Technical Winters Small Block 1966 Intake Manifold.
Discussion in 'The Hokey Ass Message Board' started by 1Nimrod, Sep 17, 2025.
  1. 1Nimrod
    1Nimrod
    Seen this Cool Chevy Tri-power with Holley Carbs for a Small Block, the intake manifold is by Winters, I can not find any information about it, was this a SHP Intake Manifold for the 327 or 302? casting date is 2-9-65 or 66
    Casting # 3896927 or 3696927 any one have information on this Intake Manifold.
    Dustin
    (1Nimrod) L70intake_01-scaled-e1636106318565.jpg L70intake_05-scaled-e1636108988455.jpg L70intake_04-scaled-e1636109552978.jpg
  2. DDDenny
  3. 427 sleeper
    427 sleeper
    It's probably the closest you'll ever come to seeing a Unicorn.
  4. SS327
    SS327
    Buy it at any cost! Hell, let me know where and I’ll buy it!
    Just Gary, Sharpone, 1Nimrod and 2 others like this.
  5. 1Nimrod
    1Nimrod
    That sure is interesting, what a great looking Winters Tri-power Intake Manifold for the Small Block SHP 1967 350 engine.
    That's what dreams are made of right there.
    It would've been something if GM had introduced the 1967 Camaro with the L70 350 360 SHP engine instead of the 302 360 SHP engine back in 1966.
    Thank You DDDenny Way COOL...
    Dustin
    (1Nimrod)
  6. Moriarity
    Moriarity
    SUPER MODERATOR
  7. 1Nimrod
    1Nimrod
    Big Bucks $$$$...
    If the price is right then @badshifter may sell that Small Block Chevy L70 Winter's Tri-power 3X2 bbl Holley Carb Intake Manifold, MAYBE ??
    Dustin
    (1Nimrod)
    Sharpone and bchctybob like this.
  8. Moriarity
    Moriarity
    SUPER MODERATOR
    I am quite certain that it is not for sale.....
  9. 1Nimrod
    1Nimrod
    So the 1st & 3rd Holley Carbs have Vacuum Pods is that how they worked? The 2nd (middle) Holley was the main Holley Carb that was used for starting bcuz of the Choke?
    What is the CFM of the Holley 2 bbl carbs on this Tri-power?
    Dustin
    (1Nimrod)
    Sharpone likes this.
  10. bchctybob
    bchctybob
    Too bad the aftermarket didn’t pick up on that and offer a similar manifold. Although it looks counterintuitive, like a set of Rochesters on a small block Ford, it sure fills the top of a small block Chevy with carburetors.
  11. RodStRace
    RodStRace
    Yes, the center is the 'primary' the outers are 'secondary'. I come from a Mopar background, but Chevy also did this on the big blocks. Probably lots of info out there on how they work, what the numbers are and such.
    Remember, CFM is calculated differently depending on how many barrels (venturi) are being pulled thru.
    https://www.jalopyjournal.com/forum/threads/2bbl-vs-4-bbl-cfm-flow-ratings.786212/
  12. 1Nimrod
    1Nimrod
    Carbking knows his stuff, he's the only one that has a REAL Complete Holley Carb Kit for my 1966 780 Holley.
    Bcuz the thread is older the first extra thread is not available now, wish there was a way to save the HAMB older information or retrieve the older threads somehow, a lot of excellent Car & Engine & everything else History is being lost one day at a time.
    Thank you for the Holley Carb CFM information.
    Dustin
    (1Nimrod)
  13. carbking
    carbking
    I would be very interested to know the list numbers of the carburetors.
    Thanks in advance.
    Jon
    427 sleeper, SS327, 1Nimrod and 2 others like this.
  14. DDDenny
    How about this one Bob.
    I think I would come up with a different filter/top setup though.
    https://www.hotrod.com/how-to/testing-holleys-new-small-block-chevy-tri-power-system
    SS327, 1Nimrod and Sharpone like this.
  15. RodStRace
    RodStRace
  16. 1Nimrod
    1Nimrod
    This part of the History of the L70 information from DDDenny may have listed the 3 2bbl Holley Carb List Number's but it only shows referral numbers no other information on those part's. Sure would be great to know right.
    Dustin
  17. 1Nimrod
    1Nimrod
    Sharpone and SS327 like this.
  18. RodStRace
    RodStRace
    @DDDenny and others let's take a look at that kit.
