Projects finally found a true 57 265 Chevy
Discussion in 'Traditional Hot Rods' started by bfalfa55, Sep 23, 2025.
  1. bfalfa55
    bfalfa55
    Well, I still haven't finished the 265 I want to build for my car but I couldn't p*** up finding this over the weekend. A legit, standard bore 57 265. Now I have one of each:55,56 and 57. 55 and 56's are much easier to find but I will try and grab all of these up that I can find when they cross my path.
  2. BJR
    BJR
    I thought 265's didn't have an oil filter in the block? Or was that just the 1955 265's?
  3. Moriarity
    Moriarity
    SUPER MODERATOR
    yup, only the 55's were without filters
  4. 427 sleeper
    427 sleeper
    That was 55 only. I also thought 57 265's were yellow. :confused:
    But it looks like the heads are off, so the bore could easily be measeued.
  5. bfalfa55
    bfalfa55
    265's made in the Flint planted were painted chartreuse into early December 1956 and the end of November in the Tonawanda plant, then they were painted Orange like a 283. They call it red but it is Orange. The stamped code ending in "C" identifies it as a 265 but I did measure the bore and it is 3.75". Attached is the GM memo stating the color change.
  6. bfalfa55
    bfalfa55
    I want to put together all the correct info. on 265's that I have found. I have a lot that will help eliminate some of the bad info. out there but I could use some help filling in some blanks or things I am unsure of. One for example is: do 55 and 56 blocks have different lifters than the full oiling small blocks ? Another one and this will be tough, what color were the truck blocks painted ? To the best of my knowledge they were never painted the same as the cars. Gray, a turquoisy type blue, a real yellow color and more of a fire engine red are the only colors I have seen or vaguely come across in research but I don't have concrete proof on these colors. Any help will be appreciated. Not many people care about these engines that "started it all" except for crazy people on a forum like this ! LOL !
    CSPIDY, 61Cruiser, Sharpone and 5 others like this.
  7. wheeltramp brian
    wheeltramp brian
    I've got a 56 265 in the corner that I dis***embled that was already a hundred over. Had everything magnifluxed and it's good to go, so it probably just needs some sleeves, pistons etc.
  8. bfalfa55
    bfalfa55
    I have the original 55 block from my dad's car in high school in the corner and I have a highly machine prepped .060 56 on the engine stand that I plan to put in my 55. I have another "plan" to build an interesting twist on a 265. I'd like to find another bare 56 or really a 57 block that is standard or slightly over bored. The plan is to use GM 5.94 rods for the L-99 (called the Baby LT-1) of the 90's era and then I can use any over the counter 305 piston. This makes for less expensive parts and the "long rod" concept should achieve more dwell time at top dead center. After some discussions with some full time racers, this should actually make more power than your typical 5.7 rod and 3" stroke. I think I need my head examined ! LOL !
  9. 302GMC
    302GMC
    from Idaho
    Why not punch it to 3 7/8'' & use stock 283 pistons ?
    Uncle Lee, bfalfa55, Sharpone and 3 others like this.
  10. krylon32
    krylon32
    from Nebraska
    Got what I believe is a 56 265 in my deuce daily driver pickup backed up by a 350 trans into a 3.0 geared 9 inch rear. It runs great so far. Truck is very noisy so I wear noise canceling head phones and find myself running 80+ on the 4 lane.
    Outback, LCGarage, bfalfa55 and 2 others like this.
  11. d2_willys
    d2_willys
    from Kansas
    Looks like the 57 265 still mounts from the front, as I don't see side motor mount holes in the block. If that's the case, then the 57 265's probably were never equipped with Turboglide, as I don't believe the aluminum bell housing had provisions for motor mounts. Block mounted starter holes are probably absent too.
    bfalfa55, Sharpone and chryslerfan55 like this.
  12. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Here’s a 58 (tailhousing mounting point) unit that still has 57 bellhousing mounting points. IMG_4704.jpeg
  13. d2_willys
    d2_willys
    from Kansas
    Yes that does look like the mount holes. But does the 57 265 have the block mount starter holes or do they use an adapter plate to mount starter?
