Projects 1928 Model A 2 dr Phaeton Build
Discussion in 'Traditional Hot Rods' started by caprockfabshop, Aug 17, 2022.
  1. 1-SHOT
    1-SHOT
    from Denton
    Looking good you are making great progress.
    caprockfabshop likes this.
  2. caprockfabshop
    caprockfabshop
    Alright gang, needing some input. I'm considering how to do the lower cowl area, in particular where it sits over the frame. Since the frame was pre-***embled, I didn't have any input as to how pinched to make it, and the fitment is rather tight between the leading edge of the cowl and the rails:
    Now, the body and frame will be the same color, so I'm not too worried about that aspect, but I would like to have more room to install and fit the body without scratching the frame or if the body shifts while driving I'm not having it banging on the frame.
    So I'm proposing to relieve the body up to the black line as shown here:
    That's ^ the tightest area, and would give far more room to drop the body over the frame without banging into it.
    However, I'm not a fan of the firewall just having a corner missing, so I'm thinking about cutting the lower area on a curve mimicking the upper firewall line, and ending on a straight cut exactly like I need at the leading edge.
    Give me your thoughts, it does mimic that line where the fuel tank upper meets the firewall sides, and does continue the lower body line at the base of A pillar. So wouldn't be too radically departed from the original Ford design, I'm going to push forward with the rest of the firewall in the meantime.
    Edit: Alternative is like Shine did on his 34 Truck:
    ~Peter
    brEad, CSPIDY, Kelly Burns and 2 others like this.
  3. wstory
    wstory
    from So Calif
    Hope I can clearly articulate my idea.
    Looking at your first photo, I see an offset between the flange and the body of the cowl of about 3/8 inch. How bout moving that surface (the small rectangle) shown in the second pic "out" to be flush with the cowl surface, making a little "step out" to accommodate frame clearance?
    brEad likes this.
  4. rusty1
    rusty1
    ^^^ ditto,needs more chop, that doesn't even look chop'd...
  5. caprockfabshop
    caprockfabshop
    I like that idea, though it would only give an 1/8" or so combined, that might be all I need.
  6. caprockfabshop
    caprockfabshop
    Those are 2" chopped Roadster windshield posts, any lower and the proportions get all weird.
    brEad and Stan Back like this.
  7. Doug G
    Doug G
    from Manheim Pa
    Depends if you plan on using the hood sides or not ?
  8. caprockfabshop
    caprockfabshop
    No hoodsides, maybe hood top at some point
    brEad likes this.
  9. wstory
    wstory
    from So Calif
    I like a hood top and no sides. A hood top extends the line, making it a complete car, while no hood sides is a "skirt lifter" exposing enough of a hot rod engine to draw folks in. ;)
    brEad and caprockfabshop like this.
  10. caprockfabshop
    caprockfabshop
    You're the man! That solved my troubles without compromising the appearance. Here's with a quick skim coat of filler for the interim, but that's exactly what I needed! PXL_20240527_231006280.jpg
    ~Peter
    RICH B, brEad, Stogy and 7 others like this.
  11. rusty1
    rusty1
    It's yer car, but if it were mine, I'd kept it as a sedan,...lots more weather friendly.
    what did you do with the roof part?
  12. caprockfabshop
    caprockfabshop
    I already have a 1954 Olds for weather-friendly driving, that being said, plenty of guys drive roadsters in all weather...
    brEad, CSPIDY, loudbang and 4 others like this.
  13. verde742
    verde742
  14. Grumpy ole A
    Grumpy ole A
    I love reading about your build. I bought mine, aviator. It was built in the 60s I think. I have a picture of where it was found in the attic of a garage. It had some changes made to where it is now. It was a coupe that was cut down to a roadster but the doors are thick. I was looking at yours to see how you he’d made your doors like a roadster. Very interesting the way you got it done. Keep up the good work.
    Kelly Burns and caprockfabshop like this.
  15. Tim
    Tim
    from KCMO
    Anything new?
    osage orange and Kelly Burns like this.
  16. ModelAMitch
    ModelAMitch
    How's this thing coming? I used to love getting updates on this!
    osage orange and Just Gary like this.
  17. caprockfabshop
    caprockfabshop
    Yeah, I stopped posting on Instagram and forums, I found the time it took to stop and photograph and do***ent my progress was cutting into my hourly production. Lame, I know, but especially when I'm trying to maximize output, I find it easier to keep pushing through when my hands are dirty vs stopping and grabbing a camera for a photo.
    I'll share pics when it's finished, but I had to shove it to the side recently to focus on paying work, economy is hitting a lot of blue-collar jobs, just lucky I still have mine.
    osage orange, Jeff34, drdave and 3 others like this.
  18. ModelAMitch
    ModelAMitch
    Makes complete sense. Glad to hear its still around and will get finished!
    osage orange and Outback like this.
  19. Outback
    Outback
    from NE Vic, Oz
    Understand, please don't forget us when it's done
    osage orange likes this.
