Technical Little tips and tricks for garage hobbyists.
Discussion in 'The Hokey Ass Message Board' started by Ron Brown, Jul 30, 2019.
  1. Six Ball
    Six Ball
    from Nevada
    Use a bungie instead of the spring. You don't need tools to put it on.
  2. patsurf
    patsurf
    :eek::rolleyes::p
    Six Ball likes this.
  3. atch
    atch
    There is another sign on the walk-out door at eye level.
  4. atch
    atch
    Ratchet straps don't get tangled up when stored like this. I have about 25 of them and they are always easy to choose and use. They are stored in a milk crate so are always together.
    rpm56, enloe, Deutscher and 12 others like this.
  5. @atch I do the same thing, for straps and other items. keeps them well organized.
    Six Ball, X-cpe and Sharpone like this.
  6. atch
    atch
    Speaking of baggies; whenever I remove a bolt, nut, or other hardware and know (or even think) that I'll want to put it back on sometime in the future I put it/them in a baggie and label the baggie as to what the contents are. Then that baggie goes into a big drawer with all the other baggies containing hardware. And since I don't want to get SS or grade 8 hardware mixed up with ordinary hardware, I put those in baggies also, labeled as to what it is.
  7. jetnow1
    jetnow1
    from CT
    I put it on the light switch!
    rpm56 and Six Ball like this.
  8. 65pacecar
    65pacecar
    from KY, AZ
    Just a reminder to wear appropriate safety equipment. Today I completed installing new brake calipers, hoses and hard lines on my diesel and had the wife working the pedal to bleed the brakes, a task we have all done many times. Luckily I had my safety gl***es on, when I opened the bleeder it shot fluid much stronger than expected and hit me dead center in the gl***es, it would have been my eye otherwise. The rest of the job I layed to the side of the stream, but that was a close call.
    vtx1800, Sharpone, jet996 and 4 others like this.
  9. nrgwizard
    nrgwizard
    from Minn. uSA
    I'm not a fan of open bleeders...
    I use a snug piece of hose, long enough to go into & along the inside wall of a mason jar, so's I can see the color of the brake fluid. A little more fussing/mumbling, but I also don't like big messes. Easy to pour the contents into a proper container as needed.
    Marcus...
    alanp561, vtx1800, Sharpone and 7 others like this.
  10. patsurf
    patsurf
    heck-w/ the bottle you don't need a helper!
    Sharpone, jet996 and 65pacecar like this.
  11. 65pacecar
    65pacecar
    from KY, AZ
    I’ve used that method many times and it’s my regular go to, but went the old way this time. Future bleeding, going back to the hose in a jar. Cleaner and ultimately easier, especially on a show car, this was a DD type and was just ready to get done and couldn’t find any hose that would stay on; I had rags and cardboard to absorb the mess. Another lesson learned……
    Sharpone and deathrowdave like this.
  12. j hansen
    j hansen
    Yes,,,the best way!
  13. brading
    brading
    I made a little stand for my container so that it does no tip over.
    Sharpone, GuyW, 65pacecar and 2 others like this.
  14. deathrowdave
    deathrowdave
    from NKy
    PPE is always over looked when in a hurry to finish up . I did a stupid stupid thing earlier this year and it took weeks to recover . A Friend stopped by needed a part TIG welded , I was working outside no shirt on . Took the part inside and welded it . Shirt on went to lunch . I started to notice strange feeling on my chest . Got to checking , really burnt from the UV of welding and not wearing my jacket . This act is over looked by most , protect all skin from the UV when welding : hands , top of head , arms , chest , throat , ears the more the safer . Eyes when plasma cutting , are easy to forget .
    The persons we hurt the most by not using PPE is our family , and I know no one wants to hurt a family member .
  15. Bandit Billy
    Bandit Billy
  16. 31Apickup
    31Apickup
    Wear ear protection!
    Glitchy, 5brown1, Just Gary and 7 others like this.
  17. patsurf
    patsurf
  18. Dave G in Gansevoort
    from Upstate NY
    Now that is unique. Looks like it would be easy to duplicate. Hearing protection and finger protection…
    Bandit Billy and Sharpone like this.
  19. j hansen
    j hansen
    I like it,,thinking of doing that myself .Poor man`s Pullmax.
  20. patsurf
    patsurf
    the one of mine in that not very good pic above thinks NOTHING of 16 ga.!
  21. Fortunateson
    Fortunateson
    That’s the one Karl Fischer of Japhands offers up. Knowing his work it must be a great tool! I believe he has plans on his website...
  22. rockable
    rockable
    I've seen the videos. It appears to work pretty well, just slower than a pullmax. Karl is pretty inventive!
  23. jnaki
    jnaki
    Hello,
    When we decided to do a garage makeover, out came the old big box store cabinets and counter drawers. Once it was empty, the new thicker material and better surface material made the cabinets sturdier and safer. No more sagging shelves. The thicker shelves are double the size of the store bought shelving.
    The good thing was it was done by a garage cabinet company that knew normal thickness cabinets for closets are not good for garage work or storage. So, their cabinets are simply sturdier and fit better. They are custom made to the measurements of the garage layout we had planned.
