Hot Rods The Belly Button Bucket Build Thread
Discussion in 'The Hokey Ass Message Board' started by Tim_with_a_T, Dec 2, 2015.
  1. RodStRace
    RodStRace
    Quick search found this, a spreadsheet of cars with the power to weight calculated.
    https://docs.google.com/spreadsheets/d/1p-jge5s6bpDC6OgjUU69sSgiat9_nnaM_HzHuDkL03I/edit?gid=0#gid=0
    Caterham (#6) is probably the closest. Figure your car weighs ~2000 pounds, probably less. Guess the power is 400 plus, maybe 350 at 5K RPM, depending on the curve. I don't know how high you are revving it.
    The math is pretty simple! It should scare you for a while. Might even be a permanent condition.
    Just Walter Mitty yourself as taking it thru the gears like a wild man.
  2. DDDenny
    If it doesn't scare ya a little..........it needs more engine!
  3. Dave G in Gansevoort
    from Upstate NY
    So, you say that the pucker factor kicks in…
  4. Tim_with_a_T
    Tim_with_a_T
    Pure benching here- not a lot of data to support this. That cam, head, cubic inch, and compression combo has made 425hp in magazine builds with a Performer RPM air gap and 750 Holley. I did EVERYTHING I could think of to max out the tri power, short of cutting the throttle shafts, boring Venturi size, machining boosters… you know- the stuff that would keep me from getting the car on the road to infinity. But I’m guessing the tri power is down 25hp from the Air Gap, and I think that’s a safe ***umption. I scaled the car awhile back- 1600lbs. So let’s say 1800lbs with me in it, 4.5lbs/hp. The other element of fear factor is EIGHTY EIGHT INCH WHEELBASE and open air, which is quite a visceral experience LOL.
  5. Dave G in Gansevoort
    from Upstate NY
    Wild Willy, Terrible Tim! I’m just saying…
  6. Tim_with_a_T
    Tim_with_a_T
    Seems like that table is off by a factor of 100, unless I’m not understanding something. Power/Weight for any of those cars in the table is actually Power/Weight * 100 to match what the table shows. So for that math, the T is 22.22. I think being in an open wheel roadster with an 88” wheelbase plays just as much of a factor as the power to weight, though!
  7. RodStRace
    RodStRace
    I usually use pounds to HP also.
    Say a 4000# Charger with 400 HP hemi = 10 pounds per HP.
    Caterham is 1200 with 310. See K column = 3.87.
    Column H is used to set order, but is very closely related to K (decimal point stuff).
    Yours as you say is 4.5. Very close to a Bugatti, but more than the Ferrari.
    The wheelbase is a factor, along with probably 4 inch total front suspension movement!;)
  8. RodStRace
    RodStRace
    Either way, that puts you and the car solidly in the Platinum category.
    Top Fuel Drag Car
    Koenigsegg One:1
    Yamaha R1
    Yamaha R6
    Bugatti Veyron SS
    Caterham Seven 620R
    Bugatti Veyron
    Tim's Belly ****on
    Ferari 458 Speciale
    Dodge Viper
    Lexus LFA
    Shelby Mustang GT500
    Porsche 911 S Turbo
    I'd imagine a tri power Nitrous system is far down the list for now.
  9. Dave G in Gansevoort
    from Upstate NY
    6-71 GMC roots blower, Hilborn injection and nitro with a touch of hydrazine. Ok, maybe the hydrazine is just a little too much…
    Sharpone, Tim_with_a_T and RodStRace like this.
  10. DDDenny
    I was told there would be no math today!
  11. Dave G in Gansevoort
    from Upstate NY
    Just mayhem
    Sharpone, RodStRace and Tim_with_a_T like this.
  12. Tim_with_a_T
    Tim_with_a_T
    Made it to a local tech school car show this afternoon- showed up fashionably late and left early but it was a good time! Car did great! I have no way of accurately measuring fuel consumption, but it seems to be doing really well in that category as I haven’t had to fill up yet, and I’ve got about 1/2 tank now.
  13. Dave G in Gansevoort
    from Upstate NY
    Tim, how do you like the height of the windshield?
  14. Tim_with_a_T
    Tim_with_a_T
    Windshield is pretty decent. Close up I look through it, far away I look over top. Sungl***es help the eyes from watering above about 55mph, which is about the speed my eyes would water downhill skateboarding lol. Gf has long hair, and didn’t like going faster than about 45 because her hair would whip around everywhere. Mom has shorter hair and didn’t seem to mind the wind. I think visibility with a top on will be compromised, but aesthetically I like the shorter windshields.
