Projects Little Truck Doctors 51 Ford Gasser
Discussion in 'The Hokey Ass Message Board' started by LittleTruckDoctor, Sep 11, 2025.
  1. duecesteve
    duecesteve
    If it's wired by Lucas stuff gets warm and can go bad ? That's why beer is warm in England and Ireland?
  2. Me and Andy are constantly talking ford/ Chevy **** (notice I didn't capitalize ford) but my shop fridge is a 1962 ford philco. He likes to remind me :D
  3. That old Philco cools damn good, but it probably drinks the electricity!!
  4. Both springs are mou ted and the axle is mocked up. 20250919_184748.jpg 20250919_184736.jpg
    bchctybob, enloe, saltflats and 20 others like this.
  5. enloe, porkshop, Sharpone and 4 others like this.
  6. 1st hub is mocked up and the front tires are mounted Thanks Lloyd's paint and gl*** 20250920_135123.jpg 20250920_135114.jpg
  7. chevy57dude
    chevy57dude
    That 'axle is looking good!
    enloe, porkshop, Sharpone and 5 others like this.
  8. C'mon Chandler, these guys like mock up pictures like your pop sent me! Screenshot_20250920_165921_Gallery.jpg
  10. Robdski
    Robdski
    Good looking project you have there, young man.
    Thanks for sharing your progress.
    I also would like to compliment your clean, safe workspace.
    Keep up the great work.
  11. hotrodjack33
    hotrodjack33
    Yeah I agree, I'd have every tool I own spread all over the floor...even ones that I didn't need LOL
    bchctybob, enloe, Budget36 and 7 others like this.
  12. Wanderlust
    Wanderlust
    Ya but when you’re down there it’s easier to just scrabble around than to crawl out, get up and go to the toolbox and forget what it was you needed o_O
    bchctybob, enloe, seb fontana and 9 others like this.
  13. swade41
    swade41
    from Buffalo,NY
    You welded the springs in solid already, how did you mockup shackle angles ?
    If those are the Speedway springs they are really stiff, I ended up removing half of them on my Henry J before it got any travel.
    bchctybob, enloe, ffr1222k and 7 others like this.
  14. alanp561
    alanp561
    Did you mention chevy ****, I didn't notice. BTW, the other brand you mentioned is spelled FORD.;)
    enloe, Okie Pete, Sharpone and 5 others like this.
  15. Apparently not, they already had to redo it once when the shackles went horizontal lol. Last 2 speedway straight axle kits I've bought have had damn good springs.
  16. We didnt weld the springs we bolted them in place
    bchctybob, enloe, Okie Pete and 5 others like this.
  17. The spring brackets were not welded in. They are bolted in. Lloyd is correct, we had to go back and adjust the position of the shackle brackets. No big deal. Adjusting things is part of the build process.
  18. Get your facts right before criticizing
  19. Sharpone
    Sharpone
    Well you corrupted the young fella, turnabout is fair play. His turn to corrupt you! A FE would look cool in the wagon;):eek:
    Dan
  20. Sharpone
    Sharpone
    Oh and welcome to the HAMB @LittleTruckDoctor, I’ll be following along!
    One thing you’ll notice is that there are a lot of opinions on this site, however with the opinions is an incredible amount of knowledge and skills.
    Dan
  21. 1971BB427
    1971BB427
    from Oregon
    Suggestions shouldn't be taken as criticism. Try not to be so testy please. Setting up shackle angles, and kingpin angles shouldn't be done until the engine and full weight is on the ch***is. Doing so prior to having curb weight on the car will usually result in having to change or adjust them later, which is often difficult. Everything should be temporarily located until full weight is on and you can check proper angles before making things permanent.
    bchctybob, SS327, Okie Pete and 10 others like this.
  22. alanp561
    alanp561
    This is NOT a criticism!
    Are there only two bolts holding the hanger bracket? Did you stiffen up the frame where you bolted the hangers in place? I would make and fit 1/4" strips the width of the inside the frame where your hanger bolts are and make them long enough that you could get a bolt in front and behind your hanger bolts at least as far apart from the existing bolts as the distance between the existing bolts. This is crude drawing, but I'm sure you get the idea. There's a lot of stress on that 75-year-old frame where that hanger is and you don't want the bolts tearing through the frame.
  23. Thank you Alan! That is a really good idea, we will work on it. Easy to do and I should have thought of it too.
  24. hotrodjack33
    hotrodjack33
    Yeah, and getting up off the garage floor requires a little "thought process" pre-planning these days:(
  25. swade41
    swade41
    from Buffalo,NY
    Oh to be a know it all teeny bopper again lol
  26. I will definitely do that thank you for the advice
  27. deathrowdave
    deathrowdave
    from NKy
    I think I would have installed shackle end on front perch . But not 100% sure thats correct either
  28. There’s been much debate on shackle placement. We consulted several people and the rear was the consensus.
    enloe, 57Fury440, alanp561 and 5 others like this.
  29. duecesteve
    duecesteve
    Nosebleed lol
  30. 1971BB427
    1971BB427
    from Oregon
    Almost every g***er or straight axle installation I've done I put shackles at the rear. But my theory is I also put steering boxes ahead of the axle, so I want my drag link to be the same side as the fixed spring eye so I'm not pushing-pulling against the end where the shackles can deflect. So if I put the steering box behind the axle, I'd have that end as the fixed spring end, and shackles up front. Or vice versa if steering is ahead of the axle.
    I like steering boxes ahead just to make sure my steering box isn't sharing space with headers, or other things behind the axle.