    But, once we had them installed, the counter tops were pristine and so I told my self, I needed to refer to an old friend to help keep the counters in pristine condition.
    41 year old Corian counter top saved from a new kitchen remodel, back when we were in our late 30s did the trick. The contractors cut out a small opening on a sink counter top. I took the opening cutout piece and made it smaller with rounded corners and edges. Warning: The raw cut Corian counter top is razor sharp and care or gloves are to be used. Once the corners were rounded and edges filed as well as sanded round, then it was easy to grab and hold to use for any “hot plate.”
    Yes, the counter folks do not tell you it is ok to put anything warm or hot on the counter surfaces. Which is true. But this original man made surface, Corian was great in that for the garage use, any liquid spills, solder left overs and other paint marks on it cleanly wiped up with lacquer thinner. Now, that made the surface super clean. The one thing the installer told us was that if we did burn the counter top, a super fine sandpaper could be used to go over the marks and that would take out the burnished surface. That was true and the super fine wet/dry paper worked wonders.
    But, for the garage use, the super fine sand paper on a vibrating sander did the job of keeping the surface clean after any work. Once I accidently made a deep gouge on the corner from a s****ing tool that got out of the angle I was using on a project. It made a small groove one could feel as you rub your hand over the surface. So, out came various sand paper grades and eventually the super fine vibrating sander to get the marks completely off and smooth again.
    upload_2025-9-20_4-53-28.png Then we moved several times and the last garage re-do was the best.
    In 2023, I put on felt pads for protection, when we got the new garage cabinets and counter surface. The surface is great, but the added Corian counter top work tablet is a good way to keep the counter surface clean and mark free.
    One other application was when we got a new kitchen counter top made out of granite. It took on a completely new look and yes, there were big/little flat plates that were cut out for the sink and other openings. So, again, I had the counter guys do the rounding and shaving to make a smooth/rounded edge/corners to be able to work on the smooth surface.
    upload_2025-9-20_4-56-27.png They were good plates for smoothness and accessibility. Any gluing projects were easily cleaned up and the surface was as good as new. No hammering or chisel work was going to be used on this top. The granite had a tendency to chip easily and cracks started to show up on the new surface and size of the plate. When the plate was cracked, the edges were, again, razor sharp. The cracking continued with any lifting and work on the surface, so, the 30+ year old Corian counter top original work top was put back in play.
    Jnaki
    Then in 2024, my wife had this great idea of hers to change the counter top again. The granite was smooth and nice, but now, it was dark and we wanted a brighter kitchen appearance. So, we started looking for a lighter looking color and material. The popular alternative was Quartz. But it was going to have the same touchy results of the granite.
    So, we opted for a quartzite material that is stronger and better suited to the daily use of two folks that like to keep everything clean and neat in the house. The new lighter counter made the whole kitchen look as if it was day light all of the time. A nice lighter look overall did the job.
    Yes, I was able to get a couple of pieces of the new Quartzite pieces. But, to our surprise, the counter folks had already looked ahead and made a custom countertop work plate for us. The corners were rounded and the edges were smoothed and radius matched the curve of the corners. Now they even put on feet to give us a nice looking plate for all reasons.
    Here are some other pieces I saved in raw cut form. We are using them for outside planter bowl coasters in the patio. We don’t care if the weather affects the surfaces. We just have to use gloves when moving the plates.
    One advantage of sharp edges/corners, is that those plates keep the snails from wanting to climb up the edges to get to the bowl and plant. No need for snail food to keep them away from our plantings. YRMV
  24. atch
    atch
    Had to remove the axles from Clarence's 8" Ford rear recently to replace the third member. Everyone on here has his/her favorite way to pull the axles. Many of you turn the brake drum around and use it as a slide hammer. That's what I did. Normally you put them on with three lug nuts turned around to the flat side. As these lug nuts were mag wheel nuts and I couldn't find any old fashioned "regular" lug nuts I just used the mag wheel nuts. Worked just fine. As you can see there was about 1/2" (+/-) of free play before the drum hit the lug nuts. Before you comment: yes, I know that I have some maintenance to do before I put the drums back on.
    rpm56, Sharpone, alanp561 and 4 others like this.
  25. Kentuckian
    Kentuckian
    A basic kitchen timer is very handy to have around. They are cheap and easy to use. Give it a try.
    Sharpone, jet996, b-body-bob and 3 others like this.
  26. Six Ball
    Six Ball
    from Nevada
    Like for seeing how long it takes to drain your bladder? :eek:
    rpm56, Sharpone, vtx1800 and 3 others like this.
  27. SDS
    SDS
    To keep track of BPH...beers per hour
    Sharpone, Six Ball and jet996 like this.
  28. DDDenny
    ****** timer!:eek:
    Sharpone, hrm2k and Six Ball like this.
  29. ******? What's THAT?:p
    Ben
    Sharpone and Six Ball like this.
  30. Ziggster
    Ziggster
    Fabbed up this “puller” out of an old screwdriver to get this nail out that was stuck in my tire this morning.
    Sharpone, Irish Mike, enloe and 7 others like this.
