Hot Rods Ignition wire gets hot while driving
Discussion in 'The Hokey Ass Message Board' started by drumyn29, Sep 18, 2025.
  1. drumyn29
    drumyn29
    I built a truck for my 16 year old daughter and my Ignition wire gets hot while driving and then it doesn't start unless I jump the wires at the starter. Thoughts please!
  2. MCjim
    MCjim
    from soCal
    Nice truck...what are you calling the ignition wire? Can you be a bit more specific.
    05snopro440 and chryslerfan55 like this.
  3. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    We talking about the wire going to the coil from the ignition switch?
    If so, then it may be a resistor wire to cut down voltage kinda like a ballast resistor.
    If we talking about the coil wire from the coil to the distributor then you really have me scratching my head. :D
    hrm2k and chryslerfan55 like this.
  4. RodStRace
    RodStRace
    Circuit is too small to handle the load, poor ground or connection, or if points style ignition and this is the feed, no resistor as mentioned.
    I'd also check the charging system output.
    Since you have the time in here and the skills, first place I'd check is the ignition switch itself. I'm sure you will be back to report your findings.
    This is the basic layout, but shows the Ford relay. Ignore that.
    hrm2k, 05snopro440 and chryslerfan55 like this.
  5. Ignition huh? Don’t get me started. Hehe.
  6. drumyn29
    drumyn29
    I'll try to be more specific. I only took a quick look today and it seemed like the Alternator wire was getting hot but it could also be the coil wire as well. It has a one wire alternator and an HEI distributer on a SBC. No resistor wire or ballast anywhere in the system.
  7. 19Eddy30
    19Eddy30
    from VA
    What size ga of wire on "Stud "
    Of alternator down to starter stud or bat cable " Hot" .?
    Should be @ least a #10 ga
    with 100 amp Alt ,
    When charging what the volts showing
    13.7 -14.2 v .
    Bigger amp Alts can be #8 ga some times #6 ga
    Key in dash or on column ,
    What size #ga wire powering the
    Coil on HEI ,?
    What size ga Ground & Hot to battery,
    & how far battery from starter?
  8. winduptoy
    winduptoy
    hot is as a result of resistance to the homotron flow.....'loose', corroded connection or too small of a conductor (wire) can be the culprit
    good luck
  9. RodStRace
    RodStRace
    Recent change or since built?
    Alt wire hot = too much flow (check output) or if just built, too small wire.
    Direct to battery or routed thru other things? Check other things.
    Ignition wire hot plus no start when hot still points to switch.
    Also check alt output and battery condition here. Headers?
    Check voltage during crank cold and hot.
  10. hrm2k
    hrm2k
    I'd be checking all your grounds making sure they are good
    MARKDTN, RICH B and RodStRace like this.
  11. jaracer
    jaracer
    You have to be way more specific to get any meaningful help. There is no coil wire in your setup (HEI). What happens when it doesn't start? Does the starter turn over? What wires is it you are jumping at the starter?
    If a wire gets hot during normal operation it means it is too small a gauge to handle the current load. If a connection gets hot, it points to high resistance at that connection.
    hrm2k likes this.
  12. Wanderlust
    Wanderlust
    Scratching at an old memory from the late 80s, check the insulating disc under the coil pack on top of hei, they break down and voltage starts to stray, cooked the ground wire good and proper on mine, replaced the complete cap less the coil and the ground wire needed a chunk replaced as well
  13. Mr48chev
    Screenshot (1004).png What did they use for a connector on the igniton wire to the distributor. It has to have a correct Hei clip on the wire and the wire has to be the correct gauge to handle the load.
    The HEI doesn't use a ballast resistor or resistor wire as it needs a full 12 volts all the time.
    When I first stuck an HEI in my 71 GMC I went Joe Cheap and used a female slide and length of wire and the female slide would get just loose enough to loose contact but still be kind of connected especially when it rained and I was on the way to work at 3 am. I'm thinking that the wire was probably too small of a gauge too as I just grabbed a female slide terminal out of my termainal box and used some wire I had.
