Technical Black & Decker 11/16" super-service valve refacer
Discussion in 'The Hokey Ass Message Board' started by wctrainer, Sep 22, 2025.
  1. wctrainer
    wctrainer
    Hi, I have a Black and Decker 11/16" super-service valve refacer that I am trying to replace the valve grinding stone. Is there a way to lock the wheel to get the center allen bolt loose? The bolt is tight and the wheel turns when I try to loosen it. Thanks!!
  2. Budget36
    Budget36
    I’d treat it like an alternator pulley, impact wrench while holding the stone.
  3. wctrainer
    wctrainer
    Thanks, well I could do that.. if nothing else works. It is kind of a small allen bolt wrench and would hate to round it out.
  4. Oneball
    Oneball
    Are you sure you're turning it the correct way?
  5. wctrainer
    wctrainer
    I am hoping that left is loosening it, I will try to the right.. thanks
  6. Budget36
    Budget36
    You could try a strap wrench around the stone, might take a helper to hold the strap wrench though.
  7. Mr48chev
    My Buddy had an old Black and Decker valve machine that I used more than he did but I never changed the stone on it. I'm not finding much of anything online that tells either.
  8. Jagmech
    Jagmech
    Mine has a heavy woven fabric strap with a cast handle, you could try a piece of serpentine fan belt with a vise grip pliers. My setup doesn't use the Allen, but the belt trick may help.
  9. wctrainer
    wctrainer
    Thanks, I will try the belt trick. I tried turning it both ways.. it is just frozen and I can't get any torque on it. I think it has been on for a while..
  10. wctrainer
    wctrainer
    Got it, thanks guys!! used a timing belt on the wheel with vice grips to hold it.. turns out the bolt is righty loosey, lefty tighty!! ha. Have to keep my head around that!! thanks again for the ideas
    loudbang, warbird1 and Budget36 like this.
  11. BJR
    BJR
    SS327 and warhorseracing like this.
  12. wctrainer
    wctrainer
    No, this one is mine
