Technical Frame flex (twist)
Discussion in 'Traditional Hot Rods' started by Choppedcoupe, Sep 21, 2025.
  1. Ziggster
    Ziggster
    I’m interested to see if the frame is flexing and why. As I slowly progress with my speedster build with custom made C channels (1/8” thk) the frame flexes quite a bit, but the engine and trans (C59A flathead/T5) really stiffens up the front half of the ch***is even with the Ford engine and trans rubber mounts. I would imagine the same is true for most any engine/trans/ch***is combination.
  2. Choppedcoupe
    Choppedcoupe
    It’s flexing (twisting) for sure. Im exploring the possibility of front suspension bind.
  3. 19Eddy30
    19Eddy30
    from VA
    Thats impressive & amazing more stable @ those speeds , & bumpy .
    Again I do not know if the fenders play apart in what I experienced in both body types.
    Some here say vehicles have to be low center of gravity & heavy ,
    Just wonder @ what speed that start's @.
    Your wheel base around 106 ?
    On one of Four car I built
    @ around 55-65 mph Front would start to shake front end Real bad like you
    describe seemed No bump needed for it to happen , this particular one was Vega
    Box cross steer ,
    Tried all typical adjustment I'm looking at parts , I put 10 deg of caster ,
    It narrow to like right @ 63 mph.
    Played with air pressure ,
    3-1/2 inch wide wheels 50/50 ..
    Then I seem to Notice play in Box ,
    Would adjust , few 100 miles , agin @ 63 ,
    After 3 time , I replaced box ,
    No issue so far ,only 1,000 miles on box.
    But I still will not drag over 1/8 mile .
    If I ever get around to it & add a
    8 to 10 point cage , front engine plate then I might go for 1/4 , should be low 9 mid 8 , with another engine .
    As now I am fine with low 6's
  4. Choppedcoupe
    Choppedcoupe
    When I first got to driving my car, I had a front end shake at 51 mph. Very re-producable. Went away below and above that speed, but it felt like hell right at 51. I had one front rim (steel wheel) that was out of round. Changed that-no improvement. Took it to a shop that shaves tires to true them. They took a lot off of it. It was a cheap Asian radial that was T speed rated. They also balanced it on the car (I now need to clock the wheel to the hub when I run those wheels), but it is smooth as silk now. Funny thing is, I have 2 sets of aluminum wheels, one with radials and one with Coker Firestone bias plies, and I didn’t do a thing to them and they are smooth as silk. Low 6s is no BS. I’ve just got a 4-pt roll bar to the ch***is, and I’m trying to decide if I want a full cage. I’ve got one on my real race car and I’m losing that lovin’ feeling about climbing over door bars. But, I wanna do Drag Week some time, so I’m kinda torn about my safety situation. Bonneville was a bucket list trip, so I just sent it and blocked out the fear that I had when going down the course on a practice run at 70. For my next runs, I just drove as technically as I could and was as surprised as anybody when I got the timing slip. Then I went out and did it again.
    19Eddy30 likes this.
  5. Andy
    Andy
    This is a frame I did. I tested it and it was super stiff. Also cheap and easy. You don't need threaded inserts for the body bolts. A sheet metal shop bent the channels for very little money. It is easy to check the stffness. Just put it up on three supports and put a twist load on it and measure. P1060972.jpeg P1060971.jpeg P1060967.jpeg
    whtbaron, HemiDeuce and Bandit Billy like this.
  6. Choppedcoupe
    Choppedcoupe
    Sure enough fellas, my frame is cracking where the front crossmember attaches to the boxing plate. I disconnected the shocks and there’s a bit more movement when I bounce up and down on the spreader bar. I’m going to completely remove the shocks and go for a careful drive and report back. Looks like I’ve got some all-nighters ahead!
  7. NoSurf
    NoSurf
    Stress concentration?
    Tim likes this.
  8. alchemy
    alchemy
    Gussets on the back corners of the front crossmember would be a good addition for your high stress application. More like the original Henry crossmember that had a full length horizontal lip on the back of the crossmember.
    Andy’s frame is a great example of tying the center of the X member together. As one corner tries to rise, it will try to shove the opposite corner down. If the center of the X is tied on top and bottom it will keep the two sides from operating separately. It will be better in keeping the whole frame in a singular flat plane. A tube or two underneath don’t have the same strength.
    seb fontana likes this.
