Technical Is this ‘63 Impala too high
Discussion in 'Traditional Hot Rods' started by Eth727, Sep 18, 2025.
  1. silent rick
    silent rick
    I wasn't looking at his neck man
    bobss396 and 427 sleeper like this.
  2. Kosmos55
    Kosmos55
    If you cut the springs in half it might sit right… of course the rear would need to come down ~10”.
    enloe likes this.
  3. Lone Star Mopar
    Lone Star Mopar
    Yup, I got a nosebleed just looking at the picture..
  4. Eth727
    Eth727
    So I ditched those moog springs are cut one coil off the original springs. Looks normal and rides better. Yeah stay away from moog springs. Post pics tomorrow
  5. big duece
    big duece
    from kansas
    Let's re-examine the meaning of "high"... love the whitewalls with Cragars. In the 70s our family car was a '72 Nova with Cragars and Sears whitewalls.
    anthony myrick likes this.
  6. ClayMart
    ClayMart
  7. bobss396
    bobss396
    I took 2 coils out of my '66 Belair springs. I got them from Rock Auto, name brand.
    The wire diameter was a little bigger than the stock ones, that could do it. 20250608_093817.jpg We tried one side. It was way too high.
    enloe, tractorguy and 05snopro440 like this.
  8. 05snopro440
    05snopro440
    Those MOOG springs were the right part number from what I recall when you were installing them. People here warned you that something was wrong at the time of initial install by your description that you were struggling to get them in with the car otherwise at full weight. It's always easier to sort out bad parts the first time.
    Now that you've changed springs and ride height it needs an alignment again.
    Did they ride stiff too? I've got a set of Moog springs waiting to go in my 62 Chevy. Generally, Moog stuff is very good. Maybe a mistake was made on that batch or part number.
    tractorguy and Moriarity like this.
  9. Eth727
    Eth727
  10. Eth727
    Eth727
  11. Cut a couple coils
    enloe, 38Chevy454 and Moriarity like this.
  12. MAD MIKE
    MAD MIKE
    from 94577
    Which part number did you use?
    6000, 6084, or 658A?
    Measure the free height of the spring as well as the wire diameter.
  13. Mr48chev
    Rock Auto shows a couple of choices for Moog springs for 63 small block Impalas A 658A in the heavy duty side for 9 p***enger wagons with air. or a 6000 for converts, hardtops or sedans without air .
    Are you sure that you don't have the station wagon springs?
    Back in the 60's when the jacked up in the front look was the hot lick it was common for guys with those Chevys to install a set of station wagon springs to lift the front end up but not use spacers or other nonsense. Screenshot (968).png Screenshot (969).png Screenshot (970).png
    tractorguy and big duece like this.
  14. big duece
    big duece
    from kansas
    I looked there also for the 6cyl application, same options. Thinking maybe with a spring for a lighter engine, it would settle down more with a v8. When I converted a '67 Camaro to BBC, I installed springs for a 396 car, but still had the 327 in at the time and the front end was raised until the engine swap.
  15. MAD MIKE
    MAD MIKE
    from 94577
    *Laughs in ~650lbs of Stovebolt.*
  16. big duece
    big duece
    from kansas
    Got me there... I figured the 6 would be lighter!
  17. Budget36
    Budget36
    Would a ‘63 have a 230?
    05snopro440 and Johnny Gee like this.
  18. big duece
    big duece
    from kansas
    Yes, they phased the stove bolt out in '62.
    05snopro440 likes this.
  19. Scott Younker
    Scott Younker
    Coil Springs Specialties in Kansas is the place to go for coil springs. They can dial up or down depending on your taste & application. I’ve used them a few times and they have always been spot on for me. Personally, that original posted picture reminds me of a Jr Stock 1/4 mile car look and I LIKEY!
    Super/Stock Poncho likes this.
  20. ekimneirbo
    ekimneirbo
    from Brooks Ky
    If you cut coil springs 1/4 of a coil, how will they sit properly in the little "seat" on the A frame ? Seems like it needs to be a complete coil. Maybe one cut at a quarter turn could be split between top and bottom seats for minor adjustment. :cool:
  21. RodStRace
    RodStRace
    Just needed to raise the back a little!
    enloe, 427 sleeper and 63Biscuit like this.
  22. This is a Hot Rod and Custom car site, "Low Riders belong somewhere else, not here, They are neither Rod or Custom
    Oh Boy here comes the "Heat" !
  23. captaintaytay
    captaintaytay
  24. DDDenny
    Yeah, what up widat?
    SS327 likes this.
  25. 550Coupe
    550Coupe
    Looks like an early sixties Super Stocker. I like it.
    enloe and 65pacecar like this.
  26. I am sure I am late to the party I see you replaced the rebuilt the front end and replaced the springs did you do replace or rebuild any part of the rear suspension?
    If not, the front end may not be high the rear end might be low (sagged)
  27. lostn51
    lostn51
    from Tennessee
    I love the way you are going with this car, it’s looking really nice and would love to have it sitting in my driveway :D
    bobss396 likes this.
  28. 38Chevy454
    38Chevy454
    In my opinion the question should be "is this too low?" And the answer is always no.
    Even after you cut a coil, it sits too high for my preference. Cut another coil.
    63Biscuit likes this.
  29. 63Biscuit
    63Biscuit
    from Hudson, WI
    I'll admit I'm biased, but I think '63 Chevies look best really low. This is how mine sits now...and it was lower until I moved over to disc brakes which required me raising the front end about an inch due to fender rub.
  30. 05snopro440
    05snopro440
    I went with the CPP "original offset" front disc kit so it didn't kick the tires out like basically every other kit. Didn't need to raise the front, I'm tucking the whitewall on 15's on my 62.
    enloe likes this.