  14. 427 sleeper
    427 sleeper
    57 265's were two barrel, stick shift applications only. No need for side mounts or starter pad bolt holes.
  15. Johnny Gee
    Johnny Gee
    from Downey, Ca
    What 427 sleeper said.
  16. 1934coupe
    1934coupe
    It always amazes me about the wealth of knowledge on the Hamb.
    Pat
  17. d2_willys
    d2_willys
    from Kansas
    Yes, that clears up everything. Funny, you could get Powerglide with 235, but not with 265.
    bfalfa55 and Sharpone like this.
  18. 427 sleeper
    427 sleeper
    Yet, if you'd have antedup for a 283, you could get damn near any combination you wanted... wierd... :confused:
  19. Sharpone
    Sharpone
    Thank you for the history Good stuff!
    I see a lot of 265 and 283 stuff at swap meets for damn near free, amazing to me. I should start buying I guess.
    Dan
    bfalfa55 likes this.
  20. Dynaflash_8
    Dynaflash_8
    from Auburn WA
    I've got a 55' 265 in my 46 ford farm truck backed by the flathead 3 speed. Fantastic little motor. Its a factory 4 barrel so I think that makes it 210 hp? Byp*** oilfilter mounted off the water neck.
    I've got a 56 oil filter block in the barn for my roadster. They do have special lifters with a higher oil hole. The rear cam bearing is not grooved so the cam has to be notched for the pulsed oiling to the top end.
  21. 2935ford
    2935ford
    My '32 pickup had a rebuilt 265 w/stock 4bbl. Great little motor.
    Tickety Boo and bfalfa55 like this.
  22. bfalfa55
    bfalfa55
    Only because there are so many 283 blocks to find. I do have a set of original std. bore 270/283 pistons that just may get used for a future build.
    Tickety Boo likes this.
  23. bfalfa55
    bfalfa55
    Correct. 57 265's were an upgrade from a 6 cyl. and all were 2 brl. 3 speeds whether in a car or truck. To the best of my knowledge, they only put 115 265's in 57 trucks!
    427 sleeper and Tickety Boo like this.
  24. bfalfa55
    bfalfa55
    Buy them before everyone s****s them. Most think they are all worth big bucks because they are old and rarer to find but only me and the rest of the nut jobs on sites like The HAMB care to mess with them ! LOL !
    Outback, Baumi, williebill and 2 others like this.
  25. bfalfa55
    bfalfa55
    Thanks for answering the lifter question. You can also modify the rear cam journal and connect the oiling hole with the annular groove and make it full oiling to the top end. Then you can run a 1 hole rear bearing and no notch. 57 block is not like a 55-56, full oiling. 55-56 is also a different distributor. The oiling is different on it too.
  26. bfalfa55
    bfalfa55
    If the casting number ends in 991, it's a 56. If no filter on the block, you know it's a 55. 55 casting number ends in 524. a 57 block ends in 548 for a 265 and a 283. You have to check the stamped code to be sure but some 57 265's were bored out to 283 because you could do that easily since the block was designed that way from the factory.
    Outback, Tickety Boo and Johnny Gee like this.
  27. Mo rust
    Mo rust
    I've got an early small block that I'm trying to identify that was in this old model A roadster when I bought it. It's got an old iron powerglide attached to it and no side mounts. It has straight across valve covers and I ran the numbers on those and they were early sixties. The valve covers were staggered bolt covers that were old chrome and had been redrilled to put them on the early sixties heads. It's got a four barrell carburator that was from a 1960 Dodge so it was obviously pieced together from what they could find.
    Outback, williebill and bfalfa55 like this.
  28. Moriarity
    Moriarity
    SUPER MODERATOR
    57 283 obviously someone put later heads on it
    bfalfa55 and Mo rust like this.
  29. Butch M
    Butch M
    i have one of them yellow 265s
    GlassThamesDoug and bfalfa55 like this.
  30. bfalfa55
    bfalfa55
    What Moriarity said is the case, 57 283. If it were a 265 the last letters would be C, CD or CE for a car and L, LA, LB or M for a truck.
    Moriarity likes this.
