Hot Rods Chevy to Flathead
Discussion in 'The Hokey Ass Message Board' started by Little Wing, Sep 11, 2025.
  1. Little Wing
    Little Wing
    from Northeast
    Putting a flathead transmission behind a Chevy 153 4 cylinder (which seems to be same as small block) ..What pilots bear and throw out bearing is used in this application?
    Thank you
    Bandit Billy likes this.
  2. hotrodA
    hotrodA
    IF it’s the same as the V8, Speedway sells the correct pilot bushing.
    If you are using the standard early Ford to Chevy adapter, use the early Ford T/O bearing
    If the flywheel is standard Chevy drilled for it, use the Borg and Beck #988-1310 pressure plate,
    49-51 Mercury piece. Cores are scarce, meaning pricey. Ft Wayne Clutch or Kentucky Clutch.
    Use the early Ford clutch disc.
  3. ididntdoit1960
    ididntdoit1960
    from Western MA
    What year flathead transmission? Car? Truck? Big difference between early and 8ba transmissions
  4. Little Wing
    Little Wing
    from Northeast
    1939 Car
  5. ididntdoit1960
    ididntdoit1960
    from Western MA
    Good advice above then - speedway makes the pilot bushing and there is a merc clutch core in the cl***ifieds on here now - send it out to ft Wayne Clutch for a rebuild and get a new disc from them too - use the stock Ford throw out and one of the many adapters available to bolt the trans to the sbc
  6. Mr48chev
    Looking for some Examples of Ford flathead pilot bearings and ( I put in 64) chevy II pilot bearings I came up with these. ID of the Ford pilot bearing is .6693 while the ID of the Chevy II busing is .593.
    For the price the brash pilot bushing from Speedway isn't a bad deal. I'd like to have a bit more meat on the stub that sticks out past the end of the crank though. Screenshot (754).png Screenshot (757).png Screenshot (758).png
  7. Little Wing
    Little Wing
    from Northeast
    Motor is from a 64 Nova still has its clutch, PP,and flywheel with pilot bearing
  8. Little Wing
    Little Wing
    from Northeast
    Yes stock 4 cyl Nova motor with original Clutch, pressure plate and flywheel
    @hotrodA
    this is the pilot bushing that came with a speed gems sbc adapter.
    Haven’t put it together yet.
    I’m using a 50 merc disc and pressure plate.
    3703870 is the gm flywheel I’m using.
