Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. partsdawg
    partsdawg
    from Minnesota
    I started peeling the onion in my shop today. After removing and sorting through a 6'x16' area of stuff I could almost see a back wall. Removing 2 4'x8' plywood panels I found a pair of 3-speed overdrive transmissions, a very nice '54 Ford drivers fender, '54 Plymouth station wagon upper tailgate with gl*** a pair of late '30's rear fenders and a couple early 50's grilles plus 8 old mag wheels. None of it has seen the light of day in ay least 15 years.. It was like Christmas.
  2. FrozenMerc
    FrozenMerc
    I blew the drivetrain out of the T-bird last night. Final paint and ***embly of all the drivetrain bits starts tonight.
  3. saltflats
    saltflats
    from Missouri
    Made a start on my poor man's cowl induction.
    Okie Pete, bowie, alanp561 and 14 others like this.
  4. Sharpone
    Sharpone
    Took the Dirt Cheap Darts driveshaft to the driveline shop, the donor cars driveshaft was 2 inches too short. They will build a new shaft and balance with new u joints and slip yoke. I thought about building a drive shaft myself but by the time I got the parts, made a jig etc etc it would probably be a week or two longer to finish and I would’ve still had it professionally balanced. Prices have gone up! $480.00 used to be 200 - 300. I should be ready to have car driving by the time I get the shaft back.
    Dan
    porkshop, enloe, swade41 and 5 others like this.
  5. atch
    atch
    Went to town and got the drive shaft and axle seals this afternoon. Drove the Model A to the Model A club meeting. I'm the current club president and it took me all afternoon to complete all the paperwork I had to do before I went to the meeting. Therefore, I didn't get anything done on Clarence today, but I've got all day tomorrow. I should be driving it tomorrow afternoon. Earlier if I roll out of bed at the same time most of you do. I doubt I'll be awake before 9-10ish though which means I'll probably start working on Clarence around noonish.
    All I have to do is install the seals, reinstall the axles & brakes, reinstall the drive shaft, fill the 3rd member with 90wt, let that thing down off of the cribbing I've got underneath it, and take it for a test drive. I figure 2/3 hours for me. Probably 30 minutes for most of you.
  6. Stock Racer
    Stock Racer
    Sanding my firewall in preparation for paint. Sanding a firewall ****s, lol. IMG_7427.jpg
    Okie Pete, bowie, porkshop and 11 others like this.
  7. atch
    atch
    Clarence is all ready for a test drive. I would have done that this afternoon but it started raining like a cow p*****g on a flat rock. Tomorrow is my other car club's annual picnic so we'll drive Clarence to that. I'm really glad to get it down off of the cribbing it's been on for a while.
    Okie Pete, porkshop, alanp561 and 9 others like this.
  8. 5w Jen
    5w Jen
    from Sweden
    We are working on the '33-34 frame. Weld prep, it took three p***es with the TIG to build up enough material. The rear part is finished Bonneville style with a 6" kickup to get frame and weight down. L1020853.JPG L1020856.JPG L1020859.JPG
    Okie Pete, TA DAD, BigRRR and 17 others like this.
  9. Royalshifter
    Royalshifter
    Moderator
  10. 57 Fargo
    57 Fargo
    Got wifeys ‘62 T-Bird running, and the disc brakes off a ‘66 on the drivers side, hopefully get the other side done tomorrow
    Robdski, saltflats, porkshop and 4 others like this.
  11. Sharpone
    Sharpone
    IMG_3547.jpeg WOWzers cool with a capital K and C
    Dan
  12. atch
    atch
    Test drove Clarence today with new rear end parts, seals, etc. Went to a car club picnic.
    Drove about 100 miles and it ran perfectly.
    Tomorrow I plan to drive it to church. Thursday it goes to New Haven (between Hermann and Washington) for a car-guy lunch. That's about 100 miles each way. Following Thursday to southeast Kentucky for a small car-guy gathering.
    For those of you who read my thread about spark plug wire routing let me tell you they sure are ugly where they are now BUT I haven't burned another wire since I fixed that fiasco.
    Since May of 2024 I've put about 13K miles on it and finally it seems to have all the bugs worked out. Well, except for the left turn signal on the front that I discovered today needs a new bulb. I think even I can handle that issue.
