Technical HAIR PINS AND MUSTANG BOX ON 32 FORD???
Discussion in 'The Hokey Ass Message Board' started by ALLDONE, Sep 25, 2025.
  1. ALLDONE
    ALLDONE
    Trying to remove the 20'' four bar set up on my 32.....I got drilled split bones about 41'' long... the way it ends up with the bones under the frame i have to deal with the steering arms and they hit the steering box... plan was down the road to use a flattened cross member to get the 1'' lower in the front.... my axel is 2'' so I wanted to use bushed ends and hook to the hair pin??? you can get 27'' pins pre made...allso they make them in 36 but I think you would have to gusset the longer ones.... any way... the box is in the way to do anything but leave it alone..... I don't care for the 4 bar look so it needs to go.... I don't wanna do vega or cross steer.... is there a way to mod the steering to work with hairpins????
    any pic would really be helpfull, thanks guys...
  2. ALLDONE
    ALLDONE
  3. ALLDONE
    ALLDONE
    I'm all eye's here if you have an idea...
  4. ALLDONE
    ALLDONE
    here's some pics I found.. not my car, but same set up
  5. ALLDONE
    ALLDONE
    this set up seems to be 60's 70's ???
  6. V8 Bob
    V8 Bob
    Your car's "set up" was designed and produced in the early '70s by a well known company named Pete and Jake's, and is one of, if not the best non-stock front suspensions for I beam axle hot rods.
    You can use split radius rods or hair pins with the Mustang or early Ford steering box, but the results will not look or work nearly as well.
    You might want to take time to learn about Pete and Jake's and the well designed products they provided, which helped in a big way rekindle hot rodding in the '70s, before you start tearing apart what you have, IMO.
    RMR&C, 59sedandelivery, rpm56 and 8 others like this.
  7. Dak Rat
    Dak Rat
    from NoDak
    I have that suspension on my full fendered '32 Sedan, built in the 80's. As V8 bob said above, it is one of the best handling, steering and riding suspensions out there. My car is a pleasure to drive. Maybe you could bolt fenders on your car and be done with it.
  8. lothiandon1940
    lothiandon1940
    Lots of great information in the Pete and Jakes catalog... 06082020_0001.jpg
    59sedandelivery and 19Eddy30 like this.
  9. goldmountain
    goldmountain
    Just leave it alone and the 70's look will come back in style.
    ALLDONE and chevyfordman like this.
  10. ALLDONE
    ALLDONE
    on mine, they moved the box up to the bottom of the frame.... my first thought was to move it up more... then use the split bones... but then the steering tie rod is a problem ... It seems to work real well, and steers good and easy. I just don't like the look.... I guess what i'm trying to do mess all that up..
    lothiandon1940 likes this.
  11. ALLDONE
    ALLDONE
    I used to buy from P&J 40 yrs ago
    deathrowdave and lothiandon1940 like this.
  12. lothiandon1940
    lothiandon1940
    I guess you've figured out by now that changing one thing leads to 10 other changes that need to be made!:eek:
    X-cpe, seb fontana, rpm56 and 2 others like this.
  13. ALLDONE
    ALLDONE
    I just took the fenders, tweed. billet hi back buckets off... I was trying to pull it down to the 50's... I would have left the fenders, but they were fiber glass. I wanted a hi boy so I grabbed it.. it's a steel car 524063475_10213633781794736_687526918886614566_n.jpg 524390658_10213633783194771_1231280055425167798_n.jpg 524615128_10213633811555480_756656416243842747_n.jpg 524934095_10213633777954640_5797543328823003471_n.jpg IMG_5924.jpg IMG_5929.jpg IMG_5979.jpg IMG_5980.jpg IMG_6009.jpg IMG_6038.jpg IMG_6040.jpg
  14. HOTRODPRIMER
    HOTRODPRIMER
    I had the same suspension under my old 4 door sedan, drove great.
    The 4 bar is a very good alternative when you have fenders but under a hiboy they don't fit the 50's style. HRP
    bchctybob, ALLDONE and dwollam like this.
  15. A Boner
    A Boner
    Luckily the front axle is a beam, not a tube. Use the bottom hole to mount the rear of the hairpins. Might end up with some bump-steer…and depending on how much it bothers you… could always just put the 4-bars back on! Don’t think the bump-steer would be any worse than the cowl-steer set ups, that are quite popular.
