Technical Is it snake oil?
Discussion in 'The Hokey Ass Message Board' started by Dave G in Gansevoort, Sep 21, 2025.
  1. Dave G in Gansevoort
    from Upstate NY
    Watching the F1 today, and saw signs for Liqui Moly. I’ve seen it advertised in old magazines, probably back to before I learned to read. (Don’t ask, it’s been a few years…).
    So I’m just curious about it. Has anyone ever tried it? Did you think it was snake oil or something worth using? I’m not going to try it, just thought I’d ask the question
  2. PackardV8
    PackardV8
    A high school friend was for forty years a petroleum engineer at Chevron. Want to make him attack you physically? Just try putting Liqui Moly, Marvel Mystery, STP, Wynn's or any of the snake oils in with his motor oil.
    "Chevron, Mobil and the other major brands have spent millions of dollars and a hundred years making the best motor oils possible. You realize the snake oil con artists don't have refineries? They buy their feed stocks from us. If that ****e was any good, it would already be in our oil, essentially for free. That they can convince buyers to pay $10 a can for it just boggles the mind!"
    jack vines
    Blues4U, Wobbly, saltflats and 17 others like this.
  3. Sharpone
    Sharpone
    While I agree with you on not using additives with premium brand motor oils on good solid engines. I know for a fact that some of the “snake oils” do in fact work. I have used MMO in engines with stuck or noisy lifters and stuck rings with good effect, basically a last ditch effort. I have also used Lucas Oil additive in an engine that had very low oil pressure brought the pressure up to a safe level. I drove that to work car for months then I gave it to my daughter and she drove for a while before selling. Without the Lucas I’m sure the bearings would have been destroyed.
    I think that using these additives on a sick engine to get a few more miles is ok.
    No reason to use on a good engine IMO.
    I have not used Liquid Moly additives but I believe their oils are very good.
    Dan
  4. rockable
    rockable
    There are companies like Ethyl Corporation whose business is to develop additive packages for motor oil companies. They have dyno cells running round the clock and then they tear the engines down to inspect for wear. As PackardV8 said, if they could make it better, they already would have. Some of the fuel additives may have some merit but I stick with quality products and dont buy additives.
    Driver50x and Sharpone like this.
  5. hotrodjack33
    hotrodjack33
    Back in the '90s there was a product callled Moly Black Gold...and they even sponsored Jimmy Spencer's #98 NASCAR Cup Car.
    The premise was based on the superior lubrication properties of molybdenum as an oil additive.
    It must not have worked that good because the company seems to have disappeared.
    Incidentally, the U.S. Navy in WWII used a molybdenum ****tail brushed on the turret tracks of large guns so they wouldn't rust up and would turn/spin freely.
  6. Dave G in Gansevoort
    from Upstate NY
    The only time I used one, STP the old stuff that Andy Granatelli advertised, was in gear oil for the dirt car. It did something, because we were having temperature control issues, added a single can of that goo, and the temperature dropped over 100 degrees f. I used temperature labels on the quick change case, same spot every time. Btw don’t ask where they came from…
    This was with no other changes, just the gear oil and STP. NEVER used it for anything else, just the quick change.
    saltflats, Sharpone, jet996 and 2 others like this.
  7. gimpyshotrods
    gimpyshotrods
    Li****oly is not a "thing". Li****oly is a German petroleum products company.
    I run one, or another of their oils in most of my vehicles. I have been using their fuel system cleaners for almost 40-years, with great success.
    saltflats, big john d, rod1 and 6 others like this.
  8. 1934coupe
    1934coupe
    Funny you mentioned putting STP in the transmission. I tried that when I was a teen and had a 57 Chevy with a Muncie 4 speed. Well in the winter time on LI I could not get the car in gear until I ran the car in neutral for 3-4 minutes. Shifted great though after it got warm. Geez what we didn't do when young and knew everything.
    Pat
    saltflats, SS327, seb fontana and 3 others like this.
  9. Dave G in Gansevoort
    from Upstate NY
    Now that is what I wanted to know. Thanks.
    Sharpone and chlsnk like this.
