Projects 32 make over started
Discussion in 'The Hokey Ass Message Board' started by pantodd74, Jan 3, 2025.
  1. What are your cam specs and what type of spring pressure on the seat are you running?
  2. pantodd74
    pantodd74
    Finally have tomorrow off from work. In the morning I will be installing the new 8.000 pushrods and setting the valves. Then start putting the engine bay back together. We did order the 12 circuit harness the other night. If I remember I will take and post the pic's of the current setup to the new setup on the pushrods. But in the afternoon it's tree stand therapy!
  3. pantodd74
    pantodd74
    The pic I'm posting is a list of cam's I chose from. The one in the middle with the dot is the one we are running. 20250121_204133.jpg
  4. pantodd74
    pantodd74
    So yesterday I swapped the pushrods out. What a difference .200 makes. The 8.000's set the roller tips in the center of the valves stem tips and also adjusted a lot easier than the stockers. Also had plenty of thread in the poly locks for the locks. Got the oil pump primer installed and forgot to install the oil pressure gauge tube. Shot oil like a gyser. Cleaned that mess up and installed a new tube to the gauge. Spun the drill again and forgot about the plug on the front of the engine and made another mess. Got that plug installed and showed 50 psi on the gauge and oil flowing through all the push rods and rockers. Installed the starter, valve covers, intake, carb, and exhaust. A few more items to wait on being shipped and installed. Then we can fire this mouse up, break in the cam and take her for a spin. 20250915_200857.jpg 20250915_200903.jpg
    loudbang and jaracer like this.
  5. pantodd74
    pantodd74
    Installed the new Lokar shifter. What a nice piece and easy to install. 20250925_131412.jpg
    loudbang and RICH B like this.
  6. pprather
    pprather
    That is going to be unbelievably loud to drive. Remember to wear your ear protection.
    NoSurf likes this.
  7. alchemy
    alchemy
  8. pantodd74
    pantodd74
    Ears will be protected until we get the exhaust the wife found and wants.
  9. pantodd74
    pantodd74
    What type of trans cooler are you guys running? There is no room to put one in front of the radiator. So I'm wondering if anyone is using the finned tube style and where did you mount it?
  10. 19Eddy30
    19Eddy30
    from VA
    On the A I had ,
    I used this style mounted on inside of frame behind / past front seat .
    No issue with 3k converter .
    On my 32 I have this one ,
    I have it ducked / scoop that I made
    To catch air under & force threw because @ time a 4,800 converter ,
    This one mounted Flat with 4 inch
    Space between floor @ 3rd member area,
    All pluming is PTFE lines
    pantodd74 and big duece like this.
  11. 19Eddy30
    19Eddy30
    from VA
    Not to be busting on Op car with Zoomies
    Not going to sound right with out
    12:1 plus compression and right cam ,
    Idle & normal throttle.
    My 5w I installed set of Borla straight threw round S.S. because of true 4 link & @ idle to 3,500 rpm's sounds like my 1950 farm tractor , Ahh horrible!
    But up on converter to WOT sound like my Borla VR1's collector mufflers like used on TopDragster Super Comp .
    I can not Believe the way it sounds
    With 10:5 static compression with a Big bore roots . I honestly do not know if
    Mufflers or all the Tight radius turns to make fit using Fabrication donuts
    pantodd74 likes this.
  12. Mart
    Mart
    "You'll have to speak up, officer, I can't hear you over these exhausts. They're very loud".
    SPEC and pantodd74 like this.
  13. ozrodder
    ozrodder
    I find it impossible to stay away from build/rebuild threads so much talent and inspiration for my own project thanks for posting !!
  14. pantodd74
    pantodd74
    19Eddy30 how did the finned tube do while in stop and go traffic like a cruise-in? With no air flowing over it I guess it's better than nothing.
  15. 19Eddy30
    19Eddy30
    from VA
    Do not under stand your question?
    I am like a few others here spend time & work @ a track , Hear & see many different drag , street vehicles for over 50 years ,
    Fc , Dragster & Pulling header's are Unique sound when
    Alot of Compression & large cam shaft,
    To me Just @ idle , if not @ 1,500 to 2,500
    Rpm's ,,
    Your Zoomies , to long , shorter better
    Like 12-15 inch from ports ,
    & Are not going to sound correct @ idle 500 to 4,000 rpms , Just loud ,,, Not even like a H-D drag pipes,
    & all those drag pips do not sound ,made equal ,,, Needs compression .
    I am not kidding about my 5w with the
    Straight threw mufflers it sounds
    Awful , I idle 1,000 rpms Much radical
    Cam then your & blower with 10:5 static compression ,
    Even so-many with long Tube
    4 into 1 collector Open do not sound right
    Below 1,000 rpms .
    The round Borla on 5w Now
    The XR1's are other 2 pictures,
    on large cid sbc 700 plus
    I might put the XR1s on 5w
    The little 383 is only 630 hp .
    big duece likes this.
  16. big duece
    big duece
    from kansas
    I think his question was directed towards the finned trans cooler.
  17. 19Eddy30
    19Eddy30
    from VA
    With Tube style with fines,
    3,200 converter / stall , I also use extra sump trains pan TCI cast aluminum
    I had No issue ,, when moving there a lot of air flow underneath
    On As & 32's aslong as frame not
    5 inches off ground a Very deep Channeled ...
    I am just one that does thang's & test ,
    When I get a Ideal thinking about I try
    With test ,,, I used temp probes
    In cooler lines , I also used / had test Temp probs @ bottom of radiator shell
    Ambient air temps flowing under
    car at different location so I could test
    Temps while sitting still & driving .
    On my 32 , in Fall when temps are below 55 degs I have to install plug
    On air dam to trains cooler to get temp to 160ish trains temp in pan ..
  18. pantodd74
    pantodd74
    Thanks for the info. The pipes on the headers I built are not done. I'm going to cut them all equally across. More of a work in progress.
  19. pantodd74
    pantodd74
    Got a lot done the past few days. Front of the car is rewired. Engine is done other than the cooling and fuel systems finished. Gave my old man the old dash board and he cut out a new one in walnut. Installed the new gauges and switches. A couple more full days and it will be time to fire it up. Still need to get a new drive shaft made before it can run down the road. 20251008_132949.jpg 20251008_150005.jpg 20251008_150015.jpg
  20. pantodd74
    pantodd74
    Spent the past 2 days getting more wiring done. The trans controller and it's parts are all installed and wired up. The dash is almost ready to be installed. Still have to finish wiring the tail lights and get the dash installed. Then set it back on the ground and measure for the drive shaft. Install the cooling system and fuel line. Then fire it up and break in the cam.
  21. pantodd74
    pantodd74
    Finished the wiring today and dash is ready to be installed. Radiator is installed as well. Getting closer!
