Projects 1936 ford pickup hotrod
Discussion in 'Traditional Hot Rods' started by Ed95, Jul 8, 2025.
  1. Ed95
    Ed95
    Redid the seat. Its still not perfect but better.
  2. Budget36
    Budget36
    If you want perfection, pay for it. But I gotta tell ya, look good to me.
    Can’t see wrinkles with your **** in the seat!
    6sally6, 3blapcam, Ed95 and 4 others like this.
  3. warhorseracing
    warhorseracing
    from cameron wv
    Like I said, it is a learning process. The more you do the more you learn what to do and what not to do. It still looks great for an old car and when you sit on it, it may get even better.
    BigRRR, Ed95, Just Gary and 1 other person like this.
  4. alchemy
    alchemy
    Someone marked the crankcase wrong? Huh? You know that #1 is the front right cylinder.
    Deutscher likes this.
  5. Ed95
    Ed95
    It looks good in it. The top was easier i did learn a bit i guess. Idk if i wanna do any upholstery for a while tho. Also newest addition to the truck…Peep my fuzzy dice
  6. Ed95
    Ed95
    I know. But the mark on crankcase doesn’t align with the TDC of cylinder #1 (The front p***enger side cylinder). To be fair i don’t know the history of the engine. I never had it rebuilt or anything. Maybe I will if i need to but trying to make it run as is
    Just Gary likes this.
  7. Rehpotsirhcj
    Rehpotsirhcj
    The seat looks great, good job. They’re a pain to do for sure. Perfection is overrated
  8. Ed95
    Ed95
    Next I’m trying to restore the original key functionality. Someone destroyed the lock cylinder in place. So this will be fun IMG_3268.jpeg
    i took the steering wheel off and loosen the outer jacket or whatever the tube is called from the steering box. I was able to slide it a little bit up. I was trying to remove it but seems like i need to remove the steering box so i dont wanna do all that.
    So this is where i’m stuck now…
    I am trying to dis***emble the entire inner awitch system. I figure this way ill be able to push the remnants of that cylinder piece. There’s a little pin thing remaining in there that doesn’t let me slip it out. I read youre able to claw it out somehow but don’t wanna damage it
    Deutscher and Just Gary like this.
  9. Budget36
    Budget36
    I read the pin needs to be drilled out. Maybe @alchemy can confirm the process?
  10. Ed95
    Ed95
    I pulled it out! but still cant slide the switch off. It should be pushed into the steering shaft. This is the piece
    here is how it looks now. Im able to push it a bit but it hits the inner steering shaft
    Might need to remove the steering box
  11. Ed95
    Ed95
    Oh well… i guess i’ll clean the steering box and repaint it too had to cut the bolts to remove it they just kept spinning. All this for the stupid key cylinder and i dont even know how to take the outer tube off and the steering drop slides side to side but cannot slide it up the tube for some reason. Like stuck inside
    Just Gary and Deutscher like this.
  12. Looks pretty good...nice:cool:!!
  13. Ed95
    Ed95
    So for other people u dont really need to do all that.
    Theres a key thing that punches out on the inner shaft
    then the drop thing can slip out the outer tube
  14. Ed95
    Ed95
  15. Ed95
    Ed95
  16. warhorseracing
    warhorseracing
    from cameron wv
    It looks great! You are learning a lot with the steering column and all.
  17. alchemy
    alchemy
    For the switch parts I’d search at Third Gen Auto. But I think your horn rod is fubar.
    Ed95 likes this.
  18. Just Gary
    Just Gary
    @Ed95 I have a vacuum gauge you're welcome to borrow.
    hotrodjack33, Bandit Billy and Ed95 like this.
  19. Ed95
    Ed95
    Haha yeah thats what i see too. Is there any other more modern way to restore functionality even if its not the original design?
  20. Ed95
    Ed95
    Oh thanks @Just Gary i’ll need that haha. I can come by sometime this week. You got your sedan running again? Would love to hear it
  21. alchemy
    alchemy
    Unfold the tangs on the back of the horn switch, solder a long wire to the contact of the ****on, and run that wire all the way out the bottom of the steering shaft and column. Hook it to your horn relay just like a modern car. You will need to make sure the little bit of tube you have left on the back of the horn ****on ***embly will ground to the steering shaft. Looks like there’s tape on it? Clean that off. And put a very slight bend on the middle of that tube so it kinda wedges in the shaft and doesn’t slide out easily.
    warhorseracing likes this.
  22. Ed95
    Ed95
    Can you explain that with a little more detail? There’s a contact ****on? What does the wire soldered to the ****on contact do? Grounds it? Do i need a spring or something? And that bent little rod will be enough to keep it in place?
    Is the little ball with v8 in the middle of the chrome ring a separate piece from the whole thing?
  23. alchemy
    alchemy
    Should be a spring under the V8 ****on. If it doesn’t spring now, somebody has messed it up. Most horns work when you ground the ****on, which completes the circuit.
    My sedan is done exactly like I described for you. Except my horn rod wasn’t messed with before I got it, and my rod is a couple feet longer than yours. It stays in place during normal use, but if you yank on it, it will pull loose.
    Ed95 and Just Gary like this.
  24. Ed95
    Ed95
    Ahhh got it. Looks like someone did mess with it. Took it apart… i see what youre saying now. Thought it was all a solid piece. Someone screwed a threaded rod in it. I’m gonna see if i can attach a small tube back in it and do what you said
  25. Ed95
    Ed95
    Whoever had the truck before had done some pretty ****py patch around pedal area IMG_3334.jpeg
    Just made it a little better . It was annoying me
    i think they did some work on the clutch and it looks like the clutch pedal sits a little lower than the brake pedal.
  26. Ed95
    Ed95
    Cleannnnn steering column! Also repainted the steering box while I had it out and the frame rails. Ignore the ****py wiring. I promise I’ll get to it eventually lol
  27. warhorseracing
    warhorseracing
    from cameron wv
    ****py wiring?:confused: Man, this is a work in progress. One thing at a time. It isn't like you have a team of six guys working on it 10 hours a day.;) You are doing it all by yourself. Learning as you go.;) It is looking pretty good, and the "****py wiring" will one day tucked away out of sight while you drive it down the road.:cool: No need to apologize for work in progress.:D
  28. Ed95
    Ed95
    You’re so right! I just wanna drive it already! I guess i should learn more patience lol
    warhorseracing and Just Gary like this.
  29. Ed95
    Ed95
    Currently I have the choke connected to my farthest carb on the front. I have solid linkage. How should I connect the choke? I turned the engine on and it rpms like crazy, guess too much air… i read some things online about closing one carb and using only one or should i connect both the same? IMG_3316.jpeg
    osage orange and Just Gary like this.
  30. alchemy
    alchemy
    High rpm’s is probably because of too much gas rather than too much air. Many flatheads are run with dual two barrels both open at the same time. You probably need to fiddle with the idle needles and maybe the idle adjustment. Did you synchronize the carbs?
