Technical Flathead First Start-up - Fuel in Oil!
Discussion in 'The Hokey Ass Message Board' started by Ziggster, Sep 23, 2025.
  1. Ziggster
    Ziggster
    As I was just about to start up my rebuilt flathead for the first time, I decided to check the fuel tank (1 gal from a lawnmower), and noticed there was no fuel left in it.
    Then checked the dipstick, and it’s full of fuel. I’ve had fuel in the tank for about two weeks while getting things ready. After adding the fuel, I noticed leaks at all of my fuel line fittings. That took about 3 - 4 days to sort out, so lost some fuel from that, but not a gallon. Fuel tank bottom is above base of carb by about 16” or so.
    Can someone help me understand WTH just happened, and what I need to do? I’m guessing a complete engine teardown.
    I’m beyond words.
    Stogy likes this.
  2. Budget36
    Budget36
    Drain it out, let it sit, fill with oil, turn the engine over a bit, drain and refill with oil.
    I’d suspect the float stayed open and fuel went in through the carburetor.
    You can pull the carburetor off, smell, look in the intake for signs of gas.
    I can’t see there being a need to tear he engine down.
    Stogy, hrm2k, borntoloze and 2 others like this.
  3. big duece
    big duece
    from kansas
    Check mechanical fuel pump diaphragm.
  4. Ziggster
    Ziggster
    Almost no fuel left in carb reservoir. Has to be leaking through the carb somehow, and into the intake - no?
    Stogy, hrm2k and Squablow like this.
  5. Ziggster
    Ziggster
    The ch***is is now outside, so will need to bring it back in before I start tearing things apart.
  6. gary macdonald
    gary macdonald
    Power valve leaking or stuck float . Is that a chinese carb ? Put a on off valve on the fuel line .
    Drain oil add new and fire it up after you crank for oil pressure . Not a big deal , these are not rocket science. They were meant for farmers with tractors to be able to repair . Dont worry about zinc oil or any other nonsense . The cam pressure is not high enough to require special oil though I do use rotella for 20 plus years on 13 different flathead hotrods .
    Ziggster likes this.
  7. gary macdonald
    gary macdonald
    Remember, beauty is only skin deep . Get it running and start the rest of the ***embly before you’re my age and can’t enjoy it !
  8. cs39ford
    cs39ford
    So you are using a gallon tank 16 “ above carb. Gravity fed. If so this means its the carb needle and seat stuck or float in carb not properly set to shut off.
    Toms Dogs and Stogy like this.
  9. winduptoy
    winduptoy
    Pull the power valve...it needs not to have a radius where it seats against the underside of the bowl...if a modern PV was installed, with a radius...there is your leak
    I am putting my money on this
    Stogy, jet996 and alanp561 like this.
  10. Phil P
    Phil P
    I agree with the drain out the bad and replace it with new oil. With my model A with the stock tank above the carb I always shut the valve off before turning off the egnition just in case.
    Phil
    Stogy and Ziggster like this.
  11. Ziggster
    Ziggster
    I rebuilt the carb from stuff I got at Vintage speed so PV should be good. Just got it back inside. No way fuel bowl should be empty. What would cause the fuel to drain from it?
    Stogy likes this.
  12. Ziggster
    Ziggster
    Float was set correctly, but it was many years back now when I rebuilt it.
    So, as folks mentioned, bad PV or needle not closing properly.
    Will check it out tonight.
    Stogy likes this.
  13. big duece
    big duece
    from kansas
    Is it wet under the carb, it it wet under fuel pump?
    Stogy likes this.
  14. Ziggster
    Ziggster
    I should mention that I did notice the gasket between the carb and intake was “wet” with fuel the other day. Thought maybe it was “normal” considering all the other fuel leaks I had including same condition a fuel pump
    diaphragm.
    Stogy likes this.
  15. big duece
    big duece
    from kansas
    They do make a alcohol safe diaphragm for the Ford pumps.
    Stogy and alanp561 like this.
  16. RodStRace
    RodStRace
    Gravity fed, so not pump.EDIT: IT IS FEEDING A PUMP!