    I don't foresee any issues arising on the Kentucky trip except that I need to leave early enough in the morning to get there before dark. The last 50 miles or so are on narrow mountain twisties with drop offs on one side and bluffs on the other side and I've never been there before. Google maps tells me it's about 10 hours of actual driving time but when you add in gas stops, a meal or two, and a time zone change I might have to leave by 4-5 am to get there when I want to. It is what it is. Those of you who know me know that the last time I saw 4 am was because I hadn't been to bed yet. My bed time is normally 12-3 but usually between 1 and 2.
    Robdski, saltflats, porkshop and 6 others like this.
  13. 57 Fargo
    57 Fargo
    Put the disc brakes on the right side of Wifeys T-Bird
    Robdski, saltflats, porkshop and 3 others like this.
  14. RMcCulley
    RMcCulley
    Finally found the front end grinding sound when rolling slow..... after 2 months.....
    trim rings :D
    At least the car has new wheel bearings and rotors o_O
  15. Have FUN. Hope you do a road trip thread.
    Ben
    Sharpone and porkshop like this.
  16. porkshop
    porkshop
    from Clovis Ca
    Worked on this in my spare time for @Royalshifter 20251004_112953.jpg 20251004_112953.jpg 20251004_112935.jpg 20250927_072637.jpg 20250927_121743.jpg complete custom exhaust bent up...
    Okie Pete, bowie, enloe and 17 others like this.
  17. Sharpone
    Sharpone
    porkshop likes this.
  18. saltflats
    saltflats
    from Missouri
    Need to unload after the weekend at Tristate raceway. Had a blast with the 348 409 racers after the 7 year absent.
    Okie Pete, bowie, rod1 and 18 others like this.
  19. swade41
    swade41
    from Buffalo,NY
  20. Sharpone
    Sharpone
  21. Almostdone
    Almostdone
    Two things… first, helped my brother add footings for a 2-post-lift (necessary, but not fun). Second, (here comes the fun part) I bought a ‘51 F1 project that will likely keep me busy in the shop for 2-3 years. Giddyup.
    John
    Okie Pete, Jeff34, enloe and 15 others like this.
  22. Almostdone
    Almostdone
    enloe, Sharpone and porkshop like this.
  23. porkshop
    porkshop
    from Clovis Ca
    Thanks, There is hours and hours of work there and thought process to get it right...
    Robdski and Sharpone like this.
  24. flatout51
    flatout51
    Fixing old Ford work. The lead seam on my shoebox coupe was bad. 20251007_165721.jpg 20251009_131854.jpg 20251009_131858.jpg
    Okie Pete, rod1, enloe and 9 others like this.
  25. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Lending a hand to the gentleman I bought my lathe from. Andy doesn’t move around so well after his health scare. Chased down all the EFI (TBI to be exact) wiring and unplugged it all and removed it. Going carbureted as a 55 Chevy Bel Air should.
    little red 50, BigRRR, enloe and 9 others like this.
  26. chevy57dude
    chevy57dude
    Good deal, Johnny. Bet he is glad you're around.
    enloe, porkshop, 427 sleeper and 2 others like this.
  27. jimmy six
    jimmy six
    Unhappy with our performance at World Finals Bonneville without a way to tune in more I’m going inside to see and check everything. Ready for the engine stand and starting to send external parts out that I don’t have the expertise or tooling. 10 days since we got home and with times shops estimate today…I’m behind already! IMG_7199.jpeg IMG_7229.jpeg
    Okie Pete, BigRRR, porkshop and 13 others like this.
  28. HOTRODNORSKIE
    HOTRODNORSKIE
    Finally got all eight pistons in the olds 303 today the rest sould go quicker. 20251011_151638.jpg 20251011_151627.jpg
  29. saltflats
    saltflats
    from Missouri
    Stop by my buddy's shop to dive into the clutch and break problem this 1962 SS Impala has always had since being converted to a 409 4 speed. The clutch and break pedal have been very hard to operate. I know it has to be a pedal ratio problem.
    So today I dove into it and what was found is the bracket and pedals are from a 61 not a 62 and they are not the same. We did come up with some pedals but need the bracket to hang them from.
    Okie Pete, swade41, Oneball and 12 others like this.
  30. chevyfordman
    chevyfordman
    I like to copy things so I duplicated the plastic knob for the antenna with a stainless steel one that I made. IMG_3104.jpeg
    Okie Pete, alanp561, swade41 and 12 others like this.