  9. Ziggster
    Ziggster
    Hard to tell but is the frame not boxed after the crossmember? If not, for sure it’s a stress concentration area.
    Is this also a crack?
    clem likes this.
  10. Choppedcoupe
    Choppedcoupe
    Yes, it looks like another crack where you indicated. It kinda looks like whoever put this crossmember in the frame thought that welding the back half of the crossmember to the boxing plates and not to bother welding it to the c-channel AND the boxing plates. I took the car for a drive with the shocks removed and there was still a lot of radiator shake over bumps. I’ve torn down the front spring and am working thru removing one or two leafs. I’ve been very proud of how this car has had plenty of clearance between the frame and the suspension. I may have to use up some of that clearance in softening the front suspension. Spring bind doesn’t seem to have been an issue. But, there is a lot of “stiction” before free movement in the plastic shackle bushings. I also likely had them tightened too tight. (I’m gonna get this suspension nice and slick!). But they don’t seem worn. What do you guys grease those with?
  11. Mr48chev
    I'm wondering if the dead perch is a contributing factor in the cracking. Great for smooth asphalt and really great as first designed for circle track use but you basically have no spring movement on that end because there no place to go as there is on the end with the shackle. Meaning that if you set up a ruler/yardstick/tape measure between the frame and the tire on the side that the dead perch is on and stack weight of the front as the suspension goes down it is pushing the frame away from the tire and on the rough salt or rough roads it is doing that every time you hit the least bit of a bump.
    pprather and clem like this.
  12. pprather
    pprather
    Are the front shocks still uninstalled?
    How hard are they to compress and expand with your two hands? If this is less than difficult, throw them out. You need a pair of Bilstein shocks.
    Are they the SoCal shocks with the covers?
  13. Choppedcoupe
    Choppedcoupe
    I don’t understand the question…?
  14. Choppedcoupe
    Choppedcoupe
    I have been running Compe***ion Engineering 3-way adjustable drag shocks. I’ve run them on the street 60/40 setting. I haven’t really been happy with them because they are so difficult to adjust, and as you’ve implied, I do t like having the hoods over the shaft. So, today I ordered some shocks from Speedway, and I hope they are just barely stiff enough to keep the tire in contact with the road-lol. I drove the car a bit tonight (even without shocks) and it is SO much better with all the front end components greased and lubricsted and no longer binding. I had ***embled everything dry so that it would stay neat and clean. But, I’d rather have it greasy and smooth in the end.
    Tim likes this.
  15. Frames aren’t supposed to flex?
    jet996 likes this.
  16. Choppedcoupe
    Choppedcoupe
    You guys have been super helpful. No, a frame isn’t supposed to flex so much that is breaks components and cracks itself.
    After chatting with yall and doing a front suspension tear down and re***embly, it turns out that the front suspension was bound up and basically not functioning, so every imperfection in the road (remember that I drove across the rough interstate of the Midwest (Missouri, Nebraska, Colorado, Utah highways, especially punishing was I-80) at 80 to 110 mph, covering 4,000 miles over a week. I beat the tar out of this car, with the front suspension pretty much completely bound. It had to have a consequence.
    Places where the binding was occurring: over -tightened shackle bolts and over-tightened shock bolts, both without any lubricant. Also, plastic Posies Superglide plastic pucks stuck to the paint on the spring leaves, not allowing them to slide or “glide.” I took everything apart and greased it and was more thoughtful about how tight I tightened parts that really need to be allowed to move. I also think that my F1 style shock mounts were contributing to a lot of stress on the frame rails and that may have contributed to some of the cracking. I re***embled the lubricated and not over-tightened (so that’s why the shackles have nylock nuts?) suspension, I took it for another test drive without any shocks and the car drove much nicer. There’s still some radiator movement, but the amplitude of the movement is much smaller, and my doors and door gl*** weren’t rattling and my shifter wasn’t beating me to death, and the shock mounts weren’t groaning and squeaking on every bump. I bought this car from someone else, and I really just tried to complete the build, rather than re-inventing the wheel on all the prior builders work. Some stuff was really well done (like the chop), but it seems that the front suspension needed revisiting. I think I can repair it just fine. I’ve got some (hopefully better) shock mounts on order, which I’ll gusset and weld on rather than having bolts. I’ve got some shocks (which I hope are less aggressively valved, though I may budget for some double adjustable shocks in the future, so that I can adjust them for as soft as possible). I’m also going to repair the cracks in the boxing plates and do some gusset- ting of the front crossmember to share the stresses between the c-channel of the frame and the boxing plates. I may do a little boxing in front of the cross member as well. 6 days til the AR Mile, where I hope to lay down some 150mph p***es. It’s 5 hours each way and I’ll go thru a couple of industrial towns in Tennessee (avoiding Memphis’s terrible roads) and spending about an hour on I-55, which gets all the heavy truck traffic between Memphis and St Louis). I’ll be rolling 80 the whole way. I’ve got a fabricator coming by tonight to help me put my welding plan together, then I’ll tear it all back down and get to work.
