Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. grdra1
    grdra1
    Nearly finished fabbing headers for my 34, Glen f77d2019-b5be-4472-94cf-ca207d7723ed.jpg fc5e54c1-44b0-471c-a6ad-f1346ba4a1b2.jpg
    Paul, impala4speed, porkshop and 13 others like this.
  2. 5w Jen
    5w Jen
    from Sweden
    We continue working on the '33-34 Ford frame. The rear bends are fully welded, the right rail still needs a bit straightening. We built in a 6" kick-up over the rear axle. Also working on the box plates, welded in six M12 (1/2") nuts for a bolt on X-member. L1020846.JPG L1020847.JPG L1020850.JPG
  3. swade41
    swade41
    from Buffalo,NY
    I worked on extinguishing flames !
    Doing rear brakes on the T yesterday I use a plastic tub to catch the brake clean I use with a long stiff bristle brush to clean things with. The brake clean itself was evaporated today just leaving the brake dust stuff in the tub.
    I had the tub behind where I was working by a good 3 1/2 feet, next to the go-kart ch***is.
    Grinding rivits on the front drums today, pointing sparks directly at the floor as to not spray them all over the place. I'm wearing shorts and I feel heat on my leg, I'm thinking there's no way I set myself on fire. I set the grinder down and look at my shorts and socks, no fire so I look behind me and hot damn, that tub is on fire.
    I mean really on fire, the entire inside of the tub is spewing a 2 1/2 foot tall flame higher than the go-kart gas tank. I'm thinking that's a vented cap those flames are right next to, I grab the tub to move it outside, but it's real pliable, I'm thinking that thing has been burning awhile.
    So I slide it over in between the Henry J and go-kart, not a lot of free space for these flames to go, my first thought was grab the fire extinguisher and that's never a first thought for me, but that thing is cooking !
    So on the way to the fire extinguisher I see a towel so I decide to smother the flame instead, then tossed it outside. That tub was really thick plastic not easy to turn pliable, sure burnt the **** out of that long bristle brush.
    So be careful out there guys.
    alanp561, porkshop, BigRRR and 12 others like this.
  4. Greg Rogers
    Greg Rogers
  5. 1971BB427
    1971BB427
    from Oregon
    You're lucky you didn't get poisoned by the fumes of burning the residual brake clean in the tub! That stuff is nasty when heated, and deadly too!
    porkshop, Sharpone, Rickybop and 4 others like this.
  6. 1971BB427
    1971BB427
    from Oregon
    I was doing some simple maintenance on my '39 Chev coupe and cleaning the differential cover when I happened to look at my driver's side rear spring shackle. I have new springs I installed 4 years ago, but still use the old threaded spring eye bolts that screw into the spring eyes. The ends of those bolts are threaded and have a 90 degree zerk fitting to grease the threads inside the spring. The bolt had unthreaded itself about 3/4" And nearly pulled out of the outside shackle bar! Only thing that stopped it was that 90 degree zerk fitting or it would have come completely off.
    I jacked the car up to unload the springs and removed the center bolt that holds the two shackle plates together, and removed them. The threaded center bolt has tapered ends like a Morse taper for a chuck, so I grabbed the exposed end with vise grips and screwed it back in place. Reinstalled the plates and cinched the retaining bolt down as tight as I could without snapping the 5/16" bolt. Thought about putting some Loc***e on the tapered ends, but decided to leave that off and just keep an eye on it in the future. If it tries to back out again I'll put some blue or red Loc***e on the tapered ends.
    porkshop, Sharpone, 61Cruiser and 4 others like this.
  7. Dick Stevens
    Dick Stevens
    I would recommend orange Loc***e as it holds better than blue and is still removable.
    porkshop, Sharpone, 1971BB427 and 2 others like this.
  8. earlymopar
    earlymopar
    Never heard of "orange Loc***e". Red yes.
  9. Dick Stevens
    Dick Stevens
    porkshop, Sharpone and GuyW like this.
  10. winduptoy
    winduptoy
    Working on straightening out some Holley 94's on this buggy...
    It hasn't been on the road yet...but he is getting close....
    Has a Yblock that came out of @metalman '57 Rancho....
    IMG_20250917_092753624.jpg IMG_20250917_102735284_HDR.jpg IMG_20250917_140504824_HDR.jpg IMG_20250917_140514676.jpg
    porkshop, Sharpone, swade41 and 16 others like this.
  11. 51504bat
    51504bat
    Finally getting some stuff done on the wagon. Doubt it will be driving before the first of the year but hoping for some shake down runs before next summer. All in anticipation for LF4:cool:
    porkshop, BigRRR, Sharpone and 16 others like this.
  12. Adriatic Machine
    Adriatic Machine
    Weighing my options for the Rzeppa joints on the driveshaft of my Pullmax P6. They’re making noise when the gearbox is shifted to an offset position. The rear joint looks fine but the front is showing some wear and definitely some metal to metal contact where there should be none. If I can get off work I’ll bring the ***embly to the drive shaft shop and get his opinion. Plan B is to do some light machining to touch up the pockets and replace the 3/8” balls with some 10.5mm. This is a bummer because I had the machine sold until I noticed the noise.
