Technical Is this ‘63 Impala too high
Discussion in 'Traditional Hot Rods' started by Eth727, Sep 18, 2025.
  1. Eth727
    Eth727
    IMG_8538.jpeg IMG_8537.jpeg Hey guys I just put a new front suspension and bushings, tie rods, etc.. I took it to get it aligned and the shop said the coils were too tall. I said just do the alignment the way it is.
    From these photos do you guys think it’s too high? I’m thinking of cutting off 1 coil.
    Thanks
    Sharpone and chevy57dude like this.
  2. Budget36
    Budget36
    Yes, too high. But let it settle for awhile, then take another look.
  3. Is the engine in it?
  4. DDDenny
    That would be a YES!
  5. BadgeZ28
    BadgeZ28
    from Oregon
    Yes it is if the engine is still under the hood. I think it has the wrong coil springs.
  6. Slopok
    Slopok
    Depends on what era you are going for, there was a time when that look was preferred!
  7. Johnny Gee
    Johnny Gee
    from Downey, Ca
    chevy57dude and Oneball like this.
  8. 69fury
    69fury
    from Topeka
    If it just had the front end worked on, I'd say it was tightened up before being set on the ground and the rubber is all bound up.
    -rick
  9. Eth727
    Eth727
    It has the engine. It was tightened on the ground. I bought the coils off rock auto for this year and model. They’re moog spring coils. I compared them to the stock ones and they were the same height. It did sit high before so I don’t know. I’m not spend more money for springs since I’ve got a cut off wheel and can remove a coil for a 2” drop.
    LCGarage and Sharpone like this.
  10. Doublepumper
    Doublepumper
    from OR-WA, USA
    Don't cut the springs...just put a bigger motor in it:D
    enloe, Thor1, flatheadpete and 7 others like this.
  11. Paladin1962
    Paladin1962
    Half a coil at a time... sneak up on it
    enloe, Sharpone, tractorguy and 3 others like this.
  12. DDDenny
    Yep, put some miles on them before cutting any more, they may settle some.
    enloe, flynbrian48, Sharpone and 2 others like this.
  13. Eth727
    Eth727
    It’s been a month or more since I had the new suspension. It was the alignment that just got done
    enloe and Sharpone like this.
  14. Eth727
    Eth727
    This is going to sound dumb but is there a top or bottom on the springs? Both ends look identical to me.
    Sharpone likes this.
  15. Eth727
    Eth727
    My car also has 15” wheels and 70 series tires
  16. Eth727
    Eth727
  17. Oneball
    Oneball
    I had some Moog coil springs for a Vette and the ends were a quarter turn out so that they didn't sit properly in the seats. The seats on the vette are shaped to fit the ends of the coil. The springs don't have flat ends. I'm not sure if I'm explaining it very well but it meant they were sitting on the lump of the seat. It was obvious the end of the coil wasn't in the same place when I compared them with the original one. Fixed by cutting 1/4 turn off.
    LCGarage, Sharpone and skooch like this.
  18. Texas57
    Texas57
    "springs for year and model"........I'm not familiar with Chevies, but here's some information that pertains to '57 Fords, which may or may not be relevant to your car. In '57 Ford used 9 (maybe 11??)different coil springs depending on accessories/drivetrain /model because they wanted all of their models to have the same ride height. Places like Eaton Detroit Springs have only 4 different coil springs available, so, how closely can 4 replace 11? Those 4 may or may not give a suitable ride height. Newer engines, like mine, may be aluminum, aluminum block, heads, intake, auto ****** case, etc, much lighter than even the original 6, plus weight distribution will make a difference also. Your current engine weight compared to original makes a big difference.
    With Ford front suspension, what you remove in height (not coils) will be approximately twice that drop at the wheel. (on mine cutting 1 1/4" off total height resulted in 2 1/2" drop.
    As mentioned previously, the removal should be calculated in inches, not coils.
    Coil springs normally sit in a pocket to stop their radial rotation, which is part of a spring's strength. On mine, the top of the spring is flat, but the bottom where it nests into the mentioned pocket is not
  19. guthriesmith
    guthriesmith
    All depends on the look you are going for, but I would cut a coil or two for my taste.
    enloe, Sharpone and chevy57dude like this.
  20. Rolleiflex
    Rolleiflex
    I'm not sure why this is a problem. :D
    enloe, primed34, Thor1 and 10 others like this.
  21. 325w
    325w
    Sets like station wagon springs
    phat rat and Sharpone like this.
  22. laidbackluis
    laidbackluis
    from Sachse Tx
    No there isn't. Just make sure the end of the spring sits on the coil-stops. Lower control arms and upper frame hats.
    You didn't order big block springs did you?
    Car is looking good man.
    enloe likes this.
  23. Eth727
    Eth727
    Thanks but it sits so high thieves could steal the catalytic converter.
    enloe, SS327, hotrodtodd1960 and 2 others like this.
  24. 57Fury440
    57Fury440
    I like it. You need some fender well headers and some slicks in the back.
    Rolleiflex, Sharpone and 427 sleeper like this.
  25. Moriarity
    Moriarity
    SUPER MODERATOR
    I would cut at least 2 coils off of them
    enloe, 63Biscuit, 38Chevy454 and 8 others like this.
  26. Budget36
    Budget36
    lol. I’ll take the under on it having a catalytic converter;)
    Springs won’t settle with a parked car, now that tge front end is aligned, put some miles on it. I’m sure it’ll settle some.
  27. Budget36
    Budget36
  28. High has 2 meanings with that car
  29. Johnny Gee
    Johnny Gee
    from Downey, Ca
