Projects '31 Ford Tudor 'Perfectly Imperfect'
Discussion in 'Traditional Hot Rods' started by SloW8, Jan 29, 2025.
  1. shortypu
    shortypu
    3.jpg IMG_1937.JPG IMG_1294.JPG My build is very similar to yours but my body had no rust and pretty good wood in it really torn about chopping it.I like that you use the orignal brakes,you put a lot of work into them.I did the flathead with a T5 and so far i havent even used 5th gear.When you start chopping it dont forget to take pics and post them.
    duecesteve, rusty1, Tim and 10 others like this.
  2. SloW8
    SloW8
    from Utah - USA
    That’s a nicely done build!
    Outback and Kelly Burns like this.
  3. Outback
    Outback
    from NE Vic, Oz
    Love your Tudor, will follow along. Thanks for sharing
  4. R Tyg
    R Tyg
    Late brake reply. But gearbox still on table, so …
    Floater intructions say reverse roller pin orientation.
    cotter pin end inside.
    Outback likes this.
  5. SloW8
    SloW8
    from Utah - USA
    Thanks for catching that. I will double check.
  6. SloW8
    SloW8
    from Utah - USA
    It has been really slow going. Spent 3 weekends building a pergola in the back yard and that took all my project time.
    I did get the engine painted. The block is New Ford Gray. The heads are gloss black. Hoping to get the flywheel, clutch and transmission bolted on so I can set everything in the frame.
  7. SloW8
    SloW8
    from Utah - USA
    I am using the AV8 kit from Millworks Hotrods. They have a bracket that allows you to use the stock Model A pedals that attaches to the transmission.
    It seems like it will work well.
  8. SloW8
    SloW8
    from Utah - USA
    A little progress.
    I got the flywheel, clutch and transmission installed on the engine and set them in the frame for a second time. I am sure it will come back out at least once but, it is in its final configuration and it seems to line up pretty well.
    These moments feel good. So many things have to be fittled and fetted and no one knows about all the work you have done fighting stuff that should just work. So it is nice when it comes together and you can see some real progress.
    Now on to fight the front brakes.
    marioD, Deutscher and ModelAMitch like this.
  9. tricyclerob
    tricyclerob
    from Fork, Md
    ShortyPU,
    The rear is pretty obvious but can I ask what your front suspension set-up is?
    Also your tire sizes as the rubber rake can make a big difference.
    Thanks,
    robj
    P.S. I'm also building a Tudor and am purposely not chopping the top. I'm looking for a late 30's early 40's style build and my instinct is telling me there are more of these chopped now than there were back in the day. I'm thinking the chopped ones were what got their photos taken but I would bet most, owned by more average guys, weren't chopped, either due to the skill set involved, money, or having the car "down" for that long. After all, these were their daily transportation for work or school.
  10. D2Denny
    D2Denny
    My 31 Tudor A-V8 low buck build. 3" top chop. will have a $175.00 Amazon 32 shell and grill.
    Deutscher, SloW8 and tricyclerob like this.
  11. wstory
    wstory
    Just discovered this great thread. I will follow with interest.
    Purchased this rusty rough 4 1/2' chopped 31 some 5 years ago. Progress has been slow recently but this thread has reignited my enthusiasm.
    As of July this year. The front end goes on soon to confirm the "stance"
    marioD, Deutscher and Tim like this.
  12. shortypu
    shortypu
    Tricyclerob the Axle is an old lucky7 4''drop drilled axle,the spring is a posies 31'' spring,the wish bones are the speedway split bones.The drum brakes are Boling bros 39 lincoln,3''3/4 drop arms,so cal shocks and steering componets on a vega box.The wheels are 40 ford with 5.50x16 front tires and rear are 215/85/16.I dont think im going to chop it now because i just put all new gl*** in it.And i agree about the rubber rake i had ordered 7.50/16'' coker tires like the front ones but after 5 months of waiting on them i went with cheap radial tires. IMG_1890.JPG IMG_1293.JPG
    Deutscher, duecesteve and Wanderlust like this.
  13. Wanderlust
    Wanderlust
    Love the color, what it called?
  14. SloW8
    SloW8
    from Utah - USA
    Well, after much time waiting for parts and doing a little and then waiting for more parts. I was able to manually arch the front linings and get the front brakes working and installed.
    Then I was able to install the front end ***embly and set her down on the ground for the first time. I still have some odds and ends to install on the front end but I am waiting for paint to dry before I do that.
  15. duecesteve
    duecesteve
    My father's '29 has 850 rear and 650 on front all 4 rims were widened 1.5 inches, got a model b 4 cyl with a Weber 2 barrel and 15 lbs shaved off the flywheel, she's pretty snappy IMG_20240502_163917~2.jpg
    Day we got it had been off road since 1979.
    SloW8, marioD and Deutscher like this.
  16. chris101_ny
    chris101_ny
    I'd love a flat 8, but way too expensive for my budget! Going to look great, good luck with it!
  17. SloW8
    SloW8
    from Utah - USA
    I got the rear end painted, rear brakes and the main spring installed.
    Because of the cold weather and limited garage space I will finish painting the rest of the spring pack and get it installed when the weather warms up a bit.
    For now, I slid it all under the frame and am happy with that slow progress.
    Now to focus on the body. I have been toying with the idea of a speedster body but my metal shaping has a long way to go to get to that point. For now I will work with the Tudor body because I want to get this thing on the road.
    That means patching the subframes and the inner fender panels. They are full of rot. The lower front cowl panels have some holes as well.
    The plan is to work on the body and get it to a servicable point.
    Remove the fuel tank and get it cleaned up. Patch up the nasty bits and chop the top.
    duecesteve, Jeff34, Deutscher and 2 others like this.
  18. SloW8
    SloW8
    from Utah - USA
    This is my latest inspiration car. Mine will have a V8 instead of a banger but I think I finally have a complete vision.
    sealgrey29, duecesteve and Jeff34 like this.
  19. I am enjoying the thread, will throw a couple of pictures at you of a car I have seen, to keep the forward momentum. Blue, chopped, half hood, on wires, original rad shell- as in not 32. EED64A0E-B4DC-4D3F-B43B-74D7FB5CBC04.jpeg C410DC65-D16A-43BE-A9F6-BD5A96E668C1.jpeg
    woodz, duecesteve, Jeff34 and 2 others like this.