    The only thing that holds the gravity pressure back is the float and needle and seat. However, if there is a leak internally, the level drops and the float lowers, allowing more fuel. I'd check it by removing the carb, filling the bowl and seeing if and where it's leaking.
    I'd fog the cylinders and clear the intake ports since the fuel went down the engine.
    Stogy, alanp561 and Ziggster like this.
  17. big duece
    big duece
    from kansas
    He does have a fuel pump, if the diaphragm is bad it will leak to crankcase wether working or not. Screenshot_20250923_134019_Samsung Internet.jpg
    Stogy, Ziggster and porkshop like this.
  18. Squablow
    Squablow
    All I can tell you is I feel your pain. I've been dealing with a different but somewhat related issue that I think I just got resolved and I know how frustrating this is. I doubt you need a full engine teardown but it might take some digging.
    I don't know that I personally have any good advice but I would like to hear what the cause was once you figure it out, posts like this are really useful to future internet-searchers dealing with the same issues.
    The pump diaphragm is one suspect, where fuel could get past and into the oil, although that doesn't explain the carb bowl being bone dry or the carb gasket being wet. Curious.
  19. big duece
    big duece
    from kansas
    Possibly a combination... removing the carb as previously mentioned and filling the bowl would be telling watching it on the bench.
  20. jaracer
    jaracer
    All engines end up with some fuel in the oil. It normally evaporates during operation. Drain the oil you have and disgard. Fill the engine with fresh oil, crank it with the plugs out, ignition disabled (the cylinders may have a lot of fuel in them) until you have oil pressure, put the plugs back in and fire it up.
    Stogy, AmishMike and Ziggster like this.
  21. rusty valley
    rusty valley
    you can test your needle and seat with a vacuum pump, or even with your mouth and tongue.
    If it won't hold any vacuum, it won't stop the fuel. Sometimes a polish with tooth paste will fix the needle.
    Stogy, Ziggster and big duece like this.
  22. Ziggster
    Ziggster
    On the road now, but will tear into carb and test when I get home. Pulled the breather on the tube next to the fuel pump and didn’t smell any fuel when I was checking things out,
    It’s easy to pull the intake and heads to check things out, but that’s about how far I would go for now depending on what I see.
    Stogy and big duece like this.
  23. big duece
    big duece
    from kansas
    Before you spin it, maybe shoot some mmo or trans fluid in plug holes just in case the gas did wash the cylinders and remove your cylinder lube.
  24. big duece
    big duece
    from kansas
    If you do indeed find the issue with a power valve that has the radius on the mating surface, it needs to be flat, or cut flat on lathe. There's a fella in NY that specializes on 94s and has those power valves on hand already modified for this issue.
  25. gary macdonald
    gary macdonald
    Dont waste more time and money on intake and head gaskets and wear on the head bolt/ studs . Something always happens , stripped headbolt or stud pulled threads etc . Check power valve , it doesn’t matter if you just rebuilt it , most all kits have the WRONG type of power valve . Only 2 ways to empty the fuel bowl , actually just one , the power valve . The seat and needle will allow fuel to fill the bowl and flow over but not empty it .
  26. big duece
    big duece
    from kansas
    Charlie's your guy on power valves if needed Charlie & Alice Schwendler at Canfield '17(1)-1.jpg
    Stogy, warbird1, winduptoy and 2 others like this.
  27. Ziggster
    Ziggster
    Ok. Makes sense to my monkey brain. Has to be something I ******ed up in ***embly as I clearly recall looking at the PV from Vintage Speed and checking for radius (there was none) as he claimed he was the only one selling them.
    Stogy and winduptoy like this.
  28. big duece
    big duece
    from kansas
    Gasket under PV?
  29. Ziggster
    Ziggster
    Just so I’m clear, can someone confirm that the likely cause is that fuel flowed past the PV into the carb throat, then down through the intake and into some of the pistons (***uming intake valves are open), past the piston rings and then into the pan?
    Stogy, winduptoy and alanp561 like this.
  30. cpraceman
    cpraceman
    from walls, ms
    Take the carburetor off, set it on the bench and fill the fuel bowl and see if the gas will
    run out. If it leaks it would about have to be the power valve or a hole in the carb body.
    Stogy, clem, borntoloze and 3 others like this.
