Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. TA DAD
    TA DAD
    from NC
    I am in the process of reconditioning my engine lift, I have had this thing for over 40 years and it has earned it's keep. It has no real value but I thought I would prop it up so the next guy can take it to the century mark . IMG_2052.JPG IMG_2049.JPG IMG_2045.JPG
    Squablow, Budget36, BigRRR and 12 others like this.
  2. impala4speed
    impala4speed
    enloe and Sharpone like this.
  3. grdra1
    grdra1
    Thanks Impala4speed for your kind comments, I am happy with how the mufflers have turned out. I decided to make my own mufflers as this car needs to meet quite strict noise requirements for registration and running a healthy supercharged SBC this was always going to be an issue. So I decided that I would fill up as much space as I could with muffler, these mufflers are 750mm long, 175mm wide and are made using a 4 inch pipe cut in half, inlet and outlet is 3 inch ( whole system will be 3 inch and finish out the side before back wheel ). Glen 20250905_163955.jpg 20250905_164004.jpg 20250905_164011.jpg 20250905_165611.jpg 20250905_165621.jpg 20250905_165629.jpg 22b61691-1494-4b24-8725-5cd132a17720.jpg
  4. choptop40
    choptop40
    curious to how did you design the mufflers / references / technical info ? that's real hotrodding there...thanks
  5. lostn51
    lostn51
    from Tennessee
    I’m like you I build all of my chambered mufflers after we blew one up from a nitrous backfire:p You can build them a lot cheaper and tailor them to fit your needs. Those should sound pretty good being a small but long 5 chamber 3” and let the motor breath :D
    Sharpone, porkshop and guthriesmith like this.
  6. ALLDONE
    ALLDONE
    were you able to finish those in 2 days??? I'm thinking more like 4????
  7. grdra1
    grdra1
    My design brief included, available space, engine specifications and internet searches on muffler types, I decided that a perforated pipe and chamber design were the best of both worlds ( I hope I am right ). Glen
    saltflats, Sharpone, porkshop and 3 others like this.
  8. grdra1
    grdra1
    Yep, 2 full days, day 1 cutting and drilling holes, day 2 ***embly and welding, day 2 1/2, I run out of gas for welder on day 2, all work done with angle grinder, mill / drill and tig welder. Glen
    Budget36, saltflats, Sharpone and 3 others like this.
  9. grdra1
    grdra1
    nd needing to meet registration needs
    Thats correct, I built these to suit my needs, after watching lots of YouTube videos and internet searches, I decided on this design as suiting my blown SBC and registration needs, I feel these will work well - time will tell. Glen
  10. patsurf
    patsurf
    :):):cool:
    Sharpone likes this.
  11. Great work! Hotrodding, not billetrodding..
    Budget36, porkshop, enloe and 2 others like this.
  12. saltflats
    saltflats
    from Missouri
    The thumb nails will show all that have been posted, if they do full image you won't have that.
    porkshop, enloe and Johnny Gee like this.
  13. Chipping away at this to be ready to race on March 21. JW
    Squablow, lostn51, porkshop and 10 others like this.
  14. swade41
    swade41
    from Buffalo,NY
    I swapped tires around on rims for the 57
    Screenshot_20250906_190042_Gallery.jpg Screenshot_20250906_190147_Gallery.jpg 20250905_160302.jpg
    and chased an oil leak on the twisted 307
    Then stacked skinny front runners with rubber into one stack, that's a little to tall LOL
  15. MCjim
    MCjim
    from soCal
    Since I have no use for a heater, clock or obsolete radio, I made a radio delete plate and a stainless panel, using the old heater control cable and knob as a manual choke control, then added a vacuum gauge...after which, I changed the oil in my Tacoma.
    lostn51, porkshop, enloe and 6 others like this.
  16. deathrowdave
    deathrowdave
    from NKy
    Roll up ear plugs are one friends when trying to experiment with fire . I have been there a couple of times . Hope all is well , my friend
  17. brading
    brading
    I think that is a very good idea especially when you are welding, grinding etc in a position where you could get slag or a hot spark in your ear.
