Hot Rods Other engines
Discussion in 'The Hokey Ass Message Board' started by sweetdick2, Sep 14, 2025.
  1. johnnymac1
    johnnymac1
    I sorta like marching to a different drum , realized I don't need a gazillion cubes or horsepower, just wanted lots of fun cruising. Had an old Chevy 250 six kicking around, figured why not. Then go and do what we do, bore it, balance it, deck it, plane it, lump port it, street port the exhaust, jump valve size, screw in studs, roller rockers, triple angle valve job, tri power, and let the fun begin. I get many, many comments on my choice, but it's all good. Wait and see what my plan is for my 32 Coupe build,
    jet996, warbird1, atch and 21 others like this.
  2. Jethro
    Jethro
    jet996, skooch, Sharpone and 11 others like this.
  3. warbird1
    warbird1
    Put 185 miles behind an "Other Engine" today. Avg. 17.4 mpg with dual quads. No fuss, no muss, no sbc Ross Lake 092325.JPG
    '31 A roadster with a Cadillac 331 and early Hydro...
    jet996, BigRRR, don colaps and 13 others like this.
  4. Bandit Billy
    Bandit Billy
    MPG is not a deal maker in hotrod speak but my blown flathead gets 14. As long as we are in double digits I think we have it made. I think we should call it MPS (miles per smile).
  5. 63Biscuit
    63Biscuit
    from Hudson, WI
    The '63 Biscayne in my avatar is originally a 230ci inliner, and when that died I had a hot 292 Chevy put together with high compression pistons, lumpy cam, lump port head with SBC valves, 4-bbl, dual exhaust, etc. good for roughly 300hp and 300 lb-ft. I love the motor BUT it has turned into a "hybrid" consuming over a quart of oil in 450 miles. I love the motor, but I'll be deeper into a rebuild moneywise than going to a crate Chevy 350, and I'll get more power and torque outta the V8. Plus, I'm juts old enough now that I want to ensure reliability for my own driving and for when one of my daughters hopefully ends up driving it (they're 17 and 20 right now).
    Sharpone likes this.
  6. Toms Dogs
    Toms Dogs
    from NJ
  7. D-Russ
    D-Russ
    GMC 321.
    jet996, 40two, Bandit Billy and 16 others like this.
  8. benchseat4speed
    benchseat4speed
    from Golden, CO
    If you have to ask why everyone runs this engine you’re dismissed. I’m not even gonna try to explain this one.
    My ‘other’ engine lol. Some really cool powerplants in this thread!!
  9. Ziggster
    Ziggster
    Interesting…
    jet996, skooch and Sharpone like this.
  10. tubman
    tubman
    Every flathead I have ever owned since 1957 got 14 mpg in regular use. Fords, Mercury's, stock, modified, and even worn out beaters.
    Sharpone and Bandit Billy like this.
  11. Stan Back
    Stan Back
    I put a 231" Buick iron V-6 in my Sedan. I used the standard cowl and hood and even saved the stock cowl gas tank and dash. I don't know the mileage, but I believe it's somewhere between 15 and 20. I've driven it to Bonneville a few times and in one trip, I'd calculated with my Isky Dream Wheel how many RPM would be needed with the 18s on the back to top 100 MPH. It was surely not a 1/4-mile, but came in soon with the old Halibrands needing better balancing!
    jet996, Sharpone, 2devilles and 2 others like this.
  12. 1952henry
    1952henry
    seb fontana likes this.
  13. saltflats
    saltflats
    from Missouri
    I run a 409.
    jet996, BigRRR, CSPIDY and 4 others like this.
  14. chrisp
    chrisp
    When you pay over $8.00 per gallon the smile tends to be tense.
    SS327, RMR&C, warbird1 and 3 others like this.
  15. Bandit Billy
    Bandit Billy
    That would turn a smile into more of a pucker.
    Hotrodmyk and Sharpone like this.
  16. 1971BB427
    1971BB427
    from Oregon
    The "why" for choosing a SBC or SBF or BBC, etc. is pretty simple. Not even sure why someone asks the why question?
    The reason is simply economics, and availability. These engines are common, parts are well supported, plentiful, and cheap; so it only makes sense for people to choose them. It may not be everyone's cup of tea, and for those who are brand loyal to various other engines they can build and install whatever they like. I have great admiration for those who swap in less common engines, and do so regardless of cost. It's not something I'll do as I'm always budget conscious, and "belly ****on engines" save me money that i can spend elsewhere on my builds. I'm not too concerned if others don't like my choice. If it bothers them too much I'd gladly accept a well built hemi, Pontiac, Buick, etc. if they want to help me be a non conformist and get rid of my belly ****on engines.
    GuyW and Sharpone like this.
  17. FlatheadFritz
    FlatheadFritz
    Dodge 315 with 10:1 forged pistons and mild cam waiting for the 1930 Model A Coupe body and 1932 ch***is to be completed. IMG_2041.png IMG_2040.png IMG_2039.png
    jet996, 2devilles, BigRRR and 8 others like this.
  18. ROADSTER1927
    ROADSTER1927
    jet996, 2devilles, 40two and 8 others like this.
  19. ROADSTER1927
    ROADSTER1927
  20. dana barlow
    dana barlow
    from Miami Fla.
    My first hotrod build in the late 1950s,I knew I wanted a over head valve V8. My limits were,had to be free or close to free an running with ****** needed. I hoped to find a Studebaker,but brand was not a must have! Tiny hotrod piggy bank,with luck, was what shaped what I'd use. The parts I could find,in the woods n down dirt roads dumped junk car,drag parts home,over the last 3 years of the 50s.
    I was lucky getting a Ford"Y" V8,w ******! It ran with out needing much.
    I drove my 28A to Sr high school,love how it turned out,still have it !
    Even thought I also built a full custom Henry J,after finding out I super need a car with roll up windows an a top with fenders. { I put a Olds Rocket 88 in to the "J",got Olds from my buddy who was going into the Navy"} Also did an helped with a lot of rods for others,with a wide number of brand engines.
    I've kept my rod,"Y" powered always.
    Only updates are,now chrome headers an alt. replaced old gen. ,the rest still looks same as it did in Sr High. 001 (4).JPG
    jet996, 2devilles, Charlie K and 10 others like this.
  21. GlassThamesDoug
    GlassThamesDoug
    2bbl holleys, my kinda fuel system.
    jet996, Sharpone and rod1 like this.
  22. Compare the actual regular mileage used by each and it's self explanatory.
  23. Stephen Barrett
    Stephen Barrett
  24. Jeff34
    Jeff34
    I built this Cadillac for a boat I was building. Never built the boat. Thought about putting it in my roadster, but it's a monster! Sold it to a guy building his own boat in Seattle who has finished his project... boat 2.jpg
    jet996, warbird1, loudbang and 3 others like this.
  25. wheeltramp brian
    wheeltramp brian
    Tell us about this monster Cadillac.
