Supercharged Heads/cam
Discussion in 'Off Topic Hot Rods & Customs' started by Fifty5C-Gas, Sep 7, 2025.
  1. Fifty5C-Gas
    Fifty5C-Gas
    I have a 350 Chevy, it has forged dish pistons. I have a Dyers 6v-71 blower (6 psi boost). The heads I’d like to use, because I have them, are Dart Iron eagle 72cc heads with 200cc runners. Will the 200cc runners be ok on the 350, I knkw for a pretty much stock 350 it’s too much but I’m hoping with the blower they’ll be fine. Also, what can would you recommend? As well as rockers, should I do full roller or roller tip? 1.5 or 1.6?
    Thanks, Mike
  2. Oneball
    Oneball
    What do you want the engine to do, get you to the local diner or go racing? What car is it in?
    squirrel likes this.
  3. Fifty5C-Gas
    Fifty5C-Gas
    Street/strip car, but I’d like it drivable because it’s more street. It’s in a 67 Firebird with an M20 and 3:70 9” rear
    swade41 likes this.
  4. Fordors
    Fordors
    I’d look at cams with a 114* lobe center angle and I’d run stock rockers, but I’m thrifty.
    Fifty5C-Gas likes this.
  5. 19Eddy30
    19Eddy30
    from VA
    IMG_3941.jpeg With all cam issues in last 15 years
    50/50 on solid & Hyd ,
    Run , use Hyd Roller ,
    No Solid Roller un less you go with
    Very Good Lifters $1,500 Plus .
    No Monster Cam Needed for your combo , under .530
    Pic just for reference , BDS has more
    H -R then shown pic 20 years old ,
    Look @ Howard web site ,
    Good roller tip are oK
    Same with Full Roller ,
    Good Brand Quality
    Not cheap under $350 bands .
    ekimneirbo likes this.
  6. Fifty5C-Gas
    Fifty5C-Gas
    I’d prefer to stay standard hydraulic cam, I don’t want to do a roller
  7. 19Eddy30
    19Eddy30
    from VA
    Is this a cam and lifters that's all already been ran and when removed each lifter match to the lobe that it came off of
    or running cam & lifter set already.
    6 psi will work on a stock cam engine
    I have done it 35 years ago ,
    Cast pistons , crank , rods
    But you gotta keep the engine happy
    """AFR """ not get to greedy on boost
  8. DDDenny
    M-20 trans/3.70 rear gears is a good combo.
  9. Fifty5C-Gas
    Fifty5C-Gas
    I don’t have a cam yet. I’m asking if the 200cc dart heads are good for a 350 with a blower and what cam I should run. I don’t want to run a roller can, I’d prefer to stay standard hydraulic.
  10. 19Eddy30
    19Eddy30
    from VA
    You can Break good parts all so
    I melted 1,300 -1,800 pistons
    Boken rod's
    Blocks
    1,200 plus cranks
    But you can also run Stock
    Stock 350 & 400 Under 6,000 rpms
    Up to 5 ish psi for years ,,
  11. 19Eddy30
    19Eddy30
    from VA
    Yes Heads will work Fine!!
    its 50/50 % you will LOOSE the cam !!
    Its really to me 80% you will wipe cam
    On any made in last 15 years to present ,
    Hydraulic or solid flat tap,
    Spend the money and use H-D roller
    Even get a 5.7 stock Vortec block
    & cam
  12. 19Eddy30
    19Eddy30
    from VA
    Just ""recommendations ""if you're new to this which it sounds like you kind of are ,,,No offense !!!
    I'm not afraid to run a 80s Vortec on my lawnmower tractor ! That would be extreme , But
    ottersea likes this.
  13. Fifty5C-Gas
    Fifty5C-Gas
    I’m just asking if the 200cc heads will be ok and looking for a cam recommendation that’ll work well with the heads and blower. I don’t really need a lesson, lol
  14. 19Eddy30
    19Eddy30
    from VA
    @Fifty5C-Gas
    If engine tuned correct ,
    You will have to learn how to speed shift real fast 1st to 2nd & maybe 3rd,
    Will RPM , Quick any traction
    Clutch , slip is more likely , next to look @ broken M20 ,
  15. 19Eddy30
    19Eddy30
    from VA
    Yes Heads Fine ,,,
    If you want you can install a set of
    SB2 's
    Those heads are Better then you Need
    For what you say your wants / intend
    You're gonna be heartbroken if you stick with a flat tap it or solid Cam go south more expensive to fix than use a retrofit kit first Time
  16. Fifty5C-Gas
    Fifty5C-Gas
    I agree the heads are better than I need, but I have them, I don’t have to spend money on heads, they’re sitting in my garage. I prefer to use them as long as they’re not too much head for what I have and won’t hurt performance.