  13. alanp561
    alanp561
  14. Rickybop
    Rickybop
    Getting a real workout the last few days with the grinder, wire wheel and sanding disc, repairing and refinishing my welding table. Flipped it over in the yard so I can do the underneath parts.
    Same with the shelving unit over yonder. Flipped it over cuz I'm gonna trim the gussets and shorten the legs to get the upper shelf to a reasonable height so I can use it for a workbench. A couple repairs and some paint and some good quality plywood for the work surface.
    Then it's the big steel cabinet's turn.
  15. Robdski
    Robdski
    After finishing the ch***is and screwing up the transmission, I decided to start get the body mounted and start the bodywork. This will be enough to keep me busy all winter. IMG_3724.jpeg IMG_3946.jpeg IMG_4098.jpeg IMG_4097.jpeg IMG_4101.jpeg
  16. swade41
    swade41
    from Buffalo,NY
    I dug the T out of the corner after doing brakes all around and drove it over to my son's work for the annual inspection.
    I think that was the first time for driving it anywhere this year, nice 70 degree day for it too.
  17. JohnLewis
    JohnLewis
    IMG_2158.jpeg Stripping down the hood. Aside from uncovering the old patch repair. Found an old flame job.
    alanp561, enloe, saltflats and 8 others like this.
  18. Rickybop
    Rickybop
  19. ladyhrp
    ladyhrp
    That looks nice.
    Sharpone, enloe, osage orange and 2 others like this.
  20. JohnLewis
    JohnLewis
    Wish I could just find something that makes me money lol.
    Sharpone likes this.
  21. 51504bat
    51504bat
    Thanks @ladyhrp but it will never be as nice as yours.
    osage orange likes this.
  22. 1971BB427
    1971BB427
    from Oregon
    I'm not getting any younger, and my 26 year old granddaughter wont have me around to repair and maintain her late model OT car. So yesterday she asked me to check her brakes, and I told her to come over and bring her "work clothes". She arrived ready, except for glove, which I supplied her on arrival. Got her car jacked up and told her to remove center caps on the factory mags, and start removing lug studs. (No lugnuts on her car, just conical studs.)
    Then we went wheel by wheel as she has 4 wheel disc brakes, and she replaced pads at each wheel. Seemed to actually be enjoying it, and I told her if she's still planning on getting my old Austin g***er when I'm gone she better keep learning. I'll call her to help the next time I'm working on it and she can help me too!
  23. Paul
    Paul
    Editor
    good on you to raise them right.
    'have done similar with my daughter,
    she's 41 now and has the mindset and skills to tackle most anything on her car or house
    of course being her dad I never say no when she asks, and she knows she needs to be there too.
  24. 1971BB427
    1971BB427
    from Oregon
    I tried with all 5 of our kids, and so far it only took with two. My oldest is a real car guy, and was out helping me when he was in diapers. Youngest daughter is also a car gal and knows things. But the other two girls and a boy would sell a car if the battery went dead. Fortunately my granddaughter can do more on cars than her mother, and is really mechanically inclined.
  25. HOTRODPRIMER
    HOTRODPRIMER
    Don't sell yourself short, right now it looks a lot better than Brenda's Ranch Wagon, but we finally found the right guy to help get it back in shape. HRP
    Sharpone, Okie Pete and Dick Stevens like this.
  26. henry29
    henry29
    RMcCulley and Okie Pete like this.
  27. Paul
    Paul
    Editor
    the '53ish Chevy spindles were fairly common on the aftermarket axles
    may still be.
    I liked them for their no honing required bushings
  28. swade41
    swade41
    from Buffalo,NY
    Yes Chevy spindles
    deathrowdave and Sharpone like this.
  29. atch
    atch
    Just dropped off Clarence's drive shaft to have the balance checked; and rebalanced if necessary. He has developed a vibration from about 60 to about 70 mph. Might be drive shaft or perhaps something else.
    If drive shaft isn't the problem I'll move on to other suspects.
    It started years ago but was almost negligible. It is getting more noticeable. All wheels and tires are different from when I first noticed it.
    Pinion seal is leaking so I'm going to rebuild the punkin this winter. Including new ring/pinion gears, seals, bushings/bearings, etc. I doubt that the vibration is coming from there but it's getting done for other reasons anyway.
    When I get the drive shaft back and test drive it I'll let you know if that eliminated the vibration.
    Tim, Stock Racer, Sharpone and 8 others like this.
  30. atch
    atch
    Was back under there checking things out and discovered that the pinion bearing is shot; it's got wobble in it.
    So out comes the 3rd member, hopefully before bedtime tonight. Driveshaft might or might not be out of balance. If it is then it probably caused the pinion failure. If not the bearing just failed.
    Since the axles will have to be pulled I'll install new seals on them as a precautionary measure. Maybe bearings too.
