Projects So this is how it starts "T" RPU
Discussion in 'Traditional Hot Rods' started by chlsnk, Jun 5, 2025.
  1. chlsnk
    chlsnk
    from Kansas
    Not much progress this weekend, moved the brake M/C hole over on the F1 cross member, had to take my life in my hands and use a 20250713_134739.jpg 20250713_142506.jpg 20250713_142714.jpg hand drill to cut the large hole my rota broach lost all its teeth in the process. Also broke down and steam cleaned the banjo rear end in preparation to ***emble the Q/C. Ordered a kings ransom worth of bearings seals and races hoping to get it together as parts arrive. Not super happy with how long the studs for the axle bells are, bottomed a few out and with nut and washer they still have close to 3/8" stick out.
  2. chlsnk
    chlsnk
    from Kansas
    20250725_175123.jpg 20250722_113836.jpg 20250720_122036.jpg Not much progress this past week or two. Bearings and seals have been arriving for the rear end, seems like everyone is sold out so I had to go through a few different suppliers. Going to get my trans case and gears boiled and ***embled soon. While ive been waiting I spent some time working on my falcon pulled the gl*** knocked the roof down to bare metal and epoxy primed it.
  3. Outback
    Outback
    from NE Vic
    Cool project, love early Falcons too.
    Had a quick read back but can't see what that gearbox is? Thanks for the updates
  4. chlsnk
    chlsnk
    from Kansas
    37' Cadillac/lasalle.
  5. Outback
    Outback
    from NE Vic
    Thanks, wondered if it was something like that.
    chlsnk likes this.
  6. Steve Reddy
    Steve Reddy
    Love the Falcon, great little cars!
    osage orange and chlsnk like this.
  7. Mikko_
    Mikko_
    from Sweden
    Don't know how I missed this thread but I'm subscribed from now on.
  8. chlsnk
    chlsnk
    from Kansas
    Finally something that looks like progress tonight. Bearings races and seals installed onto the bells, webbing clearanced for ring gear bolts. Tommorow evening I'm going to get the carrier cleaned up and ready to re***emble
    Pressed in new shackle bushings; hangers and spring. I've had so much trouble with this in the past. The difference has been my method of removal, instead of running a hacksaw through the bushing I cut down a Sawzall blade to fit though the old bushing. This made quick work cutting a relief that let the old bushing come right out with a cold chisel. On the hunt for a rear shackle after inspection it has a pretty good waist worn into it.Before it got dark I was able to get another coat of 2k primer on the falcon roof hoping to block out the tiger stripes and get some single stage white shot this week if we get a break from the 70% humidity.
    20250728_185519.jpg 20250728_185503.jpg 20250728_185436.jpg 20250727_191926.jpg
  9. Rand Man
    Rand Man
    You have a great start on this one.
    chlsnk and Outback like this.
  10. Tim
    Tim
    from KCMO
    We got a break from the 70% humidity by getting 90% humidity lol.
    Hope this afternoons storm cools us off for even a couple hours.
    chlsnk and osage orange like this.
  11. I'm gasping for oxygen, too, Tim. Guys, these A-bones seem like there's never an end to the projects. In a way, that's kinda a good thing. I did little things this morning, swapping out a hydraulic brake light switch, connecting the fuel tank and filler elbow, trying to troubleshoot a couple of electrical issues and screwing up the courage to fill the radiator with water, the fuel tank with gas, screw in the plugs, wire up the ignition and start up the engine for the first time. Chlsnk, nothing more frustrating to me than trying to pull apart shackles and get the bushings out. Nearly 60 years ago I had a '29 A standard coupe and an old neighbor of mine, a retired heavy truck mechanic, showed me how to use a short piece of 2-by-4 to go between the rear spring eye and the axle housing, then have someone jump on the rear end while the other guy shoves home the shackle. I'd wasted a couple of hours, most of my strength and all of my cuss words before he came over and helped me with that trick. Took less than a minute to put in the new shackle.
  12. chlsnk
    chlsnk
    from Kansas
    Hit a slight set back today. Sat down to ***emble the rear-end, cleaned up the last of the used parts scrubbed off the shellac of dried grease and found that there was serious pitting in the area where the spider gear rides. Have a line on a replacement I'm going to check out tommorow. Guess that's life when dealing with 60-90 year old parts. 20250802_181011.jpg 20250802_181020.jpg
  13. 26 T Ford RPU
    26 T Ford RPU
    The bright side is you did a top job on cleaning the parts!:cool::) JW
  14. Tim
    Tim
    from KCMO
    Man that’s a bummer :/
  15. chlsnk
    chlsnk
    from Kansas
    The pitting really suprised me, the axle was seemingly dry and rust free inside and out. I have a su****ion it was probably driven like this with the pitting for some time. No pitting is present on the spider gears which I found really strange.
