What OT crap are you working on
Discussion in 'Off Topic Hot Rods & Customs' started by anthony myrick, May 9, 2024.
  1. swade41
    swade41
    from Buffalo,NY
    Chasing this starting issue on the shovelhead
    Deuces, porkshop, SS327 and 3 others like this.
  2. deathrowdave
    deathrowdave
    from NKy
    There are two relays on a Shovelhead, strange one on the starter one looks like a Ford unit .Clean Grounds are must and burnt contacts will drive a wooden Indian crazy . Just thinkin outloud , I’m sure you have checked everything to this point . Batteries today are totally junk stuff . Load test maybe in order if you haven’t yet . Man the kicker was good , but age is showing up on me now . Don’t like to have to kick off the old dudes often anymore . I did today and got soaked in a storm , just like the good old days !
    Okie Pete, enloe, porkshop and 3 others like this.
  3. deathrowdave
    deathrowdave
    from NKy
    IMG_3710.jpeg IMG_3706.jpeg Replacing the bed on the beater . This will be number 3 .
    Okie Pete, Peezduk, enloe and 4 others like this.
  4. swade41
    swade41
    from Buffalo,NY
    After the video I tried jumping it at solenoid again and it just sparked but that was it. Then I rapped on the solenoid with a hammer and still only the click at the relay "Ford looking one", then I rapped on the starter and finally got a click at the solenoid.
    So at least I know power is getting to the solenoid, battery fully charged and even still had the charger hooked to it. I wish this thing had a kicker, hell I'd be riding.
  5. TA DAD
    TA DAD
    from NC
    All done ! I was surprised at how easy it was to dis***emble. I had the right color paint and used a couple axle lock nuts for the missing headlights, and salvaged the trailer decals, ready for another 100,000 thousand miles. IMG_2065.JPG IMG_2064.JPG
  6. deathrowdave
    deathrowdave
    from NKy
    There is one on the primary to engage the starter drive isn’t there . Not to be a pest , but just thinking out loud . Check for current at the starter positive terminal ( test light ) when you hear the relay engage . Contacts get crusty , coil engages ( click sound ) but no current is p***ing . Again not to be a pest , just thinking out loud . The old dudes aren’t much fun when stupid stuff happens . I always had trouble with handle bar ****ons for start on Shovelheads .
    Okie Pete, SS327 and loudbang like this.
  7. lumpy 63
    lumpy 63
    20250925_130951.jpg 20250920_143253.jpg Got the 12 bolt ***embled and painted. Pretty much all panel fitment done. Pulling subframe this weekend to clean and rebuild. Then it's time for paint:D
  8. TA DAD
    TA DAD
    from NC
    Pulled this 4L80 out of my son's Suburban, I might go through it myself still thinking about that. Looks like it needs the intake pulled off also. IMG_2068.JPG
  9. TA DAD
    TA DAD
    from NC
    Reman. units start at $2500 , my friends Transmission shop is standing room only. He would work me in but I hate using favors when I don't have to. He stocks what I need, for around a grand with a convertor.
    He is young guy in his forties who walked one of my boys through a complete 700 rebuild for that my son did as his senior project in HS.
    At no charge, so you young guys keep that in mind with the teenagers you meet. Share your skills. But I digress !
    I can't pick them up anymore so I had to take the slow route to get it on the table, but there she sits. Pretty well smoked from the looks of things so here we go. IMG_2071.JPG IMG_2070.JPG IMG_2069.JPG
  10. lumpy 63
    lumpy 63
    20250927_091201.jpg 20250927_150810.jpg Pressure washed the underside and then blew the subframe apart.
  11. lumpy 63
    lumpy 63
    20250929_171449.jpg Got the fuel lines done 20250929_171524.jpg And I couldn't resist a little tongue in cheek humor
  12. DDDenny
    porkshop and lumpy 63 like this.
  13. deathrowdave
    deathrowdave
    from NKy
    IMG_3745.jpeg IMG_3763.jpeg One ready for many miles of hard use , one ready to begin rebirth
    cactus1, Okie Pete, lumpy 63 and 3 others like this.
