Saganaw tilt column
Discussion in 'Off Topic Hot Rods & Customs' started by johnfin, Sep 15, 2025.
  1. johnfin
    johnfin
    from Florida
    I have an old chevy saganaw tilt column. Any of you have completly tore one down? I need to replace tge pot metal rack
  2. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Been a while since I’ve busted some apart and re***embled them.
  3. Mr48chev
    I'd have to go out and take one apart to remember how to change out that piece. I used to have a bunch of those columns laying around out in the shed but think I hauled them all off in a s**** load.
    Step one is to set the wheel so the column is straight and not tilted one way or the other.
    I'm thinking that when you take the lock cylinder out and take the igniton switch off down on the column that that piece and the rod just pull out the top. I'll go look and see if I have one left out there that I can look at.
  4. johnfin
    johnfin
    from Florida
    I appreciate that. I was thinking you have to remove the tilt pins and remove that section to access th.at part. You mention the key tumbler, does that have to be removed or can i leave it in,
  5. Johnny Gee
    Johnny Gee
    from Downey, Ca
  6. 19Eddy30
    19Eddy30
    from VA
    @johnfin
    Just did one yesterday
    To get the 2 pins out , one each side of tilt . Lower / upper Like the hing point?
    This will separate lower half of the column from the upper half / tilt.
    There should be threads #8 Machine
    I screwed long bolt / screw in with nut & washer , I then tighten nut down with
    1/2 open wrench laying over pins
    Tighten nut down witch it pulled the pressed pin's out,
    When putting back in I used small b*** jeweler hammer to tap back in place
  7. willys36
    willys36
    Here is a printed version of the process. Don't need any special tools, just carefully follow the steps. those buried tilt bracket bolts are always the culprit to a malfunctioning column. Dig down to them, Lok***e them to death and you are good!!
  8. johnfin
    johnfin
    from Florida
    My ignition switch rod tip looks different then the one in the article. How does the rack actuator lock into the rod tip. Does tilt and pins have to come apart to connect the rod to the rack? Dormans sells the pot metal rack piece so i ***ume it is easy to replace.
      189.6 KB
      333.4 KB
  9. johnfin
    johnfin
    from Florida
    Also, the article shows the housing cutaway. I dont have that luxury. I need to see what iam doing.
  10. 19Eddy30
    19Eddy30
    from VA
    Is that the Lock for steering wheel when ignition off key out?
    If so Yes , it's design to come in through the backside towards the steering wheel.
    I'm thinking the reason why making it harder for a person to steal the vehicle even if they remove the steering wheel
  11. RodStRace
    RodStRace
    Oh, I did quite a few of those tilt pins and other repairs in those! I even have the little special tool to pull them. But there is no way I could write out each and every step to R&I from memory. Just know that you will have a huge ***ortment of tools laying around and a lot of parts to get there.
    Steering wheel puller, the lock plate compressor to pull the snap ring, and lots more.
    Watch the video posted, and there are probably more. Once you feel like you can at least back out if needed, go in!
  12. johnfin
    johnfin
    from Florida
    Its not the steering wheel lock, its the rod for the ignition switch.
  13. johnfin
    johnfin
    from Florida
    ps I love the video at 22:19 when he pulls it apart and parts go flying. OMG
  14. SS327
    SS327
    When I was at my best 30 years ago I could dis***emble, replace the shift bowl, install a rack repair kit and upper bowl in less than 5 minutes without removing the column from the car. But back then I was doing 4-5 columns a day on recovered thefts.
  15. johnfin
    johnfin
    from Florida
    In the ***embly video he shows the connection of the rack to rod. My rod came out ***embled so why cant it go back in ***embled? Be nice if the cover had an access cover or could be pulled back. Mine does not.
  16. johnfin
    johnfin
    from Florida
    Here is another pic from a video. Does the tilt pin go thru the rack piece?
    SS327 likes this.
  17. 19Eddy30
    19Eddy30
    from VA
    If tilt pin not Taped to jack out ,
    Center punch , then tap to #6 or #8
    Machine screw , My post #6 is how I pulled pins out,
    It took me 3hrs start to finish , column was in vehicle , took little time to look @ wear patterns to figure out how to install some of the parts
  18. justpassinthru
    justpassinthru
    Be sure to get the same exact parts as removed.
    Th
    There are different racks, gears and shaft etc.
    Not all the same as many parts suppliers will lead you to believe.
    I get my parts from Steeringcolumnservices.com
    Bill
    19Eddy30 likes this.
  19. johnfin
    johnfin
    from Florida
    How is this cover held on?
  20. johnfin
    johnfin
    from Florida
    I have noticed that there are different rod end. Some have a wing piece on the tip. Anyone notice this?
  21. justpassinthru
    justpassinthru
    According to steeringcolumnservices.com, that is a mid 1980s column with that type of actuator rod.
    If you go to their website, every part has photos to identify what style you have, to get what you need to repair.
    Bill
  22. justpassinthru
    justpassinthru
    Thats a bit of a stretch of imagination of 5 minutes.
    Takes longer than 5 minutes just to R&I the horn pad and steering wheel, not to mention R&I the turn signal switch to access the lock housing and then the shift bowl.
    Then also having to repair all the other damage the thief did to the column.
    Non tilt columns are easier and faster to repair.
    But on tilt and tilt-tele columns the steering shaft has to be removed to dis***emble, which can many times add a lot more time to the project.
    Bill
  23. SS327
    SS327
    Nope! I was timed. And air tools were involved.