    Outback and 26 T Ford RPU like this.
  16. patsurf
    patsurf
    those spiders are plenty hard-it's got 90 wt or heavier-not much weight OR horsepower-put it back together!
  17. chlsnk
    chlsnk
    from Kansas
    Not going to lie I definitely considered that. But I'm going to feel real dumb if that ends up damaging my quick change center section down the road.
  18. 26 T Ford RPU
    26 T Ford RPU
    The spider gears do very little rotating unless you like doing one wheel burnouts and that's not good for any spider gears but there are four not the usual two. JW
    chlsnk likes this.
  19. Dave G in Gansevoort
    from Upstate NY
    Lincoln locker! Then there’s no one wheel peel! And who cares about pits then?
    chlsnk and 26 T Ford RPU like this.
  20. chlsnk
    chlsnk
    from Kansas
    Call me convinced I'm going to put it back together.
  21. patsurf
    patsurf
    right choice!
    Outback likes this.
  22. Yeah, I know the feeling. You ask yourself, "How hard will my cheapness/laziness bite me in the *** if I guess wrong?" I guess the new phrase is, "**** around, find out."
    Outback, 26 T Ford RPU and chlsnk like this.
  23. chlsnk
    chlsnk
    from Kansas
    20250804_180930.jpg 20250804_183623.jpg Not much progress recently but I am now a firm believer in evaporust. Dunked my door latches in a jar of the stuff and they came out beautifully in the white. Scrubbed them down pulled them apart completely for round 2 of clean up and re ***embly. Pleased with how simple they are inside, looks like a hard ware store spring with a 1/4" ID will have them back in useable shape. Not sure how I want to treat them before putting them back together, maybe a coat of primer and grease the sliding latch?
    Tim, dwollam and Deutscher like this.
  24. chlsnk
    chlsnk
    from Kansas
    Pulled the door locks apart and nickle plated them, I've never plated anything larger than nuts bolts and small gun parts so this was all a learning experience but I'm pleased with how it turned out. 20250810_190133.jpg 20250810_190147.jpg 20250810_193602.jpg
    treb11, Tim, dwollam and 6 others like this.
  25. Outback
    Outback
    from NE Vic
    I love the finish, perfect! Electrolysis I ***ume?
  26. chlsnk
    chlsnk
    from Kansas
    Yes its the easiest way, pretty safe and simple. Low amperage/low voltage takes some time but good results can be achieved.
  27. chlsnk
    chlsnk
    from Kansas
    Haven't had time to do much recently. Since my last update I did get my block back from the machine shop, not real pleased at all with the work that was done. The decks where resurfaced which I didn't ask for, main caps loose in a box, new ross pistons loose in a box and charged way more than agreed to but atleast its back in my hands. Going to do some serious measuring before I ***emble the engine.
    Got the QC together and under the frame. I misplaced my U bolts and plates so it's all clamped together for now, likeing the stance.
    Got all the lasalle cases washed and painted. Hoping to ***emble my top shift this winter and use a side shift for mock up.
    Painted the falcons roof installed the headliner and new gl***, my wife took the rear seat and package tray to her upholstery shop to retrim.I've been putting some miles on it and really questioning why I want to sell it. 20250909_174740.jpg 20250909_175036.jpg 20250909_174717.jpg 20250903_193346.jpg 20250829_163401.jpg 20250829_153648.jpg
  28. brett4christ
    brett4christ
    If it were mine, I'd SERIOUSLY consider swapping axle tubes side to side, shortening the frame, reinstalling the A rear crossmember and mounting the A spring AHEAD of the QC on the spring mounts original to the axle tubes. It sounds really weird until you see one out in the wild!
    But then again, its not mine! ;)
    BTW...Nice work to date!
  29. Tim
    Tim
    from KCMO
    Man both of those little cars are looking good!
    chlsnk likes this.
  30. AmishMike
    AmishMike
    Hate to say this but believe main caps always go back in original position. Maybe not matter since your 3 probably obvious where they fit. SBC guy here. Looks great
    chlsnk likes this.
