Hot Rods What was I thinking-3 window kit car (steel)
Discussion in 'The Hokey Ass Message Board' started by 2deuces64, Aug 15, 2025.
  1. Lookin' real nice.Great work!:cool:
    Sharpone, porkshop and 2deuces64 like this.
  2. ekimneirbo
    ekimneirbo
    from Brooks Ky
    I'd like to suggest a license plate for the car when you do get it together...........JIGSAW :)
    Looking forward to watching your progress and hope it comes together well for you.
    Sharpone, enloe, 2deuces64 and 3 others like this.
  3. RodStRace
    RodStRace
    Great for a 6 digit state. If it's 7 digits, I'd offer WELDROD!:)
    Sharpone, enloe, CSPIDY and 4 others like this.
  4. duecesteve
    duecesteve
    Sharpone and porkshop like this.
  5. 2deuces64
    2deuces64
    Thank you, I'll be away from the car for about 2 weeks and I keep looking at the last pix I posted and wonder if the rear section of the roof needs to come down a little. Opinions are welcome.
  6. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Maybe............BTSNPCS:D Bits and Pieces
    Sharpone, enloe, Outback and 3 others like this.
  7. Squablow
    Squablow
    I don't think so. Personally I think they get too boxy/squished looking with a heavy chop if the front and rear are the exact same height. I like what you've got going.
  8. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Outstanding build and an excellent thread.
    Sharpone, enloe, -Brent- and 4 others like this.
  9. Moriarity
    Moriarity
    SUPER MODERATOR
    man, really cool... The best way to figure out if it is right or not is to roll it outside and step way back from it... Looks fantastic to me though... carry on!
    Sharpone, enloe, GordonC and 7 others like this.
  10. Amazing what can be accomplished by just jumping in and going for it. Great progress and looking great. Following along to see what’s next.
  11. duecesteve
    duecesteve
    Very nice sheet metal work, it's definitely a process to piece in the panels and have it come out so nice. I'm 63 and was in high school for autobody and I had a teacher who was old school and he taught us how to do lead work it's something you never forget even if you don't do it that often .:)
    Sharpone, Algoma56, Outback and 2 others like this.
  12. SR100
    SR100
    It looks like there’s a small hump (inside the circle) is that an optical illusion?
    The straight portion of the window surround (in the rectangle) looks off to me. The factory three-door has a subtle curve there.
  13. 2deuces64
    2deuces64
    I'm concerned about the hump, I think it looks to full if that makes sense. I may have to get a better look when I get back to work, The door top doesn't bother me as much, I think there is only about1/4' to 3/8 " of rise in the blue box.
  14. pprather
    pprather
    Will you be able to install door gl*** through the window opening?
    It seems @3wLarry was never able to install door gl*** in his deuce 3 window as the window opening was too low.
  15. Grumpy ole A
    Grumpy ole A
    Great work, it does make some of us a little jealous because we can’t do this. Thanks for the pictures and descriptions of your work.
    Sharpone, porkshop, 2deuces64 and 2 others like this.
  16. nochop
    nochop
    from norcal
    F-ing sinister looking
  17. Motorwrxs
    Motorwrxs
    I think it looks bad***…considering what you started with, I certainly would not sweat a small rise or a hump or perceived humb.
  18. Nailhead A-V8
    Nailhead A-V8
    Nope....looks great fantastic work
    Sharpone and 2deuces64 like this.
  19. RodStRace
    RodStRace
    Grab a smooth Black trash bag and 'wrap' the area with it and stand back.
    You might even spray some Gibbs or such to make it 'stick'. Even a light water based glue if you aren't done sanding.
    Quick and cheap way to visualize a finish. Should show issues.
    Sharpone, 2deuces64 and porkshop like this.
  20. 2deuces64
    2deuces64
    I've ben thinking about that, not near the car right now, but if I have to I might make the upper 2 or 3 inches of the inner door skin removable. I'll see what happens.
    Sharpone, enloe, Thor1 and 1 other person like this.
  21. ALLDONE
    ALLDONE
    I was thinking PUZZLED
    Sharpone, enloe and ekimneirbo like this.
  22. krylon32
    krylon32
    from Nebraska
    Don't have to copy but maybe dig up a few pictures of Rolling Bones 33/34 3 windows and check their side roof profiles compared to yours.
    enloe, warhorseracing and porkshop like this.
  23. ALLDONE
    ALLDONE
    removable would be great..my 32 when they chopped it they left the door gl*** too long to get out, then slid the gl*** up and welded welded stops to not let it roll too far... they thru bolted billet mirrors, then weld every thing... couldn't get in there with an allen wench to get the mirrors out...and can't replace the door gl*** if it ever breaks... hair pulling experience to get the mirrors off... lots of WTF went on...
    enloe and oliver westlund like this.
  24. 2deuces64
    2deuces64
    Gary, I've looked at a lot of pictures of heavily chopped 33-34's, I think I need to bring the top down and thumbnail (55).jpg forward like the blue line in the picture
    Dos Cincos, Sharpone, enloe and 8 others like this.
  25. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Your top is lower, but here is a profile of the Kalifornia Kid. The back of the roof appears to be somewhat in the same plane as the raised area behind the door. Parallel ? The-California-Kid-LR-RGB-300x157.jpg
    2deuces64, Sharpone, enloe and 2 others like this.
  26. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Good question.............Maybe make the inner door panel have a removable section that screws in place holding the window brackets and stuff.
  27. 2deuces64
    2deuces64
    Well, I'm back from Kansas (granddaughters wedding, great grandsons' birthday, and a celebration of life for my sister in-law).
    I think I worked out my problem with what I considered a hump in the roof. I had to make the roof opening about 2" longer to match a 3W opening. I used the front section of another roof and flipped it around and widened it 3" to line up. I was able to lower it about a half inch where it tied into the sides of the roof. I'll have to shrink a few of my welds and do some welding under the back window, I'm happy where it ended up. thumbnail (39).jpg thumbnail (40).jpg thumbnail (42).jpg thumbnail (43).jpg thumbnail (45).jpg thumbnail (46).jpg
  28. 2deuces64
    2deuces64
    Sharpone, porkshop and rod1 like this.
  29. 2deuces64
    2deuces64
  30. patsurf
    patsurf
    pineknot4, Sharpone, porkshop and 3 others like this.
