What uses 5x5.25 Steel Rims?
Discussion in 'The Antiquated' started by 1953naegle, Sep 10, 2025.
  1. 1953naegle
    1953naegle
    This isn't necessarily a "wanted" ad, but I'm happy to take any leads.
    I have a pair of ag-implement axles that I want to put to work, but they take 5x5.25 rims (as in 5 lugs, 5 1/4" from center of hole to center of hole opposite), and I'm having a hard time finding ANYTHING like that. Does anyone know what other wheel'd vehicles would use this rim so I can expand my search? I'm going to try a couple of local salvage yards, but I figure the more info I can bring the better. I'm hoping to find some plane-jane steel rims. I'm flexible on the OD dimensions, but 6x16's would match some other junk of mine.
  2. fyrffytr1
    fyrffytr1
    1953naegle likes this.
  3. Yes, you are both talking about the same measurement , just different method of measuring. Anyhow probably a easy wheel to find should be from the little Suzuki 4x4 Vitara or Samurai ( what name are they in U.S. ) Those have 15 inch and 16 inch. Now if you find a little Lada Niva :eek: 4x4 your good as well. Don't forget to take your backspace measurement with you as well. Or any old Ford between 1940 and 1948 and some later pickups.
  4. 1953naegle
    1953naegle
    Yep, you guys are right! I need to pay better attention to the charts, but it is 5 1/2" from bolt center to the EDGE of the opposite hole. Those rims are everyware.
    Thanks guys!
