Hello all, Looking for your recommendations of what the ideal rear axle WMS to WMS width would be for a fully fendered '31 A Coupe with stock fenders, 16" x 4-1/2" Ford '48 p***enger wheels, 700 or 750 tires please. Unfortunately my car is in storage and I can't get to it for measuring etc ..... this photo is the similar look I'd like to achieve. Thanks in advance.
53 1/2 -54 28-32 Coupe , Roadster Drum to drum . S-10 2wd ( 28-32 truck not sure) If where a Sedan 28-32 , a S-10 4x4 , because wider @ fender wel Where rear sides windows lower there is humps for Tracks, Regulator & Gl***
@31 Coupe Just asking , did you not understand the measurements that I posted? does not matter if it's a S 10 rear or not those are the measurements, My self done A's & 32 s A&32 Coupes , A & 32 Roadster's A &32 Sedan's
This is Sedan inner fender , This is why need the s-10 4x4 rear length I believe 56-1/2 over the 53-1/2 54 , the narrower works I feel better Deeper front dish wheel & if want you can add 1/4 to 1 inch spacer to move wheel tire flush to fender ,,, If to wide limited on Wheel then will be way to wide , hanging tires out like late 60's 70s
