Event Coverage "The Fairlane Goes to Lloydfest"
Discussion in 'The Hokey Ass Message Board' started by The_Cat_Of_Ages, Sep 5, 2025.
  1. Moriarity
    Moriarity
    SUPER MODERATOR
    probably because of the dimmer switch? can you unplug it and make a jumper wire to byp*** it?
  3. 57 Fargo
    57 Fargo
    I don’t think anything of making a trip that far one way as a round trip in a day, I may check the oil before I leave but I have faith in my cars.
  4. Sharpone
    Sharpone
    Flipping it off won’t help Believe Me
    Dan
    Rolleiflex, porkshop, enloe and 4 others like this.
  5. Moriarity
    Moriarity
    SUPER MODERATOR
    how much oil did you use on the trip?
  6. mashed
    mashed
    from 4077th
    The late Raul Julia in The Gumball Rally
    Jeff Norwell, porkshop, enloe and 5 others like this.
  7. i used 3 quarts on the way down... still have plenty for the return trip.
  8. this car is a ****box. your cars are nice, it is what it is.
    50chevytx, porkshop, enloe and 8 others like this.
  9. Sharpone
    Sharpone
    Not so, it needs some TLC, it’s definitely a cool car. It appears to be complete. What ya got under the hood?, looking at my little screen it appears to be a Y-Block. Love the sound of a Y block in the morning! The afternoon and night also!
    Dan
  10. its a mostly complete sedan i picked up for cheap as a project when i was 16, little 292 Y block with a 4 barrel, 3 speed and dual exhaust. stuck a set of late 50s/early 60s gauges in it, and a full navajo blanket interior.
    the car has 976** miles. its due for its 100k maintenance.
  11. 57 Fargo
    57 Fargo
    I didn’t drive nice cars when I was young, my point is the more you drive it the less you worry about driving it.
    Driving “****boxes” as you call it, although I never thought of mine as that, all over is how i learned to not worry about driving old cars all over
  12. bobss396
    bobss396
    My brother always said, if the car will make 10 trips of 50 miles, it will make 1 of 500 miles.
    Cosmo49, porkshop, enloe and 11 others like this.
  13. F-ONE
    F-ONE
    from Alabama
    You said you had brake issues.
    Check the master. If you have a lot of fluid loss, it’s wrecker time.
    Visually check for fluid loss at each wheel. You are looking for leaky cylinders.
    If you have fluid loss,…..wrecker time.
    Adjustment……
    If the shoes are wearing in, you’ll have less pedal. An adjustment will bring the pedal back up.
    Do the adjustment at each wheel with your brake tool or screw driver.
    Get each wheel off the ground, spin it and do it properly.
    You don’t fart around with vintage brakes. They give one clue…..then it’s emergency brake, 2nd gear and aiming for the softest spot……if you have time.
    If the brakes are questionable
    Park it
    Call a wrecker.
    Driving an old car requires discipline because you want to be able to drive it again.
    It’s not just you.
    Honestly I feel the same about lights.
    osage orange, porkshop, enloe and 2 others like this.
  14. pwschuh
    pwschuh
    My hometown!
  15. BJR
    BJR
    Is the car leaking the oil, or burning the oil. It makes a big difference on how easy, and how much money it will cost to fix.
  16. RodStRace
    RodStRace
    @BJR he brought the car back to life. He's aware that the valves are loose in the guides, but put new seals on. The rings are suspect, but a big problem was the road draft tube leaking, which he repaired. It still has blowby, though. He's fixed a lot of the leaks.
    It will take some pretty heavy work to get it perfect. In the mean time, he's going to a meet and having fun while also aware it needs constant monitoring.
    Just clicking on his latest posts, it looks like he make it.
  17. Sharpone
    Sharpone
    He made it! And won a Trophy!
    Dan
    Cosmo49, porkshop, enloe and 19 others like this.
  18. the shoes were out of adjustment is all. tightening the shoes up solved my braking woes.
    porkshop, enloe, ffr1222k and 12 others like this.
  19. sitting here listening to music, thread'll be quiet til the return trip tomorrow.
    i did fix the choke/ high idle sticking issue, had to bend the rod some, who knew the choke was supposed to be vertical when its open? not me apparently.
  20. pprather
    pprather
    The choke fix should improve your mpg going home.
    osage orange, porkshop, enloe and 7 others like this.
  21. F-ONE
    F-ONE
    from Alabama
    Congratulations
    Have fun!!!
    gf sent me a pic of last night.
    Cosmo49, warbird1, ClarkH and 24 others like this.
  23. silent rick
    silent rick
    almost like under dash make out lights, I prefer blue myself
    porkshop, enloe, Torkwrench and 7 others like this.
  24. e1956v
    e1956v
    Alliance Vendor
    Glad you made the trip Cat
  25. RodStRace
    RodStRace
    He made it, made an impression and fixed things along the longest it's driven so far.
    He's also probably gained confidence in himself and the car.
    All top notch.
    Safe travels home you hooligan!
  26. gf said to say shes drunk as a skunk.
    im staying another night at our rental then heading back to camargo for the luncheon thing. aswell as to retrieve the forgotten chairs.
  27. RodStRace
    RodStRace
    She's feeling safe enough to imbibe far from home with a bunch of rowdys. Another feather in your cap, Cat. Trust is hard won and easily broken.
  28. shes been a feather in my cap for the last 4 years on the 11th.
    yes, we started dating on the 20th anniversary of 9/11
  29. Outback
    Outback
    from NE Vic, Oz
    That's a beautiful torch, what's the story on the trophy?
  30. Sharpone
    Sharpone
