Hot Rods 29 RPU- "Street/Strip" B/SR Build - Marty Strode
Discussion in 'The Hokey Ass Message Board' started by Marty Strode, Dec 19, 2019.
  1. Marty Strode
    Marty Strode
    While I am waiting for the suspension parts to return from powdercoat, I have been attending interior details. The wood rail around the back of the cab was nice, so I ran it through the gl*** bead machine, sanded it with fine paper, brushed on some Varathane. Next, I wanted to line the inside of the cab with black, textured, ABS plastic, so I formed and aluminum channel that bolts into the original holes in the back panel. After the corners are closed in, there will 10/32 rivnuts installed for fasteners. IMG_0159.JPG IMG_1904.jpg IMG_1908.jpg IMG_1903.jpg IMG_1905.jpg
    Tim, das858, rod1 and 17 others like this.
  2. Blues4U
    Blues4U
    from So Cal
    Where do you get the ABS at Marty?
    porkshop likes this.
  3. Marty Strode
    Marty Strode
    Tap Plastics, we have several in the Northwest. It's great for interior use, this is how I finished behind the seat in my COE. IMG_7301.JPG IMG_7522.JPG
    Stogy, rod1, dwollam and 6 others like this.
  4. DDDenny
    That's where I got mine Marty.
    Stogy and porkshop like this.
  5. Marty Strode
    Marty Strode
    Got parts back from powdercoat, now the work begins ! IMG_1919.jpg IMG_1921.jpg IMG_1918.jpg IMG_1917.jpg
    Stogy, alanp561, bymanr and 20 others like this.
  6. Tim_with_a_T
    Tim_with_a_T
    Looks great!
  7. Stan Back
    Stan Back
    . . . where do you get a full-size Monogram kit like that?
    Stogy, alanp561, Tim and 2 others like this.
  8. alchemy
    alchemy
    I’d like to find a pair of those C4 backing plates some day. Had a chance once but dropped the ball.
    Stogy, RICH B and porkshop like this.
  9. Marty Strode
    Marty Strode
    The giant tube of glue will be the next purchase.
    Stogy, alanp561, patsurf and 4 others like this.
  10. 05snopro440
    05snopro440
    Looks great!
    Two questions: Is the wood floor tech legal? Does the space in the floor at the back have to be filled?
  11. Bandit Billy
    Bandit Billy
    Looking good Marty! Love the powder coat and paint job.
  12. Marty Strode
    Marty Strode
    I am going to skin both sides with aluminum and have all the rest clear anodized . And the rear section will be closed in. I hope it will p*** tech.
    Stogy, dwollam, 427 sleeper and 2 others like this.
  13. Marty Strode
    Marty Strode
    I knew you would be watching, so I sent a slow easy one for you to pick off. Take care buddy !
  14. Rocky
    Rocky
    Classified Editor
    Tech at the track or state sponsored tech before being allowed to drive it on the streets legally?? I asked as a born and raised Oregonian [The Dalles] and when I left in 1980 there were no tech hoops to jump through except at the track.
  15. DDDenny
    I would have felt let down if ol' Bill didn't chime in.
    RPU is looking great Marty.
    Stogy, 427 sleeper and porkshop like this.
  16. DDDenny
    You do what ya gotta do, and being an Oregonian you'll know to do it with a raincoat on!
    Stogy, Weedburner 40 and porkshop like this.
  17. Marty Strode
    Marty Strode
    I will look to see if they refer to “floor boards” !
    Stogy, Tim_with_a_T and porkshop like this.
  18. Bandit Billy
    Bandit Billy
    Well played sir, well played in deed!
  19. Marty Strode
    Marty Strode
    A little update, DVC Machine took care of re-bushing and honing the front spindles. So, I got the front suspension in, and set the engine in place this weekend. Progress IMG_1967.jpg IMG_1964.jpg IMG_1965.jpg IMG_1966.jpg !
    Stogy, cactus1, Hotrodmyk and 16 others like this.
  20. AmishMike
    AmishMike
    Cover those injector tubes before a bird takes roost - or something moves in
  21. tomcat11
    tomcat11
    Going to be one sharp RPU! Curious about powder coating and the machined mating surfaces like the quick change bells. Did they mask them off? Are you having to remove coating from some surfaces and threaded holes? I've seen where chasing threads after powder coating was needed and also time consuming.
  22. Marty Strode
    Marty Strode
    Tom, in this case the side bell/housings bolt to the side plate adaptors and it has nothing to do with the machined surfaces, or setting up the rear backlash. I will still use gaskets on the powdercoat surfaces, but the majority of the grease stays in the center section. Also, the plug as many of the holes as possible, but the time it takes to clean out holes is well worth the ruggedness of the powdercoat. Everything that is silver was 400 bucks, and with the cost of paint, I will use it every time I can. The top one on the rack is the one I used. Thanks for your interest. IMG_3707.JPG
    Stogy, lurker mick, dwollam and 4 others like this.
  23. Marty Strode
    Marty Strode
    I have 2 paid professionals to keep any unwanted intruders out of the shop. Louie and Marbles ! IMG_7620.JPG IMG_7621.JPG
    Blues4U, Stogy, cactus1 and 8 others like this.
  24. AmishMike
    AmishMike
    What r your pans for the champ quick change?
  25. Marty Strode
    Marty Strode
    I have a few, and the one going in the '29 uses the side plate adaptors for the V-8 housings. That is my favorite look in a 60's era car. I have a Stock Car Products 31 spline locker for it.
    Stogy, lurker mick, dwollam and 3 others like this.
  26. DDDenny
    Marty, about those other housings on the rack, are those the same, both Ford or is the hidden one a Chrysler?
  27. Marty Strode
    Marty Strode
    Doug, those are Fords, as I remember they are both the GOOD ones.
    Stogy and dwollam like this.
  28. DDDenny
    Yeah, I didn't want to sound too excited, as you know you are my connection to those things, goes back near 45 years.
    Stogy, dwollam and porkshop like this.
  29. Marty Strode
    Marty Strode
    Got it rolling, since my center section isn't setup, I bolted in a greasy one ! Once I get the splash aprons back from the painter, I can set the the body on, and add fenders. IMG_1980.jpg IMG_1979.jpg IMG_1976.jpg IMG_1978.jpg IMG_1977.jpg IMG_1973.jpg IMG_1972.jpg
  30. Marty Strode
    Marty Strode
    Got the offset belt drive fuel pump system mounted today. IMG_1989.jpg IMG_1990.jpg IMG_1991.jpg IMG_1992.jpg IMG_1994.jpg IMG_1997.jpg IMG_1998.jpg IMG_2001.jpg IMG_2002.jpg IMG_2003.jpg