  15. Tim
    Tim
    from KCMO
    There’s a T with a top I see running around here now and then that has a clear panel above the windshield. No doubt to see the stop lights and etc.
    glad you’re having fun with it!
  16. Tim_with_a_T
    Tim_with_a_T
    I was thinking about this exact thing today. If you ever get a picture of it, I’d like to see it!
    porkshop, RodStRace and Tim like this.
  17. DDDenny
    Tim
    You need to buy your girlfriend a scarf rated for over 45 mph, time to remove the egg from under the gas pedal.
  18. RodStRace
    RodStRace
    Hooded top works for me. The old archive videos showed many ladies wearing them, more than scarfs.
    Sadly, they were taken down.
    Sharpone, porkshop and Tim_with_a_T like this.
  19. Tim
    Tim
    from KCMO
    Pony tail tucked into your jacket works too. I have a lot of motorcycle riding friends with very long beards and they’ve found if you don’t tuck it away that it will actually get “wind burnt” and break off the hair. Never mind that having all that hair in your face doesn’t help you see lol
  20. RodStRace
    RodStRace
    True, but you still need a ball cap, hat, scarf or something on top to keep strands from working loose. Just cruisin' the grounds. peoria2.jpg
  21. DDDenny
  22. Dave G in Gansevoort
    from Upstate NY
    Cold weather welders caps. The ones that have ear flaps and snap under your chin. Plus they can be had with crazy patterns…
  23. DDDenny
    I'm betting it's not Tims' hair that is the concern!
    A bit of a story (told before I'm sure).........
    In the late 70's a friend of mine had his T-bucket about 90% done, around Christmas he calls and says put a coat on I'll be there in five minutes, shows up, no windshield, open headers on a hot 327/4 speed and a pair of milk crates to sit on and NO SEAT BELTS.:eek:
    We had hair then but it was the least of our worries.
  24. Man this thing rules! Congratulations on getting it on the road and thanks for the videos!
  25. Dave G in Gansevoort
    from Upstate NY
    Ah, the carazy things that we did in our youth! Seatbelts? We don’ need no steenkin seatbelts! H3// we don’ got no steenkin seats!
  26. RodStRace
    RodStRace
    1977 milk crates?
    @DDDenny I'd guess they were the all plastic ones that would slip very easily upside down. I'd hope they were the old metal wire ones for your safety, but since you lived to tell the story, either way!
  27. Dave G in Gansevoort
    from Upstate NY
    Hay bales work too. Don’t ask…
    Sharpone, Tim_with_a_T and porkshop like this.
  28. DDDenny
    Ha!
    Can't remember what I ate last night.
  29. Tim_with_a_T
    Tim_with_a_T
    Small update- had some glazed pads that were producing a horrible squeal, so my dad and I took them off, scuffed them and the rotors, back on - same squeal. I had some different compound pads in the attic, so I put those on after they left. Went down to an industrial area to bed the pads…. And managed to rip a caliper bracket off the car. That was interesting. I was by myself in an empty parking lot, so no harm done. Got the caliper tucked behind the headlight and limped it home on the emergency brake. After thinking about it for a couple days, I bet I never had that tight from when I put the brakes on the car however many years ago.
    Fast forward to today, last day of local cruise in for the year. My brother and I had planned to go in the T, but I needed to fix the brakes to get there. Not the best do***entation, but new bracket was made and we made it to the show! This car is a riot to drive, and I’m glad I got to go to the show with my brother today. I let him drive home from dinner- he was pretty stoked when we pulled into the driveway. Driving hot rods is pretty fun!
    BigJoeArt, enloe, Tim and 12 others like this.
  30. mohr hp
    mohr hp
    from Georgia
    That caliper bracket is scary as hell! You got extremely lucky. There just wasn't nearly enough edge distance around those holes, needs more meat! Please be careful out there learning how to drive this thing. My first hot rod at 18 weighed 2000 pounds, had a 454 and an 84 inch wheelbase. I drove it 2 weeks and wrecked it. A wise man told me, "That throttle works both ways, doesn't it?"
    Sharpone, GuyW, Dick Stevens and 3 others like this.