  18. Good idea! He is ok, just doesn’t want to go back to school after Lloydfest yesterday. Thank you for asking!
    Sharpone, porkshop and enloe like this.
  19. enloe
    enloe
    from east , tn.
    Get him a welding cap. when he is laying on his side welding have him spin the hat around, so the bill is covering the ear that is pointing up.
  20. HOTRODNORSKIE
    HOTRODNORSKIE
    Fit the rings got lucky and didn't have to cut them installed the crank back into the olds 303. 20250908_134338.jpg 20250910_144923.jpg
  21. TA DAD
    TA DAD
    from NC
  22. 34Phil
    34Phil
    no pics yet as welded braces for front fenders up from frame clip but width not same as hood so need to ratchet strap them in and reweld. Also had replaced grille with strap as didn't want to risk grille damage but need to put it in to make sure hood is same position forward. Hood won't go down last 2" in back so don't know if binding or hinges different as it is a '40 Olds hood for a '39. Had to cut side flanges off '37 Chevy radiator, narrow post war radiator collar, use electric fan as no room for mechanical and brace radiator to fenders. When everything depends on something else it's a pain. Also trimmed fender openings as wider track.
    saltflats, Budget36 and enloe like this.
  23. Paul
    Paul
    Editor
    baby steps here,
    fitting remote thermostat to the blown Olds
    porkshop, swade41, Sharpone and 9 others like this.
  24. DDDenny
    GMC 6-71........money shot right there!
  25. HOTRODNORSKIE
    HOTRODNORSKIE
    Reclayed the pistons just to make sure the valves will clear the notches. 20250913_150312.jpg
  26. atch
    atch
    That there is my tidbit of learned knowledge for today. I've never heard of a remote thermostat (before just now).
    porkshop, enloe, JohnLewis and 3 others like this.
  27. manyolcars
    manyolcars
    I got the yellow Victoria a few months ago and just got the blue Victoria. They're pretty but need improvements so I'm working on them IMG_20250911_183656913.jpg
  28. 1971BB427
    1971BB427
    from Oregon
    Was getting ready for a big get together Saturday morning, so Friday afternoon I began cleaning up my '39 Chev coupe. I happened to notice my front axle that I painted with Duplicolor silver mag wheel paint had turned from gloss silver to flat silver over the last 5 years. I've used it before on mag wheels and it held up great, so not sure why it oxidized?
    Tried to shine it up, but the axle, tierod, and rag link all silver wouldn't shine up. I finally grabbed my pads to lay on, and a Scotchbrite pad, and scuffed up all three parts. Since my ch***is is all Rustoleum gloss black and still looked like new I grabbed a quart of gloss black and brush painted the axle and other parts. Looks great, and hope it holds up like the rest of the black has!
  29. RockyMtnWay
    RockyMtnWay
    Still doing upgrades on the Tudor and trying to have her back on the road for the big end of season show/shine in two weeks, but it’s getting to be that time to start making the ‘list’, putting stickers on everything and packing stuff up for the upcoming swap meet (Oct).
    Seems like I have to psych myself up more and more for each swap now as vending seems more like work than fun these days.
    AND I hate making the ‘list’, but my ‘helper’ says I can’t do any wandering/shopping and leave our tables if I don’t have a master price list for her.:p:p:p
    alanp561, porkshop, Robdski and 4 others like this.
  30. RockyMtnWay
    RockyMtnWay
    Screw packing boxes today.
    Tackled the grimy exhaust instead.
    Love the golden brown sugar look but had to clean the grime off from the last road trip.
    No way to save the look so back to ‘clean’ everything went.
    But she’ll brown up again. :cool::cool::cool:
    Didn’t bother with the mufflers and here’s a pic of one dirty and one done.
    Ram horns took a little more effort and no where near perfect, but good enough.