  14. DDDenny
    Every time I see a Tiger I'm reminded of the one my grade school pals' older brother had, bought when I was around twelve years old, 1966, was British Racing Green, ***y little thing.
  15. TA DAD
    TA DAD
    from NC
    That is how a motor should look, nice and clean with no China **** on it. Plus a nice set of headers ! and those heads.
  16. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Put the motor back onto the lathe finally. Lathe is mechanically in good shape. However several key adjustments were lacking. My Son captured this without me knowing. IMG_4721.jpeg
  17. swade41
    swade41
    from Buffalo,NY
    Think I found my starting issue
  18. chevy57dude
    chevy57dude
    ^"At the end of it's service life":eek:.
    @lumpy 63 - that engine looks beautiful!
  19. TA DAD
    TA DAD
    from NC
    Looks like the OD planetary came apart and in turn ruined the forward drum, the 4th gear drum and a couple other hard parts as well. That ****s. IMG_2083.JPG IMG_2082.JPG IMG_2080.JPG
    enloe, Okie Pete, porkshop and 2 others like this.
  20. lumpy 63
    lumpy 63
    Went to a machine shop today that's been closed up for 10 years or so, tons of 350 4 bolt blocks and big block stuff everywhere. I saw a nice set of 292 turbo heads that looked professionally ported and scored em cheap. When I got home I saw the RHS stamps on the ends 20251004_173307.jpg 20251004_173341.jpg
  21. swade41
    swade41
    from Buffalo,NY
    Nice, I was looking at an engine on marketplace that had 492 heads on it, precursor to the 292 could be had with straight or angle plugs but both had 2.02 valves.
    enloe, porkshop, loudbang and 2 others like this.
  22. lumpy 63
    lumpy 63
    IMG_20251009_174751.jpg My pal Tony powder coated the subframe, going to re***emble this weekend
  23. Paladin1962
    Paladin1962
    Finally got the Moggie in primer Sunday... almost got the CAT too... 20251012_123426.jpg 20251012_180741.jpg
    Deuces, Okie Pete and porkshop like this.
  24. Lloyd's paint & glass
    Block sanding 9,650 square feet of 1971 Pontiac that's going black :confused: it's like working on a yacht lmao @scofflaw 20251014_124550.jpg 20251014_142944.jpg 20251014_151608.jpg 20251014_151618.jpg
    61Cruiser, Okie Pete, SS327 and 4 others like this.
  25. Lloyd's paint & glass
    "Hey Lloyd, what off topic **** are you working on?" Lmao! Anybody need a damn job? 20251014_164713.jpg 20251014_164804.jpg 20251014_164815.jpg 20251014_164827.jpg 20251014_164839.jpg 20251014_164847.jpg
  26. Moriarity
    Moriarity
    SUPER MODERATOR
  27. Lloyd's paint & glass
    That's the problem. But it's all good.
    61Cruiser, porkshop and Moriarity like this.
  28. gene-koning
    gene-koning
    When you are self employed, being busy is a much better problem to have then being slow.
    That said, you are cranking stuff out pretty fast, the biggest problems start when things go wrong and you don't get the work done as fast as the customers think it should be done.
    All that really ****s when you want to get your own project done, but the guy in the front office wants to pay the stupid bills first...:eek::D
  29. Lloyd's paint & glass
    I'm not a 9-5 kinda guy. Some nights I'm in the shop pretty damn late. I do crank out a lot of work, but too many people watch TV shows and think that's how it works. It's not real, it's TV. I don't work on anything late model, there are multiple shops around that do that stuff. I had my fill of collision repair. I do what I want to do, and I do my best. But I do think it's time to hire somebody lol. Hard to find the right person.
  30. Greg Rogers
    Greg Rogers
    I love your shop, Lloyd. I wish we were closer. But it looks like you have plenty of work.
    61Cruiser, porkshop and chevy57dude like this.