    The part number for the whole thing is discontinued.
    https://www.holley.com/products/discontinued_product/parts/300-521
    instruction sheet.
    https://static.summitracing.com/global/images/instructions/hly-300-521.pdf
    Under the Not Available kit, they have "We Suggest" the following:
    Weiand 3x2 Dual Plane Intake- Chevy Small Block V8
    Part # 7550 $749.95 (was $382 10 years ago)
    Fuel Line Kit - 3X2 Carb set-up
    Part # 34-51 $217.95 (was $110 10 years ago)
    Carburetor Linkage for 3X2 Carb set-up
    Part # 20-42 $274.95 (was $150 10 years ago)
    Holley website does NOT show the carbs used in this system. You have to search for part #.
    Center Part # 0-80683-1 REPLACED BY 0-80683-2 (N/A)
    Outers 0-80684-1 REPLACED BY 0-80684-2 (N/A)
    Yep, Holley no longer makes the carbs.
    I didn't bother with the filters.
  19. DDDenny
    And I thought I had too much time on my hands!
    1Nimrod, RodStRace and Moriarity like this.
  20. RodStRace
    RodStRace
    Hey, I opened your link and thought, cool.
    Then I scrolled to the bottom and saw they had all the parts and pricing. 2 grand. Too rich for me.
    Then saw it was 2015. Uh oh, I thought, how much is it now?
    Cue a search and the dawning realization that Holley, the company (IMHO) known for carbs but who has become a conglomerate run like a VC will still sell you the intake, the linkage, the fuel lines, the air cleaners but NOT THE CARBS! So I had to write it all out with part #s.
    Yep, a big waste of time.
    Hopefully someone else who might be interested will not waste their time trying to find one for sale.
    1Nimrod likes this.
  21. DDDenny
    Bob
    Disregard my post per your request about aftermarket tri power, apparently I didn't delve into it deep enough, Holley setup is NLA.
    SORRY
    RodStRace and 1Nimrod like this.
  22. RodStRace
    RodStRace
    1Nimrod likes this.
  23. 1Nimrod
    1Nimrod
    There is a HAMB member that ***embles then sells the Offenhauser, Edelbrock and a few other older Tri-power Intake Manifolds with the Rochester, Holley (and those older two bbl carbs 94?) Carburetors, he does all the plumbing and linkage, ready to run & have fun. Are all the accessories made by him or does he have a big supply of NOS part's. $1500-$2000+ in the parts for sale. I believe he has a few up for sale now. They look great.
    Dustin
    (1Nimrod)
    RodStRace likes this.
  24. RodStRace
    RodStRace
    1Nimrod likes this.
  25. 1Nimrod
    1Nimrod
    A single Holley Carb with your choice of many different Intake Manifolds sounds better after reading the part's list you looked up.
    Tri-power's have that COOL LOOK just like Dual 4 bbls do $$$$.
    Dustin
    (1Nimrod)
  26. RodStRace
    RodStRace
    @1Nimrod I think I'd trust a small vendor that builds a setup like you mentioned more than a huge company selling off the shelf stuff that may not have OE support after the sale.
    I agree that a multi carb setup has the looks, and the Hot Rod article Denny posted showed it developed a bit less top end but had more 'under the curve' torque, exactly what you want on the street.
    1Nimrod likes this.
  27. 1Nimrod
    1Nimrod
    I agree, I'd buy from a HAMB member first, he makes some mighty fine looking Tri-power setups.
    OLD REK $1500 for his Tri-power Edelbrock & Holley 94 Carb setup.
    He can build whatever you need. P1010030.JPG 5910830-a04872eec8ef3749f4eaa5077028c6b7.jpg 5910831-c524ee865aea78f4c0cbd63e08fd2e66.jpg 5910838-076cb996a37e620e2d360296a3e910c0.jpg
    Dustin
    (1Nimrod)
    SS327 and RodStRace like this.
  28. 1Nimrod
    1Nimrod
    Also HAMB member fordomatic has this sweet looking Ford FE 406 Tri-power setup 390 1961-64 $1400. 5918138-c29345fef422a972027c31bfa5c66b30.jpg 5918139-3cf5d663051d47fc323e443cbea37824.jpg 5918140-03800a8b5f64c8926f266e1712707665.jpg
    To bad this wasn't for a Small Block Chevy.
    Dustin
    (1Nimrod)
    Motorwrxs likes this.
  29. 1Nimrod
    1Nimrod
    And HAMB Member hotrodhoodlum has a Tri-power for a Chevy Small Block $675. 5916288-cee26ac65ff04a647bbba24417357fba.jpg 5916289-5a434465ed5d5e57012358e848457336.jpg
    Why Cool.
    Dustin
    (1Nimrod)
  30. DDDenny
    Everything is cool guys, I just wasn't paying attention, sorry.
    1Nimrod and RodStRace like this.
