9s for $9k
Discussion in 'Off Topic Hot Rods & Customs' started by squirrel, Mar 18, 2025.
  1. squirrel
    The rooster shirt is fun!
    Made it home....been a long 12 days
  2. Thanks for taking us along buddy :cool:
  3. squirrel
    I got the transmission out and partly apart. Turns out it was the other thing that could have been wrong with 2nd gear, it rolled the sprag. So the 2nd clutch was not doing anything, even though it was still working.
    Deutscher, Sharpone, swade41 and 15 others like this.
  4. Ouch, What is the fix to prevent the sprag issue?
    Sharpone, 41 GMC K-18 and porkshop like this.
  5. rockable
    rockable
    That's some damn good torque and traction!
  6. bobss396
    bobss396
    Did you find any loose pieces in the pan?
  7. loudbang
    Well at least you got more coverage in Bangshift :rolleyes:
  8. Crosley
    Crosley
    from Aridzona
    A bit too much power for the low count 2nd gear sprag..
  9. squirrel
    A friend mentioned that it might have happened during a burnout.
    In Plan II I always did the burnout in high gear, it worked fine. In Cheep, I've been doing the burnout starting in 2nd then 3rd, because something I put in the car had instructions to do that.
    I think I'll go back to high gear only burnouts. I did that on the last p*** on Friday, since I didn't have 2nd gear any more, and the burnout was fine. Makes sense to me, a burnout is brutal on a transmission if you're shifting, so I think it's better to just leave the geartrain all locked up in direct drive, and avoid potential issues.
    I ordered some gaskets and a 34 element sprag, should be here tomorrow.
  10. Crosley
    Crosley
    from Aridzona
    Ya, you want to end the burnout in high gear, specially if the tires hook as you lift off the loud pedal. The shock load is high on the sprag or roller clutch if it is holding power like a T-400 in 2nd gear. I usually ran 400 grit wet paper over the sprag races when a new sprag unit was installed.. Just a practice I developed over the decades
  11. squirrel
    I did shift before ending the burnout...hmmm...
    Anyways, to the rearend. With the car running 126 mph, it's close to red line through the lights. So I'm working on installing the 3.27 gears to replace the 3.73 that is in the 8.8 Ford rear now.
    But I can't get the pinion out! I removed the nut, then pulled off the flange, then put an old nut on the threads of the pinion gear. Beating on it really hard with a big hammer, it has not budged.
    now what do I do? :)
    Sharpone, bobss396, Thor1 and 3 others like this.
  12. RodStRace
    RodStRace
    Front bearing seized to pinion? Can you get the front bearing out with a hook?
    The view looks like normal parts in normal positions. Only other thing is the spacer wedged or stuck, but that should still allow the pinion to move around...
  13. 41 GMC K-18
    41 GMC K-18
    Ordinarily, the suggestion would be to use some heat on that nut, but that being said, its dam near impossible to do that, with a rosebud, and NOT catch the oil on fire in the differential housing.
    I would imagine that using that kind of heat, might not be good for the temper of the metals you are trying to deal with.
    "All things are possible, through speed and diligence"
    Sharpone and porkshop like this.
  14. squirrel
    Reading old posts on mustang forums, it can be a real ***** to get the pinion out of the front bearing on the 8.8.
    Heat is probably going to come into play soon. With fire precautions.
  15. RodStRace
    RodStRace
    @41 GMC K-18 The nut's off. The pinion isn't coming out!
    The image says use a bigger hammer, but Jim already used a big hammer!
    It's the desert, Jim. What fire precautions?:D
    Be safe, best of luck.
  16. squirrel
    I don't have any bigger hammers. And I wouldn't be strong enough to swing one anyways.
  17. RodStRace
    RodStRace
    Jim, do you have a burp gun (air chisel)? I have not seen them move stuff a sledge wouldn't in cases like this, but when you go for the heat, it will avoid worrying about hold, hammer and heat.
    41 GMC K-18, Sharpone, Thor1 and 2 others like this.
  18. squirrel
    I bought one to try, and it doesn't do anything either. I heated up the bearing and beat on the pinion a few times, still hasn't moved. Might take the housing out and put it in the press, and see what happens. If it's out of the car then I can see well enough to cut the bearing off with a torch if need be.
  19. 19Eddy30
    19Eddy30
    from VA
    Wrap a chain or two around cast of rear in X , use a bottle jack press out ;)
  20. squirrel
    I took it out and put it in the 30 ton press, no movement. Torched the bearing, no movement. What fun.
  21. That's crazy! I worked at a Ford dealership for 9 years, I've built about 25 or so 8.8s and I've never had one i couldn't hammer out. Good luck
  22. Ring gear and carrier still installed? ;):D
  23. gene-koning
    gene-koning
    WOW! I thought I was the only guy that runs into that strange stuff. At some point, the inner race must have spun on the pinion shaft and welded itself there. If that was the case, I don't see it coming apart until the inner bearing race is split and forced off the pinion with the press. I doubt there is enough clearance for the pinion to come out with the rollers all gone, but the inner race still attached to the pinion?
    Maybe the rear end issue caused the transmission issue?
  24. 427 sleeper
    427 sleeper
    I've seen some ignorant **** over the years, but this tops it all!!! :confused::eek:o_O
    How in the hell can a bearing be so damned stubborn?
    41 GMC K-18, Sharpone, SS327 and 3 others like this.
  25. oldiron 440
    oldiron 440
    Hey Jim what did you think of the kids Eagle wagon with the 4.0 AMC/mopar/Jeep turbo setup? I see he ran a 9.51 on the last day of DragWeek…
  26. Johnny Gee
    Johnny Gee
    from Downey, Ca
    “Kick em when they’re down”
  27. squirrel
    yeah, no....this ain't my first rodeo. Just the toughest.
    I pulled all the rollers out, and finally got the torch deep enough in there to split the cone, then the pinion just tapped out. Very weird. I've been fighting rearends for almost 50 years, never seen anything like this one.
    Oh...the Eagle wagon, killer car! I love it
  28. Keep learning 8.8 tips Jim, I might need help soon lol. Post pictures of your ***embly please :cool:
  29. RodStRace
    RodStRace
    You know how I can tell it's not your first rodeo?
    Because the first POS that fights someone that hard is immediately thrown as hard and as far as possible. You got it out, reached over and grabbed a camera, then took a non-shaky, focused picture of it first! :D
  30. 19Eddy30
    19Eddy30
    from VA
    Thats Just Amazing even in a press.
    stuck /seized that tight .
    The chain Thought I have done ,
    & there been time's I have drilled out centers of shaft's & other to release tension.
    Most time press fit like .0010 to .0025 thou
    Wonder @ ***embly if
    One was heated other cooled
    Then Bearing & pinion was dropped
    On & in ?
    Like a Wedding band