  10. caprockfabshop
    caprockfabshop
    I almost exclusively use Li****oly in my 2016 VW GTI, but that's because it requires Euro-Spec oil with specific additives. On older HAMB cars, I think in the case of most of their additives like the Lifter Additive, Engine Flush, Radiator Cleaner, Injector Cleaner, etc... They all have their purpose, and do as good of a job as any other company's products. I would of course say, that if you're trying to use any kind of additive to repair or restore engine performance or to stop symptoms of an issue, that you're putting a band-aid on it. Almost always going to pop up again or even escalate. I know guys that limped an oil burning engine along for decades, when a simple re-ring/valve job would've fixed their clouds of blue and oily bumpers...
  11. gimpyshotrods
    gimpyshotrods
    I just changed the oil in one of the shop vehicles.
  12. Sharpone
    Sharpone
    IMG_3526.png Dave are you talking about something like this?
    Holy smokes they have a lot of additives
    Dan
    tractorguy and porkshop like this.
  13. gimpyshotrods
    gimpyshotrods
    https://www.liqui-moly.com/en/produ...ch and development,contain 10% more than that.
    Sharpone likes this.
  14. Dave G in Gansevoort
    from Upstate NY
    Oh man, see what I started? I really was just curious about the brand. I’m educated about it now.
    saltflats and Sharpone like this.
  15. Sharpone
    Sharpone
    Gotta love the OIL rabbit hole :rolleyes:
    Dan
  16. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    Whoohoo snakes revival time!
  17. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    I have used the gear oil additive from them in a Model A and was astounded how much better the crash box shifted.
  18. lostone
    lostone
    from kansas
    I wonder how their rear end oil is ? I like the idea of less friction = less heat...
  19. DDDenny
    But will it make your hair grow?
  20. CSPIDY
    CSPIDY
    MMO
    I put that sheet in everything
  21. woodiewagon46
    woodiewagon46
    from New York
    About 30 years ago there was an article in one of the car magazines, Road and Track or Car and Driver, that did a study on oil additives. They enlisted a NYC taxi company consisting of 24 cars and added different types of additives to some cars, 5000 mile oil changes to some, 7500 mile oil changes to some and 10,000 mile oil changes to some. After 150,000 miles they compared the wear results and found the cars with 5000/7500 mile oil changes did the best, with the cars with additives showing no better results. The ***le of the article was "Snake Oil's, Save Your Money". I'm almost 80 years old and have been driving for over 60 years and never used any additive in any of my cars, new or old, but do my own oil changes at every 3000 miles.
    Sharpone, Driver50x and jet996 like this.
  22. jet996
    jet996
    from WY
    This jostled an old memory loose. I've got a book about snow planes, there were quite a few still around when I was a kid. The earliest used Model T engines then Model A, B, etc...
  23. jet996
    jet996
    from WY
  24. I use oil
    Oil is good
    Sharpone, saltflats, jim snow and 2 others like this.
  25. Acres
    Acres
    from Sweden
    Snake oil or not, sometimes they must work, they been on the market as long as our vehicles.
    I had a lifter tick coming and going in a "modern car" 20+years old... when changing oil i put a can of wynns engine cleaner in it and after that its never ever made that noise again, and thats 5 years ago.
    So for me the engine cleaner works.
    Sharpone, 2OLD2FAST, CSPIDY and 3 others like this.
  26. Dave G in Gansevoort
    from Upstate NY
    Sharpone, CSPIDY and jet996 like this.
  27. captaintaytay
    captaintaytay
    I don't know if he will touch this, he's a oil guru. @Blues4U
  28. ^^^^ he’s already posted test results from modern oil being just fine for old rides.
    Even Walmart oil.
    The high performance applications with high lift profile cams might need race formulated oils.
    The oil we use today is better than the oils from the mid 60s down.
    Sharpone and gimpyshotrods like this.
  29. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    I need to know...
    Sharpone, jet996 and CSPIDY like this.
  30. warhorseracing
    warhorseracing
    from cameron wv
    I been to one of them once:confused:. That was more than enough:eek:.
