Technical Anyone near Hollywood FL who knows points ignitions?
Discussion in 'The Hokey Ass Message Board' started by Ebbsspeed, Sep 7, 2025.
  1. Ebbsspeed
    Ebbsspeed
    A non-HAMBer in another forum I belong to is fighting a no-spark issue on a 1937 Buick, and I am reaching out to see if anyone in the area would be willing to look over his shoulder and give some guidance.
    Thanks!
    Oneball, Budget36 and lothiandon1940 like this.
  2. theHIGHLANDER
    theHIGHLANDER
    If it's dead-dead at the distributor it may not be in the engine compartment. Those have an armored cable from the key switch, yes? They go bad, to see if thats the right direction simply hotwire it and see if all is well.
  3. Ebbsspeed
    Ebbsspeed
    He's done that, as well as a few other tests I've tried to guide him through. Has power to the coil, test lamp on the distributor terminal flashes when cranking indicating points are working as they should. I pretty much boiled it down to condenser or bad coil, both of which he has replaced and still nothing at the plugs. He's also replaced the cap and rotor.
  4. patsurf
    patsurf
    don't waste time w/ 'light' etc.-snapping the points makes a spark jump from coil wire to grd?-no,but have juice there=points--sand 'em
    gregsmy, BigRRR and squirrel like this.
  5. Ebbsspeed
    Ebbsspeed
    Lamp flashing when on distributor terminal proves points are doing what they are supposed to do.
  6. Power to the coil and signal should produce some spark out of the secondary tower, an inline spark tester should show this. Then use the inline tester at the cap to eliminate the coil wire, then use tester on wires out of the cap and see where the spark stops. Nothing out of the coil, check coil primary and secondary ohms, spark into cap but nothing out, check cap/rotor clearance, cap/rotor condition and make sure rotor is spinning with the shaft.
  7. ClayMart
    ClayMart
    theHIGHLANDER likes this.
  8. theHIGHLANDER
    theHIGHLANDER
    I think the pedal start is starter only, nothing to do with spark. At least it is on Packard (like the Clipper era).
    vintage6t likes this.
  9. patsurf
    patsurf
    agreed-and this is a simple prob that people are not doing the simple test(s) that would have this running a lot sooner than me typing this!--
  10. tubman
    tubman
    Where's @Hnstray ? He has one of these and really knows his stuff.
    427 sleeper likes this.
  11. BJR
    BJR
    Hold the distributor end of the coil wire 1/4" from a good ground, then snap the points with the ignition switch on. If no spark it's either the coil wire is bad, coil or condenser. ***uming like you said, a test light flashed when you snapped the points, proving you have power at the points. If you have a spark at the end of the coil wire with this test, the problem is the cap or rotor, may have the wrong rotor, or carbon tracking in the cap.
  12. gregsmy
    gregsmy
    from Florida
    I have seen oxidized contacts cause similar symptoms. They look "ok" but until you take them out and polish them they just dont work correctly. Heck I have seen new points with the same issue.
  13. Mr48chev
    Unless it has been converted to 12 volts with a resistor and resistor byp*** the coil should be getting power when cranking on a six volt system that is not missing anything. I'd say that isn't the issue though.
    Does he have the coil polarity correct? Coil polarity always matches battery polarity with no exceptions on oem applications.
    Rather than a test light when cranking I'd stick a dwell meter on it to read dwell or rpm either one and that should at least show that the points are controlling the function of the coil.
    Remembering back to when I was 16 and doing a tune up on my car that probably didn't need a tune up I got the lead from the condenser in the wrong spot when I put points and condenser in and it was actually over on the other side of the insulator block rather than against the lead from the points as shown on this old 216 Chevy distributor.
    Also make sure that the condenser is tight in it's holder. I've had replacement condensers that did not fit tight in the original holders. That is more prevelant now with one size fits a lot of applications ignition parts for older cars.
  14. ClayMart
    ClayMart
    I guess I thought using the floor switch would provide full battery voltage to the ignition for cranking and starting by momentarily byp***ing a ballast resistor. But with 6 volt electrics the resistor probably isn't needed.
  15. THERE WAS NEVER A SWITCH UNDER THE "FOOT FEED".
    Ben
  16. patsurf
    patsurf
    he must mean the actual little tiny box 'solenoid'/contactor
  17. theHIGHLANDER
    theHIGHLANDER
    Most of them had a contact switch in the throttle mechanism with a vacuum override so the starter wouldn't engage in normal operation. It's actually a pretty trick deal when it's right. Better yet? Startix. Just turn the key, if it stalls you get an instant restart. Nice when they're fussy n cold but you need to be aware during an inconsequential stall and stab the clutch. To avoid that the ign switch has 2 settings, Stx and Ign. So once started you can flip the key or switch the other way and the autostart is defeated. "Hey, no pics?"
    Ok, a pic (****ged from a net search)
    ClayMart likes this.
  18. I know the later Buicks (40s-50s) had a switch on the carb. It had a metal ball inside and made contact when full throttled to crank, then when started vacuum pulled the ball backwards so IF you full throttled again when running it wouldn't try to crank the starter.
    firstinsteele likes this.
  19. ClayMart
    ClayMart
    Yep. You're both right. The starter switch isn't under the foot feed. (Damn, that's fun to say!) It seems to be under the hood and somehow connected to the throttle linkage.
    Sounds like maybe a "Rube Goldberg" contraption. :p
  20. Closer!
    Ben
    patsurf likes this.
  21. [​IMG]
    Soooo close, but no cigar for me.
    Anyway BTT for the op.
