Technical 327 is .060 too much for a safe bore?
Discussion in 'The Hokey Ass Message Board' started by LesIsMore, Sep 7, 2025.
  1. LesIsMore
    LesIsMore
    from Ohio
    What is the max safe bore amount for a 1965 327 small journal engine? I have a nice block that is at .040 and needs cleaned up, is going .060 too much? Machine shop telle me he wouldn't recommend it because potential overheating issues? True? It's a good clean block otherwise. Thoughts?
  2. DDDenny
    Pay for a sonic test before moving forward.
    Just Gary likes this.
  3. miker98038
    miker98038
    ^^^^^ X2 cheap insurance
  4. Put a lot of miles on a .060 over 350.
    Cheapo Fred Jones build that we freshened up
    No issues
    bobss396 and 2OLD2FAST like this.
  5. JimSibley
    JimSibley
    I had a .60 over 327 with a blower in my 57 chevy. Ran hard and never ran hot.
    2OLD2FAST likes this.
  6. 19Eddy30
    19Eddy30
    from VA
    Like other above have said ,
    Or
    How about over size file fit ring.?
  7. PackardV8
    PackardV8
    No worries on most early 327"s.
    jack vines
  8. squirrel
    If it were mine...I'd think about how many miles it will get put on it, and how much taper it has in it now, or any other problems with the bore. If it only needs to last 30-40k miles, and the taper is .005" or less, I'd just give it a light hone and put new plain cast rings in it, and run it.
    But you can also get it sonic tested, and bore it to .060, or whatever else you want to spend money on.
  9. Taboo56Chevy
    Taboo56Chevy
    for a 60 over motor, depends on the car the engine is going in and if it has enough radiator and airflow. I have a 60 over 350 currently in my 33 and it overheats pretty quick in traffic. Have had other 60 over motors in other cars and its hit and miss.
  10. RodStRace
    RodStRace
    The machine shop is saying
    So you want ammo to argue with them?
    As said, sonic check the block. Here's one discussion on it.
    https://www.chevelles.com/threads/whats-correct-way-to-sonic-check-a-block-for.822985/
    Then check for pistons. I'm wondering if you go custom if you could get something between the current .040 and .060, if it will clean up at less.
    Since both the machine shop and others here have mentioned that a thinner bore does run hot, expect to have a top grade cooling system, too.
    Budget36 likes this.
  11. MCjim
    MCjim
    from soCal
    There is nothing sacred about a 327...just find a good 350, you will be $$$ ahead.
  12. squirrel
  13. G-son
    G-son
    from Sweden
    As others say, check how thick the cylinder walls are, and go from there. (Even if there may be plenty of metal core shift during manufacturing may have caused the bore to be off center, making the walls thinner on one side.)
    Algoma56 likes this.
  14. Budget36
    Budget36
    That’s the first time (the link) I read actual thickness mentioned.
    Thanks for the link.
    RodStRace likes this.
