Projects uncle Charlie's hot rod model A projects
Discussion in 'The Hokey Ass Message Board' started by tb33anda3rd, Feb 19, 2025.
  1. tb33anda3rd
    tb33anda3rd
  2. Grumpy ole A
    Grumpy ole A
    That is a tricky piece to make with all of the compound curves. I sure you will get it done and looking good.
    Outback, Stogy and winduptoy like this.
  3. tb33anda3rd
    tb33anda3rd
    I am not 100 % happy with the result, Charlie's shop is limited in metal working tools. I did it with a cheap mig, left and right tin snips, a grinder, a couple hammers and a vice.
    Outback, Stogy, winduptoy and 5 others like this.
  4. tb33anda3rd
    tb33anda3rd
    made Charlie some patch panels for the doors at my shop. image4.jpeg image3.jpeg image2.jpeg image1.jpeg used my break to bend the bead and return then used the shrinker to put the arch in it.
    Outback, Stogy, winduptoy and 9 others like this.
  5. tb33anda3rd
    tb33anda3rd
    we also mounted up a set of tires on A rims. we went through all our old tubes to find four good ones. image0.jpeg
    Stogy, winduptoy, ct1932ford and 7 others like this.
  6. tb33anda3rd
    tb33anda3rd
    I also made a set of rain gutters. I had made a stencil of the shape of the door and used it as a guide. I folded the outer side over, then bent the return, used the shrinker and stretcher to shape it to the door stencil, the folded the flange straight across that will get welded along the roof over the door image0.jpeg image1.jpeg image2.jpeg
    Stogy, winduptoy, ct1932ford and 10 others like this.
  7. I am withholding judgement on the box.
    Stogy and tb33anda3rd like this.
  8. tb33anda3rd
    tb33anda3rd
    so noted.:)
    Stogy, winduptoy and ct1932ford like this.
  9. tb33anda3rd
    tb33anda3rd
    Charlie has been busy, I stopped by today to check out his progress. he got the head light bar and lights mocked up and wired them to the original A switch. image0.jpeg
    tires and rims really changed the look
    Stogy, winduptoy, ct1932ford and 8 others like this.
  10. tb33anda3rd
    tb33anda3rd
    I started by welding in some visor extensions to fill the gap in the roof. image1.jpeg
    Stogy, winduptoy, ct1932ford and 9 others like this.
  11. tb33anda3rd
    tb33anda3rd
    I also welded on the rain gutters I made .
    Charlie painted the windshield frame and glued the gasket on so we installed it. image3.jpeg
  12. tb33anda3rd
    tb33anda3rd
    next up:
    I am going to make new metal bed sides.....
    Stogy, milwscruffy, winduptoy and 9 others like this.
  13. Awe man, no more NDTs! :D;)
    Stogy, tb33anda3rd and rusty valley like this.
  14. tb33anda3rd
    tb33anda3rd
    I like the new tires and rims but I liked the vibe of Charlie using "what he had" . Charlie is going to sell them and use the cash for parts he can use.
    Outback, Stogy, winduptoy and 3 others like this.
  15. tb33anda3rd
    tb33anda3rd
    bent up some bed sides per the slackers drawing. plan to get over there Friday.
  16. tb33anda3rd
    tb33anda3rd
  17. patsurf
    patsurf
  18. tb33anda3rd
    tb33anda3rd
  19. tb33anda3rd
    tb33anda3rd
    then we decided to add some stake pockets, so we cut some square tube to size. image2.jpeg also will add another piece to extend the angle and weld a length of tube to the edge to finish it off.
    I will do that at my shop so I can clamp it all flat to the bench.
  20. tb33anda3rd
    tb33anda3rd
  21. tb33anda3rd
    tb33anda3rd
    I then welded the patch to the drivers door. ....down and dirty:D
    :cool: image3.jpeg
  22. Grumpy ole A
    Grumpy ole A
    It’s looking better every time you show us pictures of y’all’s progress.
    Outback, Stogy, osage orange and 2 others like this.
  23. bubba55
    bubba55
    Ya do such good work Sir - I’ve really enjoyed yer posts !
  24. tb33anda3rd
    tb33anda3rd
    thanks guys.
    Outback, Stogy, cactus1 and 2 others like this.
  25. Now I feel I can judge the box - vast improvement. Keep up the great progress.
    Outback, Stogy, cactus1 and 1 other person like this.
  26. tb33anda3rd
    tb33anda3rd
    I read all the responses and "likes" to Charlie, he really enjoys fact that other people are enjoying the build. your "holding judgement" made him reflect on how the bed was coming out, he found the metal from a previous build and decided to change the bed.
    FYI I agreed with the change, we would have found a way to make it look fine, but the metal is a better direction.
  27. Hot rodding the original design- build concept. Try something, change it if it doesn’t suit. You all have a good sense of proportion.
  28. I feel some what sheepish, thinking that I have input from behind the keyboard. In no way do I think it is right to tell other people what to build. I am however happy to chime in on something I like, and for sure I like this build. I wish I was closer and could spend some time on my back with rust in my eyes, giving you guys a hand.
  29. tb33anda3rd
    tb33anda3rd
    The input is all good and appreciated, there is no right or wrong on this build. It follows no rules and isn't expected to be anything but a pile of parts and pieces assembled to resemble a vintage truck.
    Something from nothing that could be redone, rebuilt, restored, rebodyed , or used till it is recycled.
    Outback, Stogy, simplestone and 6 others like this.
  30. simplestone
    simplestone
    Rock on! This build is just so fun to watch.
    Excellent work.
