jegs, Speedway, Grainger, McMaster-Carr etc, no luck.
    Not sure that fitting even exists?
    You guys have any ideas?
    Bill
  2. 19Eddy30
    19Eddy30
    from VA
    @justp***inthru
    Aerospace/ Aviation parts manufacturers, Some European .
    Parker
    Aeroquip
    Pluming in Industrial Beverages
    many of these companies have several specific different catalogs ,
    also Earls or Russel has a special fitting catalog that's not common seen ,
    & Vibrant has some unique fittings also
    Catalog Not there web site .
  3. FrozenMerc
    FrozenMerc
    Bring in the pieces to your nearest Parker Store (there should be a bunch ****tered through out the Chicago Land area). They will be able to put together what you need.
  4. squirrel
    A "face bushing" doesn't really add any length to the fitting, give it a try
    notice that they have them at Ace Hardware...
    ClutchDumpinDan and warbird1 like this.
  5. www.polyhose.com. I ordered some odd ball brake line fittings that nobody had through them last year. They have all kinds of automotive type fittings
  6. 2OLD2FAST
    2OLD2FAST
    from illinois
  7. lake_harley
    lake_harley
    I would agree on the earlier suggestion of aeroquip, earls, russell, or xrp or possible sources
    Lynn
  8. 19Eddy30
    19Eddy30
    from VA
    All so having sets of NPT tap / die you can sneak up on deeper depths to make
    Fitting shorter , more Flush
    Adriatic Machine and squirrel like this.
  9. 57tailgater
    57tailgater
    from Georgia
    Local NAPA dealer may have something.
  10. I've had good luck with "one-stop shopping solutions" at your average hydraulic parts and service storefront in Anytown USA.
  11. leadsled
    leadsled
    Last -5 inverted flare I bought was from Earls. I bought 2.
  12. justpassinthru
    justpassinthru
    Thanks guys.
    Was able to get the correct size fitting from Hot Rod Hardware, that one of you guys recommended.
    Also got a face bushing to reduce the size, but it made it all a little bulkier than the actual correct fitting.
    The least amount of space the regulator takes up is crucial.
    Bill
    leadsled and pprather like this.
