9s for $9k
Discussion in 'Off Topic Hot Rods & Customs' started by squirrel, Mar 18, 2025.
  1. I owned a loaded 1986 Eagle wagon years ago (leather, cruise, tilt, p/seats, air, p/w, p/locks, change from 2 to 4 wheel on the fly etc) and I absolutely LOVED that car. With the carrying capacity of the wagon and the four wheel drive, it did everything well at any time of the year (Canada here so we get snow in winter). Tow a boat in the summer ... many times, tow two snowmobiles in the winter ... many times, plow through snow most other cars on the road got stuck in ... many, many times. As much as I loved that car and it's ability to "do everything", running mid-nines was something I can promise you, it did NOT do. To be honest, if I hadn't watched Drag Week, I wouldn't have believed it. Not only did it run 9's, I believe it made it through the full week too so that adds to the awesomeness as well. That reminds me, it was -40 in Bancroft Ontario, a buddy and I were at his trailer for some "sledding" ... guess who's car was the only one that would start? You got it, that "old carbed Eagle" boosted a few cars that frigid day :)
    Edit: final update on my roll bar bends question and the NHRA response ... of the FOUR NHRA tech contacts I reached out to, to this day, only ONE has bothered to respond and their response, although I specifically asked for it, did NOT include pointing me to exactly where "tubing must be uniform in outside diameter before, during and after bend" is written. Personally, I think that's disgustingly pathetic on their part :( My question wasn't "why are the bathrooms at national events so dirty" or "for the money spent, I should have received more chips/fries with my burger", it was a specific safety related question regarding the interpretation of THEIR OWN RULES regarding safety (either real or imagined).
    Deutscher, wicarnut, 1Nimrod and 8 others like this.
  3. squirrel
    I did get a picture of the engine in it....
    and his trailer, which looks like he really has his act together.
    Deutscher, wicarnut, 1Nimrod and 13 others like this.
  4. AmishMike
    AmishMike
    Owned bunch of jeeps over the years. That big 6 can not be killed like the ford 300
  5. I just made myself laugh with this thought :) ... NHRA stands for No Hurry Responding to ***holes. I mean, it ain't like the shoe don't fit me :D
    And back to our regularly scheduled program ;)
    1Nimrod, 41 GMC K-18, SS327 and 2 others like this.
  6. squirrel
    Back to the regularly scheduled program...rearends? proctology?
    A closer look at what was holding the bearing onto the pinion.
    The new used pinion is in great condition in this area. Strange.
    Also, the rear bearing pressed off easily.
  7. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Oxidation of the **** Doc?
    Sharpone, squirrel and porkshop like this.
  8. RodStRace
    RodStRace
    Looks like the signs of brinelling to me.
    https://en.wikipedia.org/wiki/Brinelling
    @AmishMike the reason those engines have a bulletproof reputation is because AMC over the years threw so much different junk at it, but it kept going! Plastic valve covers, PCV systems that were wacky and used horrid materials, Lean Burn carbs to rival Mopar. Ford, French and other lowest bidder parts bin ignition and emissions equipment, cooling systems, then toss in pilots taking them up, down and sideways beyond design; it earned that rep!
  9. ffr1222k
    ffr1222k
    On my 8.8 in my TurboCoupe I had to pull the entire rear and use a press.
  10. oldiron 440
    oldiron 440
    I’ve done it with chain and a porta power.
  11. 41 GMC K-18
    41 GMC K-18
    Bravo @squirrel !
    The mighty Squirrel ( Jim Forbes) will NOT be daunted or defeated when it comes to getting to the bottom of the problem, and onto the path of curing the problem!
    porkshop, 1Nimrod and SS327 like this.
  12. Is it supposed to be that oily??:p:p
    BEN
  13. DDDenny
  14. AmishMike
    AmishMike
    Good picture for a tee shirt ^^^^^^
    porkshop, 1Nimrod, SS327 and 3 others like this.
  15. squirrel
    back to work...first try with the rear end setup was pretty bad, using the shim that came on the 3.27 pinion. So I tried the much thicker shim that was on the 3.73s in this housing, using the original side shims, and get this...I think it'll be ok. But I'll do some more staring at it, I might try some different compound to see if I can get a better imprint.
  16. squirrel
    this is the final pattern, after setting the pinion preload. Backlash is about .011
  17. I usually have good luck reusing the shims out of the housing. Im having a hard time reading the pattern with that marking compound
  18. Just saw the update, looks good
    porkshop likes this.
  19. squirrel
    Yeah, it turns out the shims that were in the housing put it right where I want it. Thanks
  20. On the 8.8s if the backlash is off I normally swap the carrier shims side to side and that makes it perfect
    41 GMC K-18 and squirrel like this.
  21. squirrel
    The rear and transmission are back in the car. I need to fill the transmission, and see if it works.
  22. squirrel
    Went for a few drives, the last one about 60 miles. Seems to be fine now...
    the "wa-wa-wa" sound in the rear went away, probably one of the bearings I replaced. There's a slight singing noise now, very faint, which changes with throttle. Not surprising for being used gears.
    I also calibrated the speedometer by changing the gear in the transmission, it's within 1 mph now, although the odometer is off by about 3%. I'd rather have the speedo working in this one, it's pretty easy to get going a lot faster than you think you are.
  23. Harv
    Harv
    from Sydney
    Only worry if it sounds like you have Johnny Cash in the trunk :D
    cheers,
    Harv
  24. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Think a little younger.
  25. 19Eddy30
    19Eddy30
    from VA
    Back in 80's being @ local stock car track
    During Qualifying There where certain
    Car's as warm up to make Qualified position runs, You could hear rear gear
    Some had a unique sound , I was told
    Zoom brand gear's , Do not know if True , But definitely a different sound.
    Sharpone, 41 GMC K-18 and porkshop like this.
  26. slowmotion
    slowmotion
    Quick-change howl?
  27. 19Eddy30
    19Eddy30
    from VA
    No ,I am sure gm 10 /12 9 inch .
    these car where Late Model cl***'s
    80's body's asphalt Straight 6 cars V8 ,
    Camaros , T birds , Regal ,Monte Carlo's
    Track was Old Dominion Speedway
    I belive 3/8's oval I think around 66
    Switched from dirt to paved ,
    The original track closed around 2012
    Drag strip opened in 1951 do not know when oval was added ,
    ODSW claim to be the first drag strip on the East Coast
  28. RodStRace
    RodStRace
    Knowing how 'varied' setups can be and how some get supers***ious about dirt track racing, I can imagine they set them up different for some reason.
  29. justabeater37
    justabeater37
    I had Zoom gears in the 8.2 in my 68 Camaro back in the 90s. Went through the set up process 3 times before giving up and listening to the gear noise. Sort of a whine if I recall.
    porkshop, 41 GMC K-18 and 427 sleeper like this.
  30. squirrel
    Zoom gears were like that...louder than this one. I can barely hear it, and only under certain conditions.