    ALLDONE likes this.
  16. ALLDONE
    ALLDONE
    problem is how short the 4 bars are... like around 20''
  17. ALLDONE
    ALLDONE
    well thought I had this figured out.. I bought a drilled axel and drilled split bones... but no workie... steering tie rod hits the bones.... and the steering box...I was gonna move the box up... but that only fixes half the problem... so now I'm thinking flat top hair pin and f1 steering box???????????????????
  18. DDDenny
    Now, about those rocker covers!
    ALLDONE, primed34 and twenty8 like this.
  19. hotrodjack33
    hotrodjack33
    I used the Pete and Jake 4 bar/Mustang box on my Sedan Delivery Hi-boy because I wanted the BEST driving hot rod I could build...and drive it a lot.
    Sounds like you are planning a lot of work to get second rate drivability just for appearance's sake...it may look "period correct" just sitting in the garage because it drives like crap.
    Incidentally, nobody ever said: "you should shit-can that 4 bar for split bones"
  20. bchctybob
    bchctybob
    There are a lot of different steering arms available to fix the tie rod problem with the bones. Have you tried mocking up the wishbones with the ends farther inside the frame where they could clear the steering box? They might work better if you can get the frame ends closer together anyway.
    ALLDONE, lothiandon1940 and Happydaze like this.
  21. chevyfordman
    chevyfordman
    It would be some work but a cross steer Vega box with hair pins would look nice but it wouldn't perform any better. I have two 32's with both steering setups.
    ALLDONE likes this.
  22. RICH B
    RICH B
    Not quite the same; I did this Mustang box/ hairpin/MorDrop axle front back in the '70s. Maybe not perfect geometry by today's standard; but with the long hairpins there was no bump steer and the car handled great.
    (Box not installed in the picture; but it was a regular Mustang box with the pitman arm up and a slingshot arm on the spindle.
    hotrodjack33, bchctybob and ALLDONE like this.
  23. ALLDONE
    ALLDONE
    just wondering.. but how close was the tire when turning with the hair pins out that far??
  24. ALLDONE
    ALLDONE
    thanks, but I was trying to stay away from cross steer...
  25. ALLDONE
    ALLDONE
    thanks, I though of that but, the tie rod goes through the center of the bones...it looks like the arms were already heated once and I didn't wanna heat them again and bend the other way..thats why I change my mind to go hair pin....with hair pin every thing will work but the steering box where it's at.. i was also thinking of flat top hair pins to get more clearance... ???? It's been 40 years since I've done this stuff...and even then I had my way of doing it so just order the parts and bolt them on... try'n to re do something and not knowning makes it tuff...
  26. ALLDONE
    ALLDONE
    the rovers???
    oh, I ordered new ones, they're sitting on the bench...so far they haven't installed themselves... maybe wait a few days???
  27. ALLDONE
    ALLDONE
    beauty is in the eye of the beholder... I've already had people tell me "I need to fix it! it looks like shit.... but if I liked it... I'd leave it...
  28. ALLDONE
    ALLDONE
    look at this pic.... the box is probley a foot closer to the firewall than mine.... in fact, i'm betting the box comes up through the floor and not through the firewall???
    another thing that caught my eye... looks like SBF power... and no recess fire wall?? how did you get a fan on it...a pic if you have one please...also I'm assuming it's a stock size hood???or is it longer???
    hotrodjack33 and bchctybob like this.
  29. RICH B
    RICH B
    Good question; no idea after all these years. I remember making some steering stops to work with the Econoline spindles & brakes I had on the car and setting them to get the same steering angle as Ford spindles would have. Also remember making making many tight U-turns off University to hit Porky's so it must have OK.
    I have had to limit steering angle to clear the drag link on some other side steer cars, so I feel I would remember if I had problems with this one.
    ALLDONE likes this.
  30. bchctybob
    bchctybob
    Like someone else said, one thing leads to another. You could cut off the stock steering arms and add new ones or you could buy new spindles that don’t have the arms. I’ve bought several sets of CPP spindles off eBay, very reasonable.
    As far as the tires hitting the hairpins, not really a big deal, it just shortens your turning radius some.
    ALLDONE and lothiandon1940 like this.