    jet996, GuyW, dwollam and 2 others like this.
  17. Tim
    Tim
    from KCMO
    Thanks for keeping us updated!
    rod1 likes this.
  18. AmishMike
    AmishMike
    Running 150 you must have some kind of roll bar or cage. I would expect from fire wall back to be stiff as a brick. What are body mounts? & if you expect to continue running high speed; tie front frame into cage
    Robdski and clem like this.
  19. brg404
    brg404
    If you want a smoother ride over bumps, replace the dead perch with a normal perch/shackle. All the movement/compliance from that side of the suspension is being transmitted sideways through the spring to the frame. That will make your radiator dance...
    Good luck getting it all sorted out!
    GuyW, rod1 and clem like this.
  20. I thought the shackle nuts tighten the shackles against the shoulders of the shackle bolts...so there shouldn't be any overtightening. I've never left them "loose" enough to allow for movement.
    jet996, Robdski and clem like this.
  21. clem
    clem
    in the original post (number 1) and some subsequent posts, it was easy to ***ume that he was dealing with a street driven car that possibly never went over the speed limit.
    When reading that he drives almost 150 miles an hour, it opens up a completely different scenario.
    the advice given in the @AmishMike quote above is probably the best yet for what the car is intended for………..maybe worth consideration.
  22. Ford made Model "A" frames made to flex-twist it's part of the suspension.
  23. 19Eddy30
    19Eddy30
    from VA
    Op Coupe Looks as would of been built in 62,
    If Op post pic's you will be surprised
  24. Choppedcoupe
    Choppedcoupe
    I've got several thousand more miles on the car now since the repair (6800 miles since build completion in July). I've done the Arkansas Mile (drove 5 hours there and back) and ran 139mph in the mile and 141mph in the 2k (1.2 miles). Went to the drag strip and made 11 (1/8-mile) p***es between 7.75 and 7.85 at between 87 and 88mph. Car hooked well on slicks and handled really well. Have made several 1-1/2 hour drives back and forth to Rocket City Dragway volunteering for Sick Smokies where Mike Finnegan won A-gas cl***. Car is a totally different animal since re-welding the front crossmember in. Thanks for everything fellas.
    jet996, ekimneirbo, dwollam and 3 others like this.
  25. Choppedcoupe
    Choppedcoupe
    Upon closer inspection-you are correct. The bind must have been simply due to a failure of the spring leaves to slide over one another. I have a speedway spring with only 5 leafs. I wish I had a stock spring with more leafs so that I could add or take away springs to adjust ride.
  26. Choppedcoupe
    Choppedcoupe
    Just a roll bar. It most likely doesn't add any stiffening. I am considering more cage in the future, but that will make it harder to get in and out of the car and may make it kind of a pain. If I do add cage, I do plan to do as you advise and put a bar thru the firewall onto the frame rail on each side.
  27. Choppedcoupe
    Choppedcoupe
    The file size(s) of my Bonneville photos are too large to post-the HAMB system won't upload them.
  28. Choppedcoupe
    Choppedcoupe
    Not this much.
  29. Choppedcoupe
    Choppedcoupe
    Not this bad.
  30. Choppedcoupe
    Choppedcoupe
    I think you are right-the shocks only had about 1-1/2" of compression travel. I'm now running Speedway shocks (they seemed a little softer than the SoCal shocks, but still clearly have some resistance) without any hoods. I've put zip-ties on the shafts. With my buddy in the car with me, we were using all of the 1-1/2" of shock travel on the highway. With me only, I was using about 3/4". I have since modified the shock mounting to allow 3" of available shock travel. I'm using about half of it. Limited shock travel, hidden by hooded shocks, was likely a factor in my trouble, as you suggest. Thank you!