  17. 19Eddy30
    19Eddy30
    from VA
    @Fifty5C-Gas
    I would rather run those heads that you have then a fully set of reworked
    Double hump 202's ,
    Set Your springs to what ever
    Cam you go with ,
    And if you going to buy new rockers
    Good quality Full roller or just the tips
    Like Chromoly body with Roller tip
  18. squirrel
    The heads will be fine, you can run huge ports with a blower and it won't care.
    Cam with around 230 degrees duration at .050" lift is probably what you want. A little more duration on exhaust is probably a good idea. 112-114 degree lobe centers should work well for a street setup.
    Turns out that camshaft selection depends mostly on what RPM you'll be running the engine, the blower doesn't really affect it much at all. so if you're aiming for 3000-6000 rpm (for example), pick a cam that works in that range. It's not as much rocket surgery as you might think.
  19. 19Eddy30
    19Eddy30
    from VA
    @Fifty5C-Gas
    You did not bring up ,as about carbs
    I prefer side saddle mount ,
    With what it sounds what your are doing , 350 -377 around 6 pd boost ,
    2 650 cfm in line if Holley my choice
    377 - 406 2 750 cfm 8- 11 boost ,
    @squirrel I believe Carter's on the Nova
    With the 427 , many miles across the U.S. with Pre 65 parts,
    Do not know the cfms thoe thinking @ least 1,400 Combined ?
    I have No experience with Edelbrock nor Carters on Blower
  20. Fifty5C-Gas
    Fifty5C-Gas
    2 600cfm edelbrock carbs set up for use with a blower
    • 2 1406 Edelbrock carburetors
    • Universal Throttle head
    • Square flange or Spread bore mounting pattern
    • NO CHOKES
    • bright shiney finish (NOT PAINTED, BLASTED OR ANY OTHER SALES PITCH YOU SEE OUT THERE)
    • Mounting gaskets
    • flow tested
    • These carbs have a specific calibration for 2x4 super charger set up. The main jets and metering rods have been replaced with a NEW combination that we have found to be much better and more responsive that the stock combination. There is also recalibration of the primary venturi boosters that deliver your idle fuel and transition fuel mixture, making for a more responsive and crisper launch. SO take note if you are comparing other sets to these. These are no ordinary 1406's”
  21. 19Eddy30
    19Eddy30
    from VA
    @Fifty5C-Gas
    Back around 88
    I had a 406 .494 IN .512 Ex
    6:71 8 pob
    2 650 DP
    Switched to
    2 750 Dp
    Picked up 4 teth
  22. Fifty5C-Gas
    Fifty5C-Gas
  23. squirrel
    that cam looks like it's what you want...
  24. DDDenny
    Check those valve springs.
  25. Fifty5C-Gas
    Fifty5C-Gas
    You mean if they can handle the cam?
  26. DDDenny
    See the notes relating to the Howards camshaft.
  27. Fifty5C-Gas
    Fifty5C-Gas
    I saw that but I’m not using stock heads, I have dart heads with a double spring. Springs have 100psi seat pressure, hop up to .500” lift cam
  28. squirrel
    Just make sure the springs are right for the cam, not too soft, not to stiff. That's in addition to having enough valve travel so the retainer won't hit the guide/seat, or get close to coil bind.
  29. 19Eddy30
    19Eddy30
    from VA
    @Fifty5C-Gas
    That cam You looking @ looks good also to me , & If I had to buy New Rockers
    I would Experiment probably add 1:6 s
    I have 1:5 & 1:6 .
    I have use this under 400 cid ,
    Seems To For me worked well.
    H-Roller
    Thoe ,
    With out seeing on engine Dyno to see Results ,,
    I prefer over 400 cid sb .
  30. ekimneirbo
    ekimneirbo
    from Brooks Ky
    If you are buying new rockers, go with roller rockers. No reason to run 1.5 ratio if you have enough valve to piston clearance to accomodate a 1.6 ratio and springs that work with that lift. Its free HP with no downside.
    I would only use a roller cam even though it costs more. Last thing you want is to spend all that money to put the engine together and be one of the guys that has a flat tappet cam wipe it out during breakin. Yes roller cams aren't perfect, but they give fewer problems. Notice that all the OEMs use them nowadays and engines are lasting a lot longer .
    19Eddy30 and Fifty5C-Gas like this.
